Send gcode via ESP32 to Duet wifi.
there are examples in the arduino ide even
https://github.com/espressif/arduino-esp32/blob/master/libraries/WiFi/examples/WiFiClientBasic/WiFiClientBasic.ino -
Ohh I know how to make http POST/GET requests with the wifi.h. But how do i channel it to the duet wifi? Do i have to type in the IP-Address of the Duet wifi as the destination for the http request?!?
Use the IP address of the Duet.
But instead of HTTP requests you can enable telnet and connect to the telnet port and send GCODE directly instead of dealing with the DWC API
i just want a simple led to turn on, when i press a button on the esp32... and it has to be via wlan
in that case the easiest is probably to stick with HTTP towards the IP of your Duet.
first you'll need to set up means to turn your led on and off; by means of a fan output
M106
or a gpioM42
(<- click links to learn more)Then simply sent the HTTP request to run the GCODE needed to turn the LED on.
to use Fan2 output
client.print("GET /rr_gcode?gcode=M106%20P2%20S1 HTTP/1.0\n\n");
or to use M42 with the same Fan2 outut (but not as a fan)
client.print("GET /rr_gcode?gcode=M42%20P22%20S1 HTTP/1.0\n\n");
Thank you very much!!!!
simple ESP32 code to send g-code to duet
#include <WiFi.h> #include <WiFiClient.h> #include <ESPmDNS.h> const int led = 5; const char* ssid = "ccc"; const char* password = "pass"; //const char* host = "192.168.1.115"; const char* host = "ender5.local.lan"; const int port = 23; int l = 0; int potValue = 0; WiFiClient client; int sendGcode(char * gcode){ unsigned long timeout; int ret; ret = 1; client.print( String(gcode) + "\r\n" ); timeout = millis(); while (client.available() == 0) { if (millis() - timeout > 5000) break; } while(client.available()) { String line = client.readStringUntil('\r'); Serial.print(line); if (line.startsWith("ok")) ret = 0; if (line.startsWith("\nok")) ret = 0; if (line.startsWith("\r\nok")) ret = 0; } return(ret); } void setup() { pinMode(led, OUTPUT); digitalWrite(led, 0); Serial.begin(115200); delay(10); Serial.print("Connecting to "); Serial.println(ssid); WiFi.config(INADDR_NONE, INADDR_NONE, INADDR_NONE); WiFi.mode(WIFI_AP); if (MDNS.begin("pendantDue")) { Serial.println("MDNS responder started"); } WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println("WiFi connected"); Serial.print("IP address: "); Serial.println(WiFi.localIP()); delay(1000); Serial.print("connecting to "); Serial.print(host); Serial.print(":"); Serial.println(port); if (!client.connect(host, port)) { Serial.println("connection failed"); while(1){ digitalWrite(led, 0); delay(500); digitalWrite(led, 1); delay(500); } return; } Serial.print("CONNECTED to "); Serial.print(host); Serial.print(":"); Serial.println(port); } void loop() { delay(5000); sendGcode("M115"); }
@smece thx a lot.. that really saves me from wandering through github and places in the internet where my mind is not suited for. ^^ (smece-- funny name. means garbage in croatian language)
@flipil said in Send gcode via ESP32 to Duet wifi.:
znaΔi i kod nas na istoku
you are welcome, I started making a pendant for duet with esp32 so that's the initial test how to talk to it
note that if you don't close the connection
client.stop();
it can "block" as it looks like duet is listening only with one or two threads ... you might want to change to open connection to send gcode and immediately close if you don't plan to send many commads -
Hvala ti puno smece
spasio si mi zivot.
@bearer said in Send gcode via ESP32 to Duet wifi.:
Just note for the future: Telnet is going away in Duet/RepRap V3 firmware.
For that matter, so are RR_whatever HTTP calls. Moving to websocket.
@Danal said in Send gcode via ESP32 to Duet wifi.:
WHY oh WHY ?!
adding websocket is ok, but removing telnet ?!?!?! why ?
That was pretty much my question to DC42. Perhaps if we both asked nicely, he'd reconsider.
@Danal @smece on Duet 3 you have all the connection options of whatever SBC you use. So SSH into it if you wish.
@T3P3Tony said in Send gcode via ESP32 to Duet wifi.:
so telnet is not going away?
@smece said in Send gcode via ESP32 to Duet wifi.:
with respect to Duet 3 + SBC telnet is already gone, unless you cobble together something like socat and the command line client
dunno what's SBC but I'm running RRF3 on Duet2Eth and telnet is still here
Duet 3 as in 3rd generation hardware not firmware, and SBC refers to a single board computer like the raspberry pi.
Yes, of course, but it's firmware that's handling telnet server, and I find it weird that same version RRF3 for duet3 and duet2 is different in that regard.
thanks
the difference is when used with the single board computer the Duet doesn't use the ethernet interface, only SPI; ergo Telnet is not an option any more as its not supportd by the software package for the SBC.
(although i havent tested it in stand alone operation if it still support telnet)
makes sense to disable ETH if the communication is moved to SBC .. but then you can telnet to SBC so it's still available
