    Help! DWC Disconnects and Drops after extensive troubleshooting
    Duet Web Control
    1.7k
    • Danalundefined
      Danal
      Strictly for troubleshooting, have you considered putting the printer in Access Point mode?
      Then testing with a phone or tablet or laptop a few feet from the printer, then further away, etc. Then with the mobile device in the next room... then near the router... etc, etc. A demonstrable "map" of connectivity.
      This type of testing removes your home network from the picture. Once you've verified that the DWC is (or is not!!!) stable from various distances when the link is direct printer<>device, you can go back to making it reliable on your home network, with some data points in your mind about the printer's basic physical capability to wirelessly reach various places in your home.
      • alexd607undefined
        alexd607
        @Danal
        I attempted access point mode already with no success. It's not a matter of physical distance for sure, as my printer is literally adjacent to my wifi modem with no barriers between them.
        Printer:
        Hypercube Evolution 445, custom built.
        • Danalundefined
          Danal
          Edit: Wrong thread. What I meant to say here:
          If AP mode is unstable, it is guaranteed that everything else will be unstable. Go back to AP mode, thus eliminating a whole bunch of variables, and debug from there.
            droftarts administrators
            Probably minor, but you have M587 in your config.g. You should comment this out or delete. From the Gcode dictionary:
            Important! Do not use M587 within config.g. As well as being a security hazard, writing the access point parameters to WiFi chip every time you start the Duet may eventually wear out the flash memory. Also, the wifi module does not get enabled until the end of running config.g. It is better to use a macro to send M587 (source: https://forum.duet3d.com/post/42798)
            • alexd607undefined
              alexd607
              Well...it has officially quit working completely...
              When I try to access the DWC I'm met with a blank white screen that never populates...
              @dc42 would doing a hard firmware reset be a possible solution?
              Printer:
              • Danalundefined
                Danal @alexd607
                @alexd607 said in Help! DWC Disconnects and Drops after extensive troubleshooting:
                Does it time out?
                Can you ping it?
                alexd607undefined 1 Reply Last reply Reply Quote 0
                  dc42 administrators @alexd607
                  @droftarts
                  I don't have a filament sensor or panel due fitted.
                  It's strange that that is what it's reporting considering the last reset was done by me via M112.
                  Please run another M122 report after the network has disconnected, without doing any emergency stops. I want to see if the "Heat task stuck" report is a recurring thing, or if it is a consequence of the emergency stop.
                  • alexd607undefined
                    alexd607 @Danal
                    @Danal
                    It does not timeout, and it still pings without any loss.
                    Printer:
                    • alexd607undefined
                      alexd607 @dc42
                      I was able to get momentarily connected and run M122 right after power-up, here's the result:
                      M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
                      Board ID: 08DGM-9T6BU-FG3S0-7J1F6-3S06T-9A43F
                      Used output buffers: 3 of 24 (18 max)
                      Static ram: 25680
                      Dynamic ram: 92808 of which 356 recycled
                      Exception stack ram used: 268
                      Never used ram: 11960
                      Tasks: NETWORK(ready,676) HEAT(blocked,1232) MAIN(running,3808) IDLE(ready,200)
                      Owned mutexes:
                      Last reset 00:00:44 ago, cause: power up
                      Last software reset at 2019-12-04 09:23, reason: Heat task stuck, spinning module FilamentSensors, available RAM 11568 bytes (slot 1)
                      Software reset code 0x40ad HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20004a9c Task 0x4e49414d
                      Stack: 0044d38f 004451d6 6100f000 3f000000 00000000 00000000 00000000 3331bb4c 41880000 3e178897 3e1cd04f be09b238 3e3a3fd4 00000000 00000000 00000000 3f800000 3f800000 3f000000 20000010 20003258 20002b88 0044d38f
                      Error status: 0
                      Free file entries: 8
                      MCU temperature: min 26.5, current 26.8, max 27.0
                      Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                      Date/time: 2019-12-06 08:24:47
                      Cache data hit count 157313766
                      Slowest loop: 1.10ms; fastest: 0.07ms
                      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                      === DDARing ===
                      Heater 2 is on, I-accum = 0.0
                      Segments left: 0
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is idle in state(s) 0
                      serial is idle in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 201.19ms; fastest: 0.08ms
                      Responder states: HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                      HTTP sessions: 1 of 8
                      • WiFi -
                        Network state is running
                        Failed messages: pending 0, notready 0, noresp 1
                        WiFi firmware version 1.23
                        WiFi MAC address 84:f3:eb:83:48:e5
                        WiFi Vcc 3.39, reset reason Power on
                        WiFi flash size 4194304, free heap 16832
                        WiFi IP address 192.168.1.151
                        WiFi signal strength -21dBm, reconnections 0, sleep mode modem
                        Socket states: 2 2 0 0 0 0 0 0
                      Printer:
                      • Danalundefined
                        Danal
                        If it pings, you have a solid network connection and we can quit looking at the basic networking stuff.
                        Were it me, I'd rebuild the www directory on the SD card.
                        And/or, as a test, you can put your own "test.html" page on the www directory, and test via:
                        http://(ip of printer)/test.html
                          droftarts administrators @alexd607
                          Error status: 0
                          @dc42 Same error again
                          • alexd607undefined
                            alexd607 @Danal
                            @Danal
                            I've tried rebuilding the www folder already, as well as every other folder. I've tried rolling back to older firmware, and I've tried reloading the most recent full releases. All had the same result, no luck.
                            Printer:
                            • Danalundefined
                              Danal
                              If it pings, you can get packets to/from. That means WiFi is working, fundamental packet routing, etc. If it does not show a web page, that means something is broken in the HTTP layer, or web server, or content.
                              To help decide which try putting:
                              <html>
                              <head>
                              <title>Test Title</title>
                              </head>
                              <body>
                              Test Body
                              </body>
                              </html>
                              In /www/test.html
                              Then use a browser to attempt to load http://(ip of printer)/test.html
                              What happens?
                              • alexd607undefined
                                alexd607 @Danal
                                @Danal
                                I'll give this a try this evening and report back.
                                Printer:
                                  droftarts administrators @droftarts
                                  Error status: 0
                                    Please try firmware 2.05RC2 in case this issue is related to a USB output issue in previous releases.
                                    • alexd607undefined
                                      alexd607 @dc42
                                      Tried upgrading to firmware 2.05RC2. No change.
                                      Printer:
