    Fourth Extruder not working on latest RRF3
    Beta Firmware
    838
    • smoki3undefined
      smoki3 @dc42
      Regarding the M587: do you mean to remove it in forum posts or in my config?
      Is it not needed to connect to my wifi
        dc42 administrators @smoki3
        @smoki3 said in Fourth Extruder not working on latest RRF3:
        From your config. You only need to send it once, the details are stored in the WiFi module.
          This is now fixed. Source files have been committed, and new binaries are in the same place as before. Thanks for reporting it.
          smoki3undefined 2 Replies Last reply Reply Quote 0
          • smoki3undefined
            smoki3 @dc42
            @dc42 said in Fourth Extruder not working on latest RRF3:
            No problem!
            Tested! Now it's working again thanks!
            • smoki3undefined
              smoki3 @dc42
              I noticed that there is still something wrong. The 4 extruder is now active but it moves now simultaneous with every single axis movement.
              Means when I move 100mm in Y axis it also extrudes 100mm, if I move -100mm in Y it retracts 100mm. And this also happens when I move in X and Z axis. Really wired behavior.
              Just happens on the 4th extruder again. Looks like the driver 6 is know linked to all other axes
                Is that with the binary on dropbox that I linked to?
                PS:
                1. I can't reproduce that issue with the binary I built last night.
                2. What mapping does M584 report?
                • smoki3undefined
                  smoki3 @dc42
                  PS:
                  Yes also happens with the binary from the dropbox
                  M584
                  Driver assignments: X0 Y1 Z2 U7 E3:4:5:6, 4 axes visible
                  here everything looks fine.
                  Also DWC shows me that the extruder is moving when I move any axes.
                  this happens if i press +10mm Y:
                  https://photos.app.goo.gl/nCAdJE6pLJwjva3g8
                  • smoki3undefined
                    smoki3 @dc42
                    PS:
                    I also have tried now M584 X0 Y1 Z2 E6:4:5:3 U7
                    then driver 3 is running in sync with the axis. So looks like it is also not related to the driver.
                    Steps to reproduce:
                    1. Select a tool
                    2. wait for heating up
                    3. extrude a few mm manually
                    4. the move the axis
                    On beta12 still every thing is fine with same configs
                      I've just fixed this - new binary in same place as before.
                      smoki3undefined 1 Reply Last reply Reply Quote 0
                      • smoki3undefined
                        smoki3 @dc42
                        Tested with the dropbox binary. Now it's working. Thanks
