    Delta + linear Z tracking axis?
    38
    2.4k
    • Quadcellsundefined
      Quadcells @dc42
      @dc42 said in Delta + linear Z tracking axis?:
      @Quadcells said in Delta + linear Z tracking axis?:
      What is a very long rod length?
      My rods are 400mm, what should I make the rod length for the 4th tower which I will use for a camera.
      /quadcells
      Try about 20x to 100x higher, so 8000mm to 40000mm. Test it very carefully, in case the maths overflows.
      Wow, ok will do, could be a day or two to test it. Printing the extrusion supports now.
      Thanks for your quick reply.
      /quadcells
      /quadcells
        Quadcells
        A little confused about M669.
        Since I am using the 4th tower for a camera to track the height of the effector and placing my 4th tower between the Z tower and Y tower. Do I need to use M669?
        "You must specify the XY offsets of the extruder outputs on additional towers relative to machine centre in the M669 command, for example:
        M669 X150 Y100
        The M669 command must come after the M665 command."
        This is my M665 line;
        M665 R244.500 L400.970:400.970:400.970:8019.4 B150.0 H448.37 X-0.072 Y0.021 Z0.000
        /quadcells
          Quadcells
          Sorry for all the questions.
          I would like to use E1 for the 4th tower stepper driver how do I map that drive, M584?
          /quadcells
            dc42 administrators @Quadcells
            It may work without, but if in doubt I suggest you use X0 Y0.
              Create a U axis for that drive as described at https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Adding_additional_towers_to_carry_flying_extruders.
              Quadcellsundefined 1 Reply Last reply Reply Quote 0
                Quadcells @dc42
                @dc42 Thank you.
                I'll get back later after I try this out.
                /quadcells
                Munce31undefined 1 Reply Last reply Reply Quote 0
                • Munce31undefined
                  Munce31 @Quadcells
                  @Quadcells very keen to see how this goes. Please let us know. Thanks.
                    Quadcells @Munce31
                    @Munce31 I will. But it could take a few days. Trying to juggle work/home and hobbies can sometimes be difficult.
                    /quadcells
                      Quadcells @Quadcells
                      @Quadcells
                      I connect my 4th tower stepper to E1.
                      Connected the 4th tower endstop to E1 stop.
                      Added all lines of code for the 4th tower in confi.g.
                      Added lines of code for the 4th tower in homedelta.g
                      Nothing happened, the 4th stepper did move or make any noise. I must be missing something along the way. I will re-check again.
                      below is some config.g and homedelta.g code:
                      config.g:
                      M665 R244.500 L400.970:400.970:400.970:8019.4 B150.0 H448.37 X-0.072 Y0.021 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height,4th rod length for camera is 20x more XYZ
                      M669 X0 Y0 ; specify the XY offsets of the extruder outputs on additional towers relative to machine centre. It may work without, but if in doubt I suggest you use X0 Y0.
                      M666 X-0.34 Y-0.31 Z0.66 tilt X0.00 Y0.00 ; Put your endstop adjustments here, or let auto calibration find them
                      M584 X0 Y1 Z2 U4 E3 ; U4 is the 4th tower axis which is E1 stepper driver on the Duet Wifi board
                      M569 P0 S0 ; Drive 0 goes forwards, X tower stepper
                      M569 P1 S0 ; Drive 1 goes forwards, y tower stepper
                      M569 P2 S0 ; Drive 2 goes forwards, Z tower stepper
                      M569 P3 S0 ; Drive 3 goes forwards, E0 stepper
                      M569 P4 S0 ; Drive 4 goes forwards, 4th tower stepper
                      M350 X16 Y16 Z16 U16 E16 I1 ; Configure microstepping with interpolation
                      M92 X200 Y200 Z200 U200 E2787 ; Set steps per mm
                      M566 X1200 Y1200 Z1200 E40 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
                      M201 X1000 Y1000 Z1000 E120 ; Set accelerations (mm/s^2)
                      M906 X1600 Y1600 Z1600 U1600 E500 I40 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M574 X2 Y2 Z2 U2 S1 ; Set active low endstops
                      M558 P5 R0.4 X0 Y0 Z0 H10 F1000 T6000 ; Set Z probe type to effector, the axes for which it is used and the dive height + speeds
                      G31 P100 X0 Y0 Z-0.333 ; Set Z probe trigger value, offset and trigger height
                      M557 R105 S20 ; Define mesh grid
                      homedelta.g:
                      ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
                      G1 S1 X450 Y450 Z450 U450 F1400 ; move all towers to the high end stopping at the endstops (first pass)
                      G1 X-5 Y-5 Z-5 U-5 F1800 S2 ; go down a few mm
                      ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
                      G1 S1 X10 Y10 Z10 U10 F360 ; move all towers up once more (second pass)
                      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
                      G90 ; absolute positioning
                      G1 X0 Y0 F6000 ; move X+Y to the centre
                      /quadcells
                        You may need to put the M584 command before the M665 command, so that the U axis already exists when you specify the length of the rod to the U tower.
                          Quadcells
                          Thanks for you reply and suggestion.
                          Now U shows up under "Machine Movement" and I can move the carriage up and down via the controls on DWC and PanelDue, but only 200mm. When I run "Home All" only XYZ carriages move like they should, not U. I have changed the rod length down to 800 from 8000 but still nothing.
                          Gonna do more reading and testing and see where I went wrong.
                          /quadcells
                            Your homedelta.g file should have G91 as the first command.
                            You will need to hide the U axis under normal conditions using M584 P3, and un-hide it during homing.
                              Quadcells @dc42
                              @dc42 G91 is the first command in homedelta.g, I just didn't include it on my post.
                              When I get home later today i will hide the U axis and un-hide it during homing.
                              Does that mean I un-hide the U axis in the homedelta.g file?
                              /quadcells
                                Ok I just read that M584 P4 should be at the top of my homedelta.g file. Should that be before or after G91.
                                /quadcells
                                  Quadcells
                                  Is this how it should be?
                                  config.g:
                                  This
                                  M584 X0 Y1 Z2 U4 P3 E3
                                  or this
                                  M584 X0 Y1 Z2 U4 E3
                                  M584 U4 P3
                                  Also does G10 need U:
                                  G10 P0 X0 Y0 Z0 U0
                                  and
                                  homedelta.g:
                                  G91
                                  M584 U4 P4
                                  thanks again for your help.
                                  /quadcells
                                    droftarts administrators @Quadcells
                                    This, though I'd actually rewrite it M584 X0 Y1 Z2 U4 E3 P3. The P3 means "show the first three defined axes (excluding extruders)".
                                    G10 P0 X0 Y0 Z0 U0
                                    I'm not sure of the effect of setting this, probably fine.
                                    homedelta.g:
                                    G91
                                    M584 U4 P4
                                    This can just be M584 P4. You'll need M584 P3 at the end to hide the U axis again.
                                    This is incorrectly formatted. See M666. Format is M666 Xnnn Ynnn Znnn Annn Bnnn
                                    Quadcellsundefined 2 Replies Last reply Reply Quote 0
                                      Quadcells @droftarts
                                      @droftarts
                                      thank you Ian.
                                      I'll try it out and report back with the results. Hopefully tonight.
                                      /quadcells
                                        That's strange. It has been that way since I made this file using the configuration tool 2 years ago.
                                        But I will change it after reading.
                                        /quadcells
                                          but the config-override.g has it correct:)
                                          /quadcells
                                            All working now. Camera axis tracks the effector's Z.
                                            I have to re-print my camera carriage as the camera is too close to the effector when I run G32.
                                            Thanks for all your help.
                                            /quadcells
