    Smart Effector hotend fan and Lights
    1.4k
      dc42 administrators @oryhara
      @oryhara said in Smart Effector hotend fan and Lights:
      How much solder skill is needed to replace the fan mosfet? I rate mine at 5/10.
      Quite a lot. Is there a Makerspace or Hackspace near you?
      ok so I'm missing the M950 in there for heater 1.
      It should be:
      M950 H1 C"out1" T1
      in there between the M308 and M143 ?
      Yes, and move the M307 command to be after the M950 command too.
      It can be helpful to run M98 P"config.g" from the console to see if there are any error messages.
      • oryharaundefined
        oryhara @oryhara
        My M950 is not working because I don't know the right name of the e0 heater pin.
        10:50:47 AMM950 H1 C"e0" T1
        Error: Unknown pin name 'e0'
        10:50:43 AMM950 H1 C"e0 heater" T1
        Error: Unknown pin name 'e0heater'
        10:49:53 AMM950 H1 C"heatere0" T1
        Error: Unknown pin name 'heatere0'
        10:49:48 AMM950 H1 C"heater" T1
        Error: Unknown pin name 'heater'
        10:49:44 AMM950 H1 C"heater0" T1
        Error: Unknown pin name 'heater0'
        10:49:25 AMM950 H1 C"out0" T1
        Error: Unknown pin name 'out0'
        10:49:10 AMM950 H1 C"e0heater" T1
        10:49:03 AMM950 H1 C"e0-" T1
        10:48:56 AMM950 H1 C"e0" T1
        10:48:44 AMM950 H1 C"h1" T1
        Error: Unknown pin name 'h1'
        10:48:40 AMM950 H1 C"heater1" T1
        Error: Unknown pin name 'heater1'
        10:48:35 AMM950 H1 C"out1" T1
        Error: Unknown pin name 'out1'
        10:48:05 AMM950 H1
        Error: Heater 1 does not exist
        blog: https://deltahedron.net
          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_Maestro
          oryharaundefined 1 Reply Last reply Reply Quote 0
          • oryharaundefined
            oryhara @dc42
            thank you. I swear i searched for that.
            Per that list, it should be "out1" yes?
            that did not work. that was the example in the documentation for m950, so i tried it first.
            • oryharaundefined
              oryhara
              I see my mistake.
              it should be: !e0heat
              • oryharaundefined
                oryhara
                Got the extruder heater working, but my temp sensor readings are wonky. It thinks its a 450* C
                  What type of temperature sensor are you using?
                  • oryharaundefined
                    oryhara
                    A thermistor.
                    I checked and it actually was at 450C
                    I guess the hotend heater was turned on this whole time i've been trying to sort it out. or something.
                    I should have smelled it sooner.
                    • oryharaundefined
                      oryhara
                      There is an error about heater 1 being overpowered. It came up when I did the PID tune.
                      • oryharaundefined
                        oryhara
                        ok. I got most of it working. Fan 2 acts as Fan0(part cooling fan), and the bed and extruder heater operate as expected.
                        Except: G30 tries to do manual bed probing. I'm guessing that my Z-probe was not set up properly. Back to the config.g for me.
                        In case anyone is following:
                        ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
                        ; Delta Settings
                        M665 L440.440 R226.821 H420 B185.0 X0 y0 z0 ; Set delta radius, diagonal rod length, printable radius and homed height
                        M666 X0 y0 z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
                        M550 P"Predator" ; Set machine name
                        M551 P"" ; Set password
                        M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                        M586 P0 S1 ; Enable HTTP
                        M586 P1 S0 ; Disable FTP
                        M586 P2 S0 ; Disable Telnet
                        M569 P0 S0 ; Drive 0 goes forwards
                        M569 P1 S0 ; Drive 1 goes forwards
                        M569 P2 S0 ; Drive 2 goes forwards
                        M569 P3 S0 ; Drive 3 goes forwards - extruder
                        M92 X80.00 Y80.00 Z80.00 E415 ; Set steps per mm
                        M566 X3000 Y3000 Z3000 E3000 ; Set maximum instantaneous speed changes (mm/min)
                        M203 X12000.00 Y12000.00 Z12000.00 E12000 ; Set maximum speeds (mm/min)
                        M201 X9000.00 Y9000.00 Z9000.00 E6000.00 ; Set accelerations (mm/s^2)
                        M906 X1800.00 Y1800.00 Z1800.00 E900.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        ; Retraction
                        M207 S1.85 F7000 R0 T2500 Z0.5 ; Firmware retraction
                        M208 Z-1 S1 ; Set minimum Z
                        M574 X2 Y2 Z2 S1 ; Set active high endstops
                        M558 P8 R0.4 F1200 H2 T5000 ; Set Z probe type to switch and the dive height + speeds
                        G31 P100 X0 Y0 Z-.1 ; Set Z probe trigger value, offset and trigger height
                        M557 R175 S20 ; Define mesh grid
                        M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
                        M308 S0 P"bedtemp" Y"thermistor" F0 T100000 B4300 C0 R2200 ; Set thermistor + ADC parameters for heater 0
                        M950 H0 C"bedheat" T0
                        M308 S1 P"e0_temp" Y"thermistor" F0 T100000 B4725 C7.06e-8 ; Set thermistor + ADC parameters for heater 1
                        M950 H1 C"e0heat" T1 ; Define Heater 1
                        M143 H1 S290 ; Set temperature limit for heater 1 to 240C
                        M307 H2 A-1 C-1 D-1 ; Disconnect H2 from being a heater - LED
                        M950 F2 C"nil"
                        M950 F0 C"fan2" ;set fan B as fan 0
                        ;M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        M106 P1 T30 H100:101:102 ;sets up an electronics cooling fan that starts to turn on when the MCU temperature (virtual heater 100) reaches 45C and reaches full speed when the MCU temperature reaches 65C or if any TMC2660 drivers (virtual heaters 101 and 102) report that they are over-temperature
                        M563 P0 D0 H1 ; Define tool 0
                        M591 D0 P2 C4 S0 ; Activate filament sensor
                        M404 N1.75 ; Set for print monitor
                        M592 D0 A0.011806 B0.0026876 ; Nonlinear extrusion. Set parameters for extruder drive 0 - 0.4mm
                        M575 P1 B57600 S1
                        M501 ; Load saved parameters from non-volatile memory
                        ; Delta parameters
                        M665 L440.440 R220.804 H410.714 B185.0 X-0.174 Y-0.027 Z0.000
                        M666 X-0.368 Y-0.441 Z0.809 A0.00 B0.00
                        ; Heater model parameters
                        M307 H0 A137.8 C533.3 D1.5 S1.00 V24.3 B0
                        M307 H1 A799.6 C271.4 D4.4 S1.00 V24.0 B0
                        G10 L2 P1 X0.00 Y0.00 Z0.00
                        G10 L2 P2 X0.00 Y0.00 Z0.00
                        G10 L2 P3 X0.00 Y0.00 Z0.00
                        G10 L2 P4 X0.00 Y0.00 Z0.00
                        G10 L2 P5 X0.00 Y0.00 Z0.00
                        G10 L2 P6 X0.00 Y0.00 Z0.00
                        G10 L2 P7 X0.00 Y0.00 Z0.00
                        G10 L2 P8 X0.00 Y0.00 Z0.00
                        G10 L2 P9 X0.00 Y0.00 Z0.00
                          You haven't defined the Z probe input pin. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M558. For a Smart Effector on a Duet Maestro, use C"zprobe.in+zprobe.mod".
                          • oryharaundefined
                            oryhara
                            yep. that did it. thank you.
                            • oryharaundefined
                              oryhara
                              regarding the fan mosfet, I reached out to filastruder(where I bought my maestro) about an RMA and they said that unless you or another duet admin authorizes the warranty repair, it's a no-go.
                              I have my fan2 workaround functioning, so just how "not ideal" is it to have the hotend fan always-on and the print fan running from Fan 2?
                              • oryharaundefined
                                oryhara
                                so i'm getting warnings from my MCU that its at 46-47 degrees. I know 45 is the cutoff, but its holding stable just a few degrees above that.
                                I'm concerned that my fan A mosfet may be even less functional, since that is what is running the MCU fan.
                                Its on the Fan 1 output. I have it set to turn on if the MCU is above 30(despite the comments in my gcode above), and without the proportionaly control.
                                Is there a way to test the speed of a 2-wire fan?
                                or can i drive a fan from something else like one of the expansions slots or the second heater? E1, that is.
                                • oryharaundefined
                                  oryhara
                                  At the risk of dredging up a dead thread, i want to give one last update.
                                  I didn't calibrate the MCU temperature sensor, so i'm going to do that and it should fix the issue i mentioned in my previous post.
                                    Re the blown fan MOSFET, it's likely that when the fan wire came loose from the connector, it shorted to something else, and that blew the MOSFET. I'm sorry, this sort of thing isn't covered by the warranty. However, Filastuder may be able to put you in touch with our stateside Duet repairer, if you haven't a local hackspace or makerspace where you can get it done. Or you could watch https://youtu.be/LADgxZgyJ04, practice on an old hard disk drive, and if that gives you enough confidence then do it yourself. If you can remove the blown MOSFET without lifting the traces, fitting the new one is easy.
                                    Re CPU temperature, 45C is not unusual. The CPU will function up to at least 85C die temperature.
                                    HTH David
                                    • oryharaundefined
                                      oryhara
                                      thank you. It's worth asking i suppose. I'll stick with the workaround I've found. I rather like the effector lights always on.
                                      My MCU was reading 6 degrees too high, based on the 'calibrate MCU temp' procedure which I executed this morning. Given that it was hovering at 47 during a print before that calibration, it should stay well below the warning threshold now.
                                        Is the warning coming from Duet Web Control, or somewhere else? 45C is too low for a MCU temperature warning threshold.
                                        • oryharaundefined
                                          oryhara
                                          It was high temperature on drivers. usually 0 and 1.
                                          I see it in gcode console and a popup on web control and the panelDue.
                                          I thought the warning started at 45 and then they stopped at 65, is that not correct?
                                            The drivers warn of over temperature when their temperatures exceed about 100C according to the on-chip sensor. That warning is not related to MCU temperature, except that when the drivers are generating a lot of heat, some of this will feed through to the MCU.
