    True Bed Leveling - G32 w/Dual Z in Series
    • supernovaeundefined
      supernovae
      HyperCube EVO
      Dual Z - Connected to driver 2 in series (A/B)
      M584 X0 Y1 Z2 E3
      Does G32 "True bed leveling" work when in series or do I have to connect my dual z to 2 and 4 for it to be able to level the bed???
      • fcwiltundefined
        fcwilt
        You have to connect each stepper to a separate driver, something like Z2:4
          droftarts administrators
          @supernovae See https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
            supernovae
            thanks all! got it all figured out. It didn't click that i had it wired in a series with the 2 A:B setup... I put them on 2:4 and i have auto leveling perfection finally! 🙂 so happy since i'd just done a bunch of motor swaps and new plum connectors for the z rods so it was super easy to get level after fixing this!
