Help! DWC Disconnects and Drops after extensive troubleshooting
Well...it has officially quit working completely...
When I try to access the DWC I'm met with a blank white screen that never populates...
@dc42 would doing a hard firmware reset be a possible solution?
@alexd607 said in Help! DWC Disconnects and Drops after extensive troubleshooting:
Does it time out?
Can you ping it?
I don't have a filament sensor or panel due fitted.
It's strange that that is what it's reporting considering the last reset was done by me via M112.
Please run another M122 report after the network has disconnected, without doing any emergency stops. I want to see if the "Heat task stuck" report is a recurring thing, or if it is a consequence of the emergency stop.
It does not timeout, and it still pings without any loss.
I was able to get momentarily connected and run M122 right after power-up, here's the result:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3S0-7J1F6-3S06T-9A43F
Used output buffers: 3 of 24 (18 max)
Static ram: 25680
Dynamic ram: 92808 of which 356 recycled
Exception stack ram used: 268
Never used ram: 11960
Tasks: NETWORK(ready,676) HEAT(blocked,1232) MAIN(running,3808) IDLE(ready,200)
Owned mutexes:
Last reset 00:00:44 ago, cause: power up
Last software reset at 2019-12-04 09:23, reason: Heat task stuck, spinning module FilamentSensors, available RAM 11568 bytes (slot 1)
Software reset code 0x40ad HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20004a9c Task 0x4e49414d
Stack: 0044d38f 004451d6 6100f000 3f000000 00000000 00000000 00000000 3331bb4c 41880000 3e178897 3e1cd04f be09b238 3e3a3fd4 00000000 00000000 00000000 3f800000 3f800000 3f000000 20000010 20003258 20002b88 0044d38f
Error status: 0
Free file entries: 8
MCU temperature: min 26.5, current 26.8, max 27.0
Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2019-12-06 08:24:47
Cache data hit count 157313766
Slowest loop: 1.10ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Heater 2 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 201.19ms; fastest: 0.08ms
Responder states: HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 1 of 8- WiFi -
Network state is running
Failed messages: pending 0, notready 0, noresp 1
WiFi firmware version 1.23
WiFi MAC address 84:f3:eb:83:48:e5
WiFi Vcc 3.39, reset reason Power on
WiFi flash size 4194304, free heap 16832
WiFi IP address 192.168.1.151
WiFi signal strength -21dBm, reconnections 0, sleep mode modem
Socket states: 2 2 0 0 0 0 0 0
- WiFi -
If it pings, you have a solid network connection and we can quit looking at the basic networking stuff.
Were it me, I'd rebuild the www directory on the SD card.
And/or, as a test, you can put your own "test.html" page on the www directory, and test via:
http://(ip of printer)/test.html
Error status: 0@dc42 Same error again
I've tried rebuilding the www folder already, as well as every other folder. I've tried rolling back to older firmware, and I've tried reloading the most recent full releases. All had the same result, no luck.
If it pings, you can get packets to/from. That means WiFi is working, fundamental packet routing, etc. If it does not show a web page, that means something is broken in the HTTP layer, or web server, or content.
To help decide which try putting:
<html> <head> <title>Test Title</title> </head> <body> Test Body </body> </html>
In /www/test.html
Then use a browser to attempt to load http://(ip of printer)/test.html
What happens?
I'll give this a try this evening and report back.
Please try firmware 2.05RC2 in case this issue is related to a USB output issue in previous releases.
Tried upgrading to firmware 2.05RC2. No change.
