beginer cr10 questions
I got a CR-10, I try to make my config files and still not be able to correct somes things...
My cr-10 have only this modifications:
the X axes inverted
BMG Extruder
3 wires limits switchs (VCC,Ground,Signal)
Duet WiFi boardFirst problem (I don't make to much search on this one)
My X homing movement is inverted and it just move alittle and stop with homing done. It does't not hit any limit switch
2nd
My manual homing in z is perfect even with home all. When I start my program I can't change Z speed for homing and retract inprint Z movement.Here's is my config.g code
Thank you
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Network M550 CR-10 ; Set machine name M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Drive 0 (X) goes forwards M569 P1 S0 ; Drive 1 (Y) goes forwards M569 P2 S1 ; Drive 2 (Z1) goes backwards M569 P3 S1 ; Drive 3 (E) goes forwards M584 X0 Y1 Z2 E3 ; Driver 0=X, 1=Y, 2=Z, 3=E M350 X16 Y16 Z16 E16 I1 ; Configure micro-stepping with interpolation M92 X80 Y80 Z400 E460 ; Set steps per mm M566 X1200 Y1200 Z1800 E300 ; Set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z1800 E1500 ; Set maximum speeds (mm/min) M201 X500 Y500 Z500 E500 ; Set accelerations (mm/s^2) M906 X525 Y600 Z675 E600 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X300 Y300 Z400 S0 ; Set axis maxima ; Endstops M574 X1 Y1 Z1 S1 ; Set active high endstops ; Z-Probe M210 X1500 Y1500 Z1800 ;Set the feedrates used for homing to the values specified in mm per minute. ; Heaters M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1 M307 H1 A493.9 C176.8 D4.6 S1.00 V23.9 B0 ; E3D V6 Hotend Calibration M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 H-1 ; Part Cooling Fan. Manual control. M106 P1 T45 H1 ; Hotend Heatsink Fan. Thermostatic control, max RPM at 45C. M106 P2 T25:65 H100:101:102 ; Duet Electronics Fan. Thermostatic control, turn on at 25C, max RPM at 65C. ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Miscellaneous T0 ; Select first tool
@EdI_VeDeR said in beginer cr10 questions:
change
to
M569 P0 S0 ; Drive 0 (X) goes forwardsand
to
M574 Y1 Z1 S1 ; Set active high endstops
M574 X1 S0 ; Set active high endstops -
Thank you for fast anwser.
For my slow homing I found the problem in my cura "start gcode"
