    61-33 chip blow out
    874
      A Former User
      Plugging in the USB cable with Vin applied to the board shouldn't be an issue. I think maybe Tony read your post as the USB cable being a custom one with 12v instead of the usual 5v, so odds are the board shorted something else as a result of you plugging in the cable, not directly causing the problem.
      • Dougal1957undefined
        Dougal1957
        I think we thought that you plugged in the USB but it had 12 v on it I am thinking maybe you mean the board was powered by 12V and then you plugged in the USB Connected to your computer is that correct?
        dombeeundefined 1 Reply Last reply Reply Quote 0
        • dombeeundefined
          dombee @Dougal1957
          @Dougal1957 exac
          • dombeeundefined
            dombee
            After replace the piece.
            The usb port don't work.
            When i start the board with only the 12v, the wifi module and the sd card reader
            become very hot.
            I think it's the end of that board 😞
              dc42 administrators @dombee
              @dombee said in 61-33 chip blow out:
              become very hot.
              When there is excessive voltage on the 3.3V rail, the SD card and the WiFi module are usually the first components to fail. I suggest you remove the SD card from the socket and throw it away, then if possible check the voltage on the 3.3V rail. Then fit the Erase jumper, press Reset, and see if you can get the Bossa port to appear on the PC. If it does, then your board can probably be recovered by replacing the WiFi module.
              • dombeeundefined
                dombee @dc42
                @dc42 said in 61-33 chip blow out:
                when I connect the usb cable, no led lights. Can i erase anyway
                  No. Assuming the cable is OK, that means your PC has cut power to the USB port because it is drawing too much current. That's probably because the faulty WiFi module is drawing too much current.
                  • dombeeundefined
                    dombee
                    I guest the shield of the usb port should be grounded?
                    when i plug a usb cable and check the ground i got nothing.
                    Does im right?
                    On an other side, when i plug only 12v PSU i got +/-3.3v on the 3.3v rail
                      A Former User @dombee
                      (on) my maestro (the usb) isn't, the microSD slot is, and the ethernet isn't - which seems to make sense to avoid ground loops.
                      dombeeundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                      • dombeeundefined
                        dombee @A Former User
                        @bearer
                        I mean conductivity not 3.3V
                        When i try with 2 working port i have conductivity
                          T3P3Tony administrators @A Former User
                          @bearer on the Maestro ethernet shield should be grounded through a large resistor (1M ohm)
                          https://github.com/T3P3/Duet/blob/master/Duet2/Duet2Maestro_v1.0/Duet2Maestro_Schematic_v1.0.pdf
                            A Former User @T3P3Tony
                            @T3P3Tony said in 61-33 chip blow out:
                            confirmed, but outside the measurement range .. 😊
                              @bearer
                              working and being correct isn't always the same thing This is for the Wifi, coupled though a cap:
                              • dombeeundefined
                                dombee
                                It's official, the ground on the usb port don't works
                                il plug the cable an put the ground usb wire to an other place and its working
                                  A Former User
                                  That has nothing to do with the shielding as such. More likely the usb socket is bad, or the ground pin is poorly soldered to the PCB. (ruling out issues with cables or the far side).
                                  Could have been damaged by the initial incident as well.
                                  (In fact if the usb shield was grounded you'd have the supply current run through the shield (no bueno) which is part of the reason its decoupled with the capacitor as shown in the schematic.)
                                  • dombeeundefined
                                    dombee
                                    i juste replace the wifi module
                                    i erase the firmware
                                    in port com i see bossa program port
                                    when i selec the right port in bossa he shut down.
                                    when the usb was on i vas 4 led open:
                                    red 5v+
                                    green 3.3v
                                    red between reset and usb
                                    red dial
                                      red 5v+
                                      green 3.3v
                                      red dial
                                      What shut down: the Duet? Did the red and green LEDs go off? Were any components on the Duet getting hot?
                                      The PC will shut off the USB port if it detects that too much current is being taken from it.
                                      • dombeeundefined
                                        dombee @dc42
                                        Bossa program shut down
                                        i try with sam -ba and it's said enable to connect
                                        Nothing seems hot
                                          And the LEDs?
                                          Did you remove or replace the SD card? The old one was probably blown.
                                          • dombeeundefined
                                            dombee
                                            yes i replace them
