Tool Change: Moving in axis without calling them
So tested it again now. It happens exactly the same as you can see on post 25.
If I move the whole tpre script to the tpost and add G53 in front of every G1 then it works fine.
The problem is: The not called axes are moving exactly the distance of the tool offset from the cleared tool instead of just update the coordinates for the not called axes and just move the called axis.
There were the changes in 2.03:
May 25th:
- Restore points (created by G60 and created automatically at the start of a pause or a tool change) now have their coordinates stored independently of any workplace offsets. So if you create a restore point and then change the workplace offsets, when you go back to the restore point it will go back to the same machine position regardless of the change in workplace offsets.
and this March 3rd:
-- Tool changers, IDEX printers and similar using tpre#.g and tpost#.g files: tool offsets are now applied within the tpre#.g and tpost#.g macros.
I assume that one of these leads to the bug.
@smoki3 said in Tool Change: Moving in axis without calling them:
Is that with the RRF3 binary that I linked to, with build date yesterday?
This post is deleted! -
@dc42 said in Tool Change: Moving in axis without calling them:
Yes, downloaded it today and tested it 10 mins ago.
Build:
RepRapFirmware for Duet 2 WiFi/Ethernet 3.0RC1 (2019-12-14b5) -
I am trying to get setup to test this with your exact files (except for absolute coordinates of the tool parking, of course).
More later today...
Running:
Board: Duet 3 MB6HC (MB6HC)
DSF Version: 1.1.0.5
Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12+1 (2019-12-02b2)I backed up all my pre/post/free files and copied yours in exactly. I set a Y tool1 offset of 25.
I do not see any diagonal moves occur. T0 T1, T0 T-1 T1, no sequence I've tried produces a diagonal move.
I DO see the final Y coordinate displayed in DWC for T1 jump from 100 to 125, when the T1 sequence ends.
@Danal said in Tool Change: Moving in axis without calling them:
Running:
You have to set the tool offset for T0. Best you try it to set the offset for both tool in all 3 axis. It's always from the tool which is clear.
I don't think the movement calculation is different for duet 3 and duet 2.
Here the issue exists and on all the tool changer videos on YouTube you see it as well (moving z axis after tfree)
I will give that a try. I'll just copy your tool offsets exactly.
OK, I have reproduced the diagonal move.
Interestingly enough, I then put messages (m117) and delays (G4) in the tpre1.g file... and the diagonal move WENT AWAY. Very, very, odd.
At this moment, I'm experimenting with delays and similar to find out exactly which command causes the diagonal move.
OK, to summarize: With exact copies of @smoki3 files, including the pre/post/free and the tool offset, the diagonal move is reproduced on my machine. Which is a CoreXY running:
Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12+1 (2019-12-02b2)With all XYZ on the main board, only tools on the expander boards.
Some experimentation also shows:
A delay, such as G4 S1, positioned before any other commands in tpre1.g, stops the diagonal.
An M400, positioned before any other commands in tpre1.g, stops the diagonal. Note that I removed all the other M400s.
G53 in front of all move commands in tpre1.g has no effect, the diagonal still occurs.
Given that this appears to be timing sensitive, it begins to make more sense why exact copies of the files are needed to reproduce.
Anyway, I hope this helps dc42 figure out what's going on.
Thanks for the nice analysis.
Good point with the timing. It also makes sense. I sure @dc42 will fix it. Maybe already for 3.0RC1
So I also tried a M400 in the first line of the tpre script. Then everything is fine
I also noticed that you have this diagonal movement when you dock your tool after the print. But as Danal mentioned it only happen if directly after the tfree script a G1 follows.
Thanks, from that I think I know what is going on, and I can fix it in 3.0 release.
Cool! So please also merge it to 2.xx
@smoki3, I have fixed this in the 3.0 stable release.
I am not planning to do any further 2.x releases, but you have an easy workaround (M400 at the start of the tpre and/or tpost file).
I see. Its working fine now.
For 2.x I don't use it. I just thought about all the tool changer users....
