    Tool Change: Moving in axis without calling them
    Beta Firmware
    2.2k
    • Danalundefined
      Danal
      I will give that a try. I'll just copy your tool offsets exactly.
      • Danalundefined
        Danal
        OK, I have reproduced the diagonal move.
        Interestingly enough, I then put messages (m117) and delays (G4) in the tpre1.g file... and the diagonal move WENT AWAY. Very, very, odd.
        At this moment, I'm experimenting with delays and similar to find out exactly which command causes the diagonal move.
        • Danalundefined
          Danal
          OK, to summarize: With exact copies of @smoki3 files, including the pre/post/free and the tool offset, the diagonal move is reproduced on my machine. Which is a CoreXY running:
          Board: Duet 3 MB6HC (MB6HC)
          DSF Version: 1.1.0.5
          Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12+1 (2019-12-02b2)
          With all XYZ on the main board, only tools on the expander boards.
          Some experimentation also shows:
          • A delay, such as G4 S1, positioned before any other commands in tpre1.g, stops the diagonal.
          • An M400, positioned before any other commands in tpre1.g, stops the diagonal. Note that I removed all the other M400s.
          • G53 in front of all move commands in tpre1.g has no effect, the diagonal still occurs.
          Given that this appears to be timing sensitive, it begins to make more sense why exact copies of the files are needed to reproduce.
          Anyway, I hope this helps dc42 figure out what's going on.
          smoki3undefined 1 Reply Last reply Reply Quote 0
          • smoki3undefined
            smoki3 @Danal
            @Danal said in Tool Change: Moving in axis without calling them:
            Thanks for the nice analysis.
            Good point with the timing. It also makes sense. I sure @dc42 will fix it. Maybe already for 3.0RC1 🙂
            • smoki3undefined
              smoki3
              So I also tried a M400 in the first line of the tpre script. Then everything is fine 🙂
              • smoki3undefined
                smoki3
                I also noticed that you have this diagonal movement when you dock your tool after the print. But as Danal mentioned it only happen if directly after the tfree script a G1 follows.
                  dc42 administrators @smoki3
                  @smoki3 said in Tool Change: Moving in axis without calling them:
                  Thanks, from that I think I know what is going on, and I can fix it in 3.0 release.
                  smoki3undefined 1 Reply Last reply Reply Quote 1
                  • smoki3undefined
                    smoki3 @dc42
                    @dc42 said in Tool Change: Moving in axis without calling them:
                    Cool! So please also merge it to 2.xx
                      @smoki3, I have fixed this in the 3.0 stable release.
                      I am not planning to do any further 2.x releases, but you have an easy workaround (M400 at the start of the tpre and/or tpost file).
                      • smoki3undefined
                        smoki3 @dc42
                        I see. Its working fine now.
                        For 2.x I don't use it. I just thought about all the tool changer users....
