    endstops on CONN_LCD (E7/E8)
    376
    • CJ.BRAVOundefined
      CJ.BRAVO
      Re: syntax for endstops on CONN_LCD
      Hey, was wondering to which pins should I connect for E7/E8 on the LCD conn to create trigger.
      there's a bunch..
      thanks!
        droftarts administrators
        On the wiring diagram, they are marked as stop10 and stop11. They are the 10th and 11th driver, but are seen by the firmware as the 7th and 8th extruder connections, so defined as E7 and E8!
        • TCundefined
          TC
          Are they supppsed to work without any special changes? Because I tried that and they triggers on these two did respond at all.
            dc42 administrators @TC
            @TC said in endstops on CONN_LCD (E7/E8):
            If you use RRF 2.04 then you need to add external pullup resistors when using them. If using RRF3, enable the pullup resistor using ^ at the start of the pin name.
            CJ.BRAVOundefined 1 Reply Last reply Reply Quote 0
            • CJ.BRAVOundefined
              CJ.BRAVO @dc42
              Hi david, can you elaborate on the pullup resistor setup? also, do I need to ground my trigger ?
                dc42 administrators @CJ.BRAVO
                @CJ-BRAVO said in endstops on CONN_LCD (E7/E8):
                I've just checked the code, and to use those pins as endstop inputs in RRF 2.04 you don't normally need to add pullup resistors, because the internal pullup resistors are enabled except when you configure those pins for filament monitors.
                • CJ.BRAVOundefined
                  CJ.BRAVO
                  ok. so need for pullup resistors for e7 and e8. what about the rest of the trigger, do i need resistors?
                  and what about grounding the triggers? I noticed that if not grounded the duet acts funny.. kinda freezes.
                  does that make sense?
                    What do you mean by "grounding the triggers"? What are you using to generate a trigger?
                    • CJ.BRAVOundefined
                      CJ.BRAVO @dc42
                      I've got a 3 prong button that triggers the endstop - running some macros.
