true bed leveling dual independent lead issue
Hey I'm not a 100% sure if my problem is only IR probe related, but here's the description of my issue.
I used a BLTouch on my duet 2 wifi before running 2.04 firmware now I replaced the BLTouch with the mini IR probe, if I do a G32 a few times in a row the level get's better with every iteration and I usually stop doing it with sub 0.008 mm deviation.
but sometimes it's like increasing the deviation. so really no repeatable behaviour.
But then no matter what I do next be it a bed mesh calibration or starting a print or just moving the z-axis up and down, the gantry is tilted again.
I also have the impression that the z-motors don't run simultanious.
btw I'm using black printbite plus.I would highly appreciate any hints that could point me to the cause of that issue.
post your config.g and bed.g
0:/sys/config.g
; generated by RepRapFirmware Configuration Tool v2.0.4 on Tue Oct 08 2019 18:53:18 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"VLN_CR10S" ; set printer name; Network
M551 P"killer33" ; set password
M552 S1 ; enable network and acquire dynamic address via DHCP
M587 S"printer.printer" P"shippuden"
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M584 X0 Y1 Z2:4 E3
M569 P0 S0 ; physical drive 0 goes backwards
M569 P4 S1 ; Physical drive 4 goes forwards
M350 X32 Y32 Z32 E16 I0 ; Configure microstepping without interpolation
M584 X0 Y1 Z2:4 E3
M669 K0.9
M671 X-27:327 Y155:155
M92 X160.00 Y160.00 Z800.00 E406.00 ; Set steps per mm
M566 X360.00 Y360.00 Z12.00 E260.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X15000.00 Y15000.00 Z600.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X900.00 Y900.00 Z200.00 E360.00 ; Set accelerations (mm/s^2)
M906 X1000.00 Y1000.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 Set idle timeout; Axis Limits
M208 X310 Y310 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 S1 ; set active high endstops; Z-Probe
;M574 Z1 S2 ; set endstops controlled by probe
;M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
;M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
;G31 P500 X+32 Y-2 Z2.319 ; set Z probe trigger value, offset and trigger height
;M557 X35:275 Y35:275 S50 ; define mesh grid
;M557 X35:280 Y35:280 S50; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M558 P1 H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor
G31 P500 X-2 Y-16.4 Z2.114 ; Set Z probe trigger value, offset and trigger height
;M557 X30:270 Y30:270 S80 ; Define mesh grid
M557 X30:280 Y45:280 S45; Heaters
M305 P0 T100000 B4267 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1
M106 P1 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S0 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossM501
; bed.g
G30 P0 X35.0 Y155 H0 Z-99999
G30 P1 X275.0 Y155 H0 Z-99999 S2 -
@gueee78 said in true bed leveling dual independent lead issue:
Unless there is a very specific reason, you should be running x16 with interpolation.
M669 K0.9
This command makes no sense. K requires an integer
there is something wrong with your probe if the bed looks like that. (
or if thats the actual bed, consider getting a new one) -
the wiki says fudge factor default is 1.0 doesn't seem to be an integer? the probe is new, the bed as well and it's a precision milled cast aluminum plate. no interpolation was accidently set, cause I got parts of the config from a buddy with a flex3drive with 40:1 gear reduction. I have a feeling that it could be PSU related, it's still the stock 12 volts psu of the cr10s
https://duet3d.dozuki.com/Wiki/Gcode#Section_M669_Set_kinematics_type_and_kinematics_parameters
What fudge factor? M669 sets the Printer Type
please run this macro
https://forum.duet3d.com/topic/6962/m48-measure-z-probe-repeatability-and-print-to-serial-output
