    Fourth Extruder not working on latest RRF3
    Beta Firmware
    807
      dc42 administrators @smoki3
      @smoki3 said in Fourth Extruder not working on latest RRF3:
      @dc42 said in Fourth Extruder not working on latest RRF3:
      M584 X0 Y1 Z2 E6:3:4:5 U7
      Tested: no this does not change anything. Still extruder four is not working.
      Do you mean extruder 3, connected to driver 5?
      smoki3undefined 1 Reply Last reply Reply Quote 0
      • smoki3undefined
        smoki3 @dc42
        Sorry yes my mistake.
        The extruder which is connected to driver 6 is working then. And driver 5 is dead
          Thanks, so it's connected with extruder numbers, not driver numbers.
          • smoki3undefined
            smoki3 @dc42
            yes can confirm that
              Some observations about your config.g (not connected with the problem AFAIK):
              • You should remove the M587 command
              • You could replace these lines:
              M950 H3 C"!exp.heater3" T3
              M950 H4 C"!exp.heater4" T4
              by:
              M950 H3 C"duex.e2heat" T3
              M950 H4 C"duex.e3heat" T4
              which may be clearer.
              • smoki3undefined
                smoki3 @dc42
                Regarding the M587: do you mean to remove it in forum posts or in my config?
                Is it not needed to connect to my wifi
                  From your config. You only need to send it once, the details are stored in the WiFi module.
                    This is now fixed. Source files have been committed, and new binaries are in the same place as before. Thanks for reporting it.
                    smoki3undefined 2 Replies Last reply Reply Quote 0
                    • smoki3undefined
                      smoki3 @dc42
                      No problem!
                      Tested! Now it's working again thanks!
                      • smoki3undefined
                        smoki3 @dc42
                        I noticed that there is still something wrong. The 4 extruder is now active but it moves now simultaneous with every single axis movement.
                        Means when I move 100mm in Y axis it also extrudes 100mm, if I move -100mm in Y it retracts 100mm. And this also happens when I move in X and Z axis. Really wired behavior.
                        Just happens on the 4th extruder again. Looks like the driver 6 is know linked to all other axes
                          Is that with the binary on dropbox that I linked to?
                          PS:
                          1. I can't reproduce that issue with the binary I built last night.
                          2. What mapping does M584 report?
                          • smoki3undefined
                            smoki3 @dc42
                            PS:
                            Yes also happens with the binary from the dropbox
                            M584
                            Driver assignments: X0 Y1 Z2 U7 E3:4:5:6, 4 axes visible
                            here everything looks fine.
                            Also DWC shows me that the extruder is moving when I move any axes.
                            this happens if i press +10mm Y:
                            https://photos.app.goo.gl/nCAdJE6pLJwjva3g8
                            • smoki3undefined
                              smoki3 @dc42
                              PS:
                              I also have tried now M584 X0 Y1 Z2 E6:4:5:3 U7
                              then driver 3 is running in sync with the axis. So looks like it is also not related to the driver.
                              Steps to reproduce:
                              1. Select a tool
                              2. wait for heating up
                              3. extrude a few mm manually
                              4. the move the axis
                              On beta12 still every thing is fine with same configs
                                I've just fixed this - new binary in same place as before.
                                • smoki3undefined
                                  smoki3 @dc42
                                  Tested with the dropbox binary. Now it's working. Thanks
