Ammeter to measure hotend output?
My Duet controlled machine
356
    sinned6915
    I am trying to tweak my hotend and PID tuning as a result of reading the wiki description-
    https://en.m.wikipedia.org/wiki/PID_controller
    So i put a 10A 0-100VDC ammeter inline with the hotend to see what the output was actually doing.
    Ammeter on hotend
    I think that the ammeter is averaging out the PWM signal. So for example, if the display reads 6V on a 24V system, then its at ~25%PWM output?
    Is there a way to display the actual PWM output either on DWC or on the PanelDue?
    I thought that this was somehow accessible as a data point? How would we read it or graph it?
    thanks in advance
    sinneD
      jens55
      Unless you have a meter that reads true RMS (I doubt the one in the picture will do that), your setup will confuse you more than help you.
      undefined 1 Reply Last reply 25 Nov 2019, 07:40 Reply Quote 0
        sinned6915 @jens55
        @jens55 agreed. its a curiosity at best right now.
        is the real value for duty cycle available in the data stream somewhere? I would trust that as reliable.
          You can use the M573 command to report the actual heater PWM.
          undefined 1 Reply Last reply 26 Nov 2019, 04:04 Reply Quote 0
            sinned6915 @dc42
            @dc42 said in Ammeter to measure hotend output?:
            dc42: is that a static call and response? is there any way to make it into a data stream to display on the PanelDue or DWC console?
              sinned6915
              maybe i should have introduce more to this-
              i am getting random 'Heater Fault" reporting.
              It does not show up onthe GCode console
              the print does not pause either- the heaters are still on and the print is still going.
              the false positive is just as bad as a real one in my mind.
              undefined 1 Reply Last reply 26 Nov 2019, 07:18 Reply Quote 0
                jens55
                You might want to try and reboot the Duet - I had random errors like that and they still crop up now and then. Rebooting fixes that for me. There is some flag left over someplace from a previous error that causes the message to pop up ... and I had this happening just now. You can dismiss the warning and carry on but it will pop up again sometime later and only a reboot clears the flag.
                  dc42 administrators @sinned6915
                  @sinned6915 said in Ammeter to measure hotend output?:
                  Have you run M303 heater tuning? https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them
                  1 out of 8
