STEPPER AND HOMING PROBLEMS
I made some corrections. Try that one.
@swrightlast , I must be getting tired. How do I upload my config.g to this discussion?
nope you got it uploaded. I cleaned up some formatting and structure. There were two commands on the same line and I removed the D values from drive setup that was trying to use stealthchop.
You can either download the file I uploaded and rename it to config.g and upload it to the duet, or you can copy and paste from below.
; General preferences G21 ;Set units in mm from this point G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M550 PCoreXY ; Set machine name M667 S1 ; Select CoreXY mode M552 S1 ; Enable network and acquire dynamic address via DHCP M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes backwards M569 P3 S1 ; Drive 3 goes backwards M350 X16 Y16 Z16 E16:16:16:16:16 I1 ; Set miscrostepping x16 with x256 interpolation M92 X80 Y80 Z400 E412 ; Set steps per mm M566 X400 Y400 Z300 E3000 ; Set maximum instantaneous speed changes (mmmin) M201 X500 Y500 Z500 E1500 ; Set accelerations (mms^2) M203 X12000 Y12000 Z1500 E6000 ; Set maximum speeds (mmmin) M906 X1200 Y1200 Z1100 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X300 Y300 Z380 S0 ; Set axis maxima ; Endstops M574 X1 Y1 S0 ; Set active low endstops ; Pressure advance ; Set pressure advance M572 D0 S0.15 ; Z-Probe M574 Z1 S0 M558 P9 H3 F500 T2000 B1 ; Disable Z probe but set dive height, probe speed and travel speed M557 X40:290 Y40:290 S50 B1 ; Define mesh grid G31 X-10 Y60 Z0.9 P200 ; Heaters M305 P0 T100000 B4171 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0:1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets ; Custom settings are not configured M501
@Phaedrux I tried it.....no change.
@swrightlast it keeps showing the motor phase error for both x,y.
Well motor phase error and stealth chop error are seperate problems.
The stealthchop thing was from the configuration.
The motor phase error is saying that the motor phases as wired are incorrect. You'll have to identify the correct pairs of wires and swap the wire positions in the plug.
There are two methods of identifying the motor phase pairs in that link. Did you try both of them?
@Phaedrux funny thing is, i only put new board connectors on x,y. z axis homes just fine....z was not involved in what i was doing. the board connector wiring is the same on x,y as it is on z. this just gets curiouser and curiouser. I'm going to call it quits for tonight. Try again tomorrow.
can you post picture of the cable connection on the stepper and the duet.
also please post the model number of your stepper drivers. -
Can i make a general suggestion. Can you please keep a log of the changes you are doing.
This will allow you to better retrace your step on changes you have made.
So if your printer was working a week ago, you made some changes, and then realised its not working anymore that you can revert those changes. -
@Veti standard folgertech nema 17, 1.8 degree. 5kg/cm, 1.5a20191106_095244.jpg
@swrightlast
the image did not upload -
@Veti i couldn't get one of the images to load...still working on it. I'll reload the one that did load.
for others this seems to be the datasheet
https://folgertech.com/products/nema17-17-stepper-motor-36oz-in-2600g-cm-3d-printer-reprap-medel-prusa-1 -
@Veti yep, that's my stepper. i still cannot get the image of my board wiring to upload. both were jpg, taken at the same time. anyway, my stepper wiring at the board, from left to right is red, gray, yellow, green.
you could try and post it somehwere else and link it. like
https://imgur.com/ -
from the spec of the motor i read that yellow and red should be one phase and green and grey.
if that is true. your wiring is incorrect.
@Veti my z wiring is the same, and it functions fine.
what is the resistance between the
red and yellow
green and yellow.
cables -
@Veti I get no reading on either one
