    Nozzle gets smashed against the bed
    Other control boards
    2.6k
    • MJCTundefined
      MJCT @Phaedrux
      @Phaedrux
      I tried to use the formula when I was using the config tool, but that value was provided by the manufacturer. But I will double cheek it tomorrow
        Who is the manufacturer? What type of printer is this?
        MJCTundefined 1 Reply Last reply Reply Quote 0
        • MJCTundefined
          MJCT @Phaedrux
          @Phaedrux
          @Phaedrux said in Nozzle gets smashed against the bed:
          More on that tomorrow, I prefer to confirm first everything I say about a company on the web. It would be terribly unfair for them if I was making some kind of confusion.
          The printer is a core XY based on V rails
          • fcwiltundefined
            fcwilt @Phaedrux
            @MJCT said in Nozzle gets smashed against the bed:
            M92 X80.00 Y80.00 Z4000.00 E96.94 ; set steps per mm
            Z steps per mm of 4000 doesn't sound correct.
            Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
            That does not sound right. For a typical 8mm lead and 1.8 steppers the steps/mm would be 400. 4000 would mean a 0.8mm lead which doesn't seem likely.
            • Vetiundefined
              Veti
              4000 is the default value in the configurator.
              this value was used for one the first 3d printers which used m5 threaded rods.
              here is a picture of the ones used some time ago.
              https://www.instructables.com/id/3D-Printer-Lead-Screw-Upgrade/
              most modern 3d printers now use a 4 start lead screw with a 8mm pitch which results in 400 steps per mm.
              if your printer really has one of the old ones, you should swap that out before you do any prints, as it will result it very poor prints.
              • Vetiundefined
                Veti
                also you have a beta value of 4138. this is also the defaults and most likely wrong for your thermistor.
                you need to find the correct value, otherwise you are printing at the wrong temperature.
                • MJCTundefined
                  MJCT @Phaedrux
                  Somehow, in the middle of all this crisis 400 sp mm transformed in 4000 sp mm. ~
                  The company information was : 1.8 deg (200 steps per rev), Leadscrew, Custom, Pitch 8, Gear ratio 1:1 and finally 400.00 microsteping.
                  When I was using the config tool I’m sure I’ve inputted 400.00, but instead of just clicking with the mouse at another area I probably pressed “Set”, and that reverts the value to the predefined 4000.00.
                  Lousy mistake that costed me dozens of hours and a lot of patience to all of us.
                  That’s why the G30 S-1 was returning values like 0.22... instead of 2.2... It was literally messing everything in the Z axis, tenfold.
                  Its now printing a test cub
                  • MJCTundefined
                    MJCT @Veti
                    @Veti
                    @Veti said in Nozzle gets smashed against the bed:
                    Yes, next step
                      jay_s_uk @MJCT
                      @MJCT
                      We'll get you sorted
                      • MJCTundefined
                        MJCT
                        The test cub printed just fine for a first print.
                        Once again, thank you all for your help.
                        • fcwiltundefined
                          fcwilt @MJCT
                          Glad you got it working.
                          Remember in the future that one of the tests you should make is to use the DWC to jog the axes a known amount and verify with a measuring device that the movement was correct.
                          • MJCTundefined
                            MJCT @fcwilt
                            @fcwilt
                            Iep I understand that, and I did it, but because de dashboard buttons don’t indicate units, they just say "Z-5" for example, I made the mistake.
                            When that button was pressed, the Z axis moved exactly 5 cm which I confirmed as accurate with a tool (not 5mm as it should). But I was so angry and confused that I didn’t notice that the behaviour of the X and Y axis was different. For those the equivalent button only moved 5mm.
