    Duet wifi 5v expansion issue
    • 3DGoatundefined
      3DGoat
      I have been trying to fix my BLtouch and now i have the problem down to the Duet wifi not supplying 5v to the expansion slots, I have the 5v from the power supply jumper connected. I connected a multimeter and it is not showing anything. I have been having this problem for months now, is it possible to break the duet in some way where it doesn't supply the 5v? how can I fix this? Thanks for the help.
      • elmoretundefined
        elmoret
        @dc42 @T3P3Tony
          Where are you trying to measure 5V with your multimeter? Have you tried the PanelDue connector?
          • 3DGoatundefined
            3DGoat
            I am measuring the pins 1 and 2 on the controller expansion, I am using two jumper cables connected to my multimeter.
              dc42 administrators @3DGoat
              @3DGoat said in Duet wifi 5v expansion issue:
              Please confirm which jumper you are referring to.
