RepRapFirmware 3.0beta12 now available
M143 is implemented but not tested yet - and in my book, untested code is broken code.
The priorities for RRF3 development are:
- Complete the support for expansion boards on Duet 3
- Conditional GCode and object model
- Add a few missing features
Conditional GCode sounds amazing and incredibly powerful, look forward to that one. Thanks for the update.
@dc42 Thanks for this rough roadmap.
could you tell us what is the plan for 3HC expansion board ?
Because Can-FD is promissing if all features are working on 3HC (Z probe / servo / Thermocouple ...)Conditionnal Gcode sounds great too, even I prefer to have features working first
The following items connected to expansion boards work in beta 12:
- Stepper motors, temperature sensors (inc. thermocouple and PT100 but not DHT), heaters (but not heater protections, and not heaters controlled by sensors on a different board), fans (including tacho readings, but excluding fans thermostatically controlled by sensors on a different board).
In the current committed source code, endstop switches are also working; but I need to add a safety feature before I release that.
The following are either not implemented on expansion boards or implementation is in progress, and therefore not working yet:
- GPIO output (M42), servo output (M280), trigger inputs, stall detection endstops, Z probes, reporting of stepper driver errors and warnings, additional diagnostics inc. crash reports.
Assuming no component shortages, I estimate that first deliveries to the 3HC to customers will be 5 to 6 weeks from next Monday. So we may just miss delivery before Christmas, in which case deliveries won't start until after New Year. We'll have a better idea next week and we may open a pre-order.
@dc42 thanks for this detailed answer, End of the year sounds Great ! I will that closed to a Christmas Beer
Endstops are now working on expansion boards, using the main+expansion firmware builds at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
I still miss a fix for the tool changer scripts, that the Z axis is not moving while tool changing. Also happens on 2.xx
@smoki3 said in RepRapFirmware 3.0beta12 now available:
Please provide a link to the post where you described this. Or, if it is in a thread with lost of other stuff, start a new thread.
@dc42 said in RepRapFirmware 3.0beta12 now available:
Bug in 2.03, 2.04RC1 and latest 3.0 beta: https://forum.duet3d.com/topic/11343/new-reprapfirmware-3-0-early-beta/30
Its already on the bug list. but its a bit hidden. You may have fogotten
I copied the conversation in this thread:
https://forum.duet3d.com/topic/12920/tool-change-moving-in-axis-without-calling-them
Thanks, I'll put further responses i that thread.
@dc42 yes :)! I hope I donβt miss the pre-order
M308 S1 Y"rtdmax31865" P"spi.cs1" A"RTD1" M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S360 ; set temperature limit for heater 1 to 360C M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit M308 S2 Y"rtdmax31865" P"spi.cs2" A"RTD2" M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2 M143 H2 S360 ; set temperature limit for heater 2 to 360C M307 H2 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
Does the above look right for a pair of PT100 sensors plugged into the PT100 Daughter board on a Duet 2 Wifi?
The second tool appears correct, but the first is stuck at ~210Β°C (even though it's cool to the touch).
I'm also struggling to work out how to have a fan be thermostatically controlled by
mcutemp
, which I'm pretty sure I had in V2 (though, I may be mistaken). -
@keyz182 said in RepRapFirmware 3.0beta12 now available:
Yes, that looks correct. What reading do you get if you connect the 100R resistor to the second input instead of the PT100?
mcutemp
, which I'm pretty sure I had in V2 (though, I may be mistaken).Create a sensor for mcutemp, then use that sensor number ni the H parameter of your M106 command. In RRF3 the M106 H parameter refers to a sensor number, not a heater number.
Just been fiddling around - it appears it may be a connection issue (reading varies a lot, even going up to 2000C based on touching the wire), so going to check/rewire that first. Will check the 100R if I have one.
mcutemp
Ahh, gotcha. Thanks.
Yup, it was a bad connection Added a dab of solder to the crimped connections to firm them up a bit and all is good.MCU temp is working perfectly now too. Had missed the bit about M106 H now being sensor rather than heater. I see it's in the notes on the wiki for M106 now. I added this
(this refers to sensor number in RRF_3)
to the end of theHnn:nn:nn
description on there just to highlight it a little more if that's OK? -
New issue - porting over my sensorless homing settings.
config.g
M915 X Y S4 F0 H200 R1
homeall.g
G91 ; relative positioning M913 X45 Y45 ; drop motor currents to 45% M915 X Y S4 R0 F0 ; set X and Y to sensitivity 2, do nothing when stall, unfiltered G1 H2 X20 Y20 Z5 F6000 ; lift Z relative to current position G1 H1 X-281 Y-325 F6000 ; move quickly to X or Y endstop and stop there (first pass) G4 P150 G1 X20 Y20 ; move away from home G4 P150 G1 H1 X-281 F3600 ; home X axis G4 P150 G1 H1 Y-325 F3600 ; home Y axis G4 P150 G1 X20 Y20 F6000 ; go back a few mm M400 ; make sure everything has stopped before we reset the motor currents M913 X100 Y100 ; reset motor currents G90 ; absolute positioning G1 X125 Y150 F3600 ; Move to bed centre G4 P500 ; pause G91 ; relative positioning ; BLTouch Z G30 ; Do a single probe to home our Z axis G90 ; Make sure we are in absolute mode G1 Z10 F360 ; Rapidly move the Z axis to Z=10.
It gets up to the second
G1
, but as soon as it hits an axes (aka the "endstop") it stops homing and ignores the rest of the script. -
There is a known issue with stall detect homing in the RRF3 beta releases up to and including beta 12. The more recent build on Dropbox includes a change that may fix it.
Gotcha. The dropbox build also fails in the same way unfortunately.
Thanks, on my list to look at after FormNext.
