Help! DWC Disconnects and Drops after extensive troubleshooting
Duet Web Control
1.7k
    alexd607 @Danal
    @Danal
    It does not timeout, and it still pings without any loss.
    Printer:
    Hypercube Evolution 445, custom built.
      alexd607 @dc42
      I was able to get momentarily connected and run M122 right after power-up, here's the result:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3S0-7J1F6-3S06T-9A43F
      Used output buffers: 3 of 24 (18 max)
      Static ram: 25680
      Dynamic ram: 92808 of which 356 recycled
      Exception stack ram used: 268
      Never used ram: 11960
      Tasks: NETWORK(ready,676) HEAT(blocked,1232) MAIN(running,3808) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:00:44 ago, cause: power up
      Last software reset at 2019-12-04 09:23, reason: Heat task stuck, spinning module FilamentSensors, available RAM 11568 bytes (slot 1)
      Software reset code 0x40ad HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20004a9c Task 0x4e49414d
      Stack: 0044d38f 004451d6 6100f000 3f000000 00000000 00000000 00000000 3331bb4c 41880000 3e178897 3e1cd04f be09b238 3e3a3fd4 00000000 00000000 00000000 3f800000 3f800000 3f000000 20000010 20003258 20002b88 0044d38f
      Error status: 0
      Free file entries: 8
      MCU temperature: min 26.5, current 26.8, max 27.0
      Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2019-12-06 08:24:47
      Cache data hit count 157313766
      Slowest loop: 1.10ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Heater 2 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 201.19ms; fastest: 0.08ms
      Responder states: HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        Failed messages: pending 0, notready 0, noresp 1
        WiFi firmware version 1.23
        WiFi MAC address 84:f3:eb:83:48:e5
        WiFi Vcc 3.39, reset reason Power on
        WiFi flash size 4194304, free heap 16832
        WiFi IP address 192.168.1.151
        WiFi signal strength -21dBm, reconnections 0, sleep mode modem
        Socket states: 2 2 0 0 0 0 0 0
      Printer:
      undefined 1 Reply Last reply 8 Dec 2019, 00:17 Reply Quote 0
        Danal
        If it pings, you have a solid network connection and we can quit looking at the basic networking stuff.
        Were it me, I'd rebuild the www directory on the SD card.
        And/or, as a test, you can put your own "test.html" page on the www directory, and test via:
        http://(ip of printer)/test.html
        undefined 1 Reply Last reply 9 Dec 2019, 19:01 Reply Quote 0
          droftarts administrators @alexd607
          @alexd607 said in Help! DWC Disconnects and Drops after extensive troubleshooting:
          Error status: 0
          @dc42 Same error again
          undefined 1 Reply Last reply 11 Dec 2019, 14:18 Reply Quote 0
            alexd607 @Danal
            @Danal
            I've tried rebuilding the www folder already, as well as every other folder. I've tried rolling back to older firmware, and I've tried reloading the most recent full releases. All had the same result, no luck.
            Printer:
              Danal
              If it pings, you can get packets to/from. That means WiFi is working, fundamental packet routing, etc. If it does not show a web page, that means something is broken in the HTTP layer, or web server, or content.
              To help decide which try putting:
              <html>
              <head>
              <title>Test Title</title>
              </head>
              <body>
              Test Body
              </body>
              </html>
              In /www/test.html
              Then use a browser to attempt to load http://(ip of printer)/test.html
              What happens?
              undefined 1 Reply Last reply 11 Dec 2019, 14:12 Reply Quote 0
                alexd607 @Danal
                @Danal
                I'll give this a try this evening and report back.
                Printer:
                  droftarts administrators @droftarts
                  Error status: 0
                    Please try firmware 2.05RC2 in case this issue is related to a USB output issue in previous releases.
                    undefined 1 Reply Last reply 13 Dec 2019, 15:19 Reply Quote 0
                      alexd607 @dc42
                      Tried upgrading to firmware 2.05RC2. No change.
                      Printer:
                      38 out of 38
