STEPPER AND HOMING PROBLEMS
2.5k
    Veti @swrightlast
    @swrightlast
    Can i make a general suggestion. Can you please keep a log of the changes you are doing.
    This will allow you to better retrace your step on changes you have made.
    So if your printer was working a week ago, you made some changes, and then realised its not working anymore that you can revert those changes.
      swrightlast @Veti
      @Veti standard folgertech nema 17, 1.8 degree. 5kg/cm, 1.5a![alt text](image url)20191106_095244.jpg
      undefined 1 Reply Last reply 6 Nov 2019, 20:58 Reply Quote 0
        Veti @swrightlast
        @swrightlast
        the image did not upload
        undefined 1 Reply Last reply 6 Nov 2019, 21:03 Reply Quote 0
          swrightlast @Veti
          @Veti i couldn't get one of the images to load...still working on it. I'll reload the one that did load.20191106_095522.jpg
          undefined 1 Reply Last reply 6 Nov 2019, 21:22 Reply Quote 0
            Veti
            for others this seems to be the datasheet
            https://folgertech.com/products/nema17-17-stepper-motor-36oz-in-2600g-cm-3d-printer-reprap-medel-prusa-1
              swrightlast @swrightlast
              @Veti yep, that's my stepper. i still cannot get the image of my board wiring to upload. both were jpg, taken at the same time. anyway, my stepper wiring at the board, from left to right is red, gray, yellow, green.
                Veti
                you could try and post it somehwere else and link it. like
                https://imgur.com/
                undefined 1 Reply Last reply 6 Nov 2019, 21:34 Reply Quote 0
                  swrightlast @Veti
                  @Veti https://i.imgur.com/kQ5BBjJ.jpg
                    Veti
                    from the spec of the motor i read that yellow and red should be one phase and green and grey.
                    if that is true. your wiring is incorrect.
                    undefined 1 Reply Last reply 6 Nov 2019, 21:51 Reply Quote 0
                      swrightlast @Veti
                      @Veti my z wiring is the same, and it functions fine.
                        Veti
                        what is the resistance between the
                        red and yellow
                        green and yellow.
                        cables
                        undefined 1 Reply Last reply 6 Nov 2019, 22:31 Reply Quote 0
                          swrightlast @Veti
                          @Veti I get no reading on either one
                            Veti
                            just to make sure. you measured while the cable is plugged into the motor?
                            is there any resistance between the yellow cable and any other cable?
                            can you check directly on the pins of the motor?
                            undefined 1 Reply Last reply 7 Nov 2019, 19:53 Reply Quote 0
                              swrightlast @Veti
                              @Veti
                              green/yellow: 2.4 ohm
                              red/gray: 2.4 ohm
                              measured directly on motor pins
                              rechecked at board ends.....no ohmage (sic).....bad crimps or break in wire someplace?
                                Veti
                                @swrightlast said in STEPPER AND HOMING PROBLEMS:
                                so you had no resistance with the cable. this suggest that the cable is broken.
                                undefined 1 Reply Last reply 7 Nov 2019, 20:09 Reply Quote 0
                                  swrightlast @Veti
                                  @Veti I have new cables coming....check back on this post next week. Thanks everyone for all your help so far.🤞 🤞
                                  53 out of 59
