    Some infill not reaching walls ?
    4.8k
      In that case, definitely try that linked build. It installs separately to the main cura install with a fresh configuration.
      Your crashing is quite likely a corrupted config file. It's happened to me a few times. I've had to torch my complete cura config and start fresh a few times.
      • jens55undefined
        jens55
        Ok, for those of us that had too many of the gray cells in the brain die off from old age .... where in the link you posted can I get the Linux appimage they are talking about <feeling very stupid at this moment>
        • jens55undefined
          jens55
          Duuuhhh, never mind .... found the teeny tiny back arrow <sigh>
            Sorry I linked straight to the read me. Oddly though when I open it it goes to the main page with all the download links.
            https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
            Try that maybe?
              😛 Too many eggnogs?
              • jens55undefined
                jens55
                Must be 😞 ... Got it downloaded, installed and it started up ok. It even flipped to the second printer without crashing ... wooohoooo
                I will try running a print on it tomorrow.
                Thanks!
                burtoogleundefined 1 Reply Last reply Reply Quote 0
                • burtoogleundefined
                  burtoogle @jens55
                  @jens55 said in Some infill not reaching walls ?:
                  Thanks!
                  Unfortunately, it does crash when I loaded your .3mf file that you provided on the Cura forum. I have a workaround for that crash so I can make a new build that will load that project OK. I will do that now and put it on Dropbox.
                  • DocTruckerundefined
                    DocTrucker
                    Have you done the checks for extrusion correction and single wall thickness?
                    Edit: A square single wall shape and measure the wall thickness and comparing it to the slicer targeted wall thickness will identify significant under extrusion. For this test I run the extrusion multiplier at 1, and adjust filament diameter to correct if needed.
                    • OBELIKSundefined
                      OBELIKS
                      Also check coasting, there is no need for that when using PA.
                      P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                      Original Prusa i3 MK3S
                      • jens55undefined
                        jens55 @DocTrucker
                        @DocTrucker said in Some infill not reaching walls ?:
                        Something is amiss. On the previous test prints I had excellent surface finish. This time, doing a vase print, I ran into terrible surface finish.
                        As it happens, I installed a new version of Cura so at this point I am not sure if the issues are related or not. I will have to do some more tests but am unable to do it this morning.
                        Quite honestly, I had not considered under-extrusion because the prints, other than the one or two joints between infill and wall, were very nice. I did recently go to a new filament and never bothered to measure the filament diameter. I now realize that size is a bit of a problem at 1.68 mm which could very well have caused some issues. Even then, it's difficult to see why under-extrusion would cause gaps on only one specific section of a print.
                        I did notice that on previous prints, the two outside walls were not joined well. That part could easily be explained by under-extrusion but not the gap between infill and wall.
                        Stay tuned for more tests but not right away ....
                        Oh, coasting is off.
                          Phaedrux Moderator @burtoogle
                          @burtoogle said in Some infill not reaching walls ?:
                          Thanks!
                          It worked. No more crash.
                          • jens55undefined
                            jens55
                            I backtracked to Cura 4.3 and backtracked some adjustments but no luck. The funny thing is that this issue only shows up on vase mode printing.
                            You can see proper wall building at the bottom and then it goes to excrement all of a sudden - very odd.
                            I also tried upping flow to 120% with no difference. I am currently out of ideas why this is happening because I printed in vase mode before with the 0.8 mm nozzle without any issues.
                            Oh, I also reduced the trace width to 0.8 mm because I thought that maybe somehow that could have caused the odd vase print (I had only printed at 0.8 mm for vase mode before)
                            The sample you see was printed in vase mode, 0.8 mm width and 120% flow.
                            • jens55undefined
                              jens55
                              OK, I think I am back on track. The issue was too much heat or too short a layer time. It would be interesting to understand why the first 15 or so layers printed fine and then it suddenly went to crap.
                              Now it's time to make sure extrusion rates are ok and once dialed in then I will reprint the model that was giving me issues.
                                DocTrucker
                                I get that with PLA if I forget the part cooling fan. The thin wall just gets too hot and goes wobbly.
                                • jens55undefined
                                  jens55
                                  I did have the fan going but only at 60% and one layer only took 3 or 4 seconds.
                                  The issue of the infill not meeting the wall unfortunately remains.
                                  I tried up to 150% flow rate without the issue going away
                                  • jens55undefined
                                    jens55
                                    One last stab at this thing ... analyzing the gcode I get 14 mm3/sec extrusion rate with 0.8 mm trace width and 0.4 layer height and the selected speeds. I have PA set to 0.8.
                                    To be on the safe side, I am assuming that the Volcano hot end is good to 20 mm3/sec.
                                    How do I figure out the actual extrusion rate once the PA speed increases are kicking in? Am I likely to exceed the 20 mm3/sec magic number ?
                                    I am getting slower and slower with the printing speed and I would hate to slow down even further just because PA increases the speed at the beginning. I would think that a short term speed increase such as PA needs should not require any de-rating of the printing speed ... but I have no clue .....
                                      Phaedrux Moderator @jens55
                                      Why assume when you can test?
                                      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s177
                                      I don't think that PA is likely to force you into exceeding the volumetric limit unless you're already really borderline. The volumetric limit isn't a hard wall, so even a little temporary excursion isn't very noticeable. The limit can also reduce itself due to cooling from pushing a lot of filament for a long duration. You can see the temp drop. But I don't think the short little ramp ups from PA are going to cause big issues.
                                      • jens55undefined
                                        jens55
                                        Thanks for that link. I will go through the calibration procedure as time allows in the next few days. Also thanks for your comments re PA and flow capacity.
                                        • OBELIKSundefined
                                          OBELIKS
                                          20mm/s on Volcano is OK if you have a decent extruder and extruder motor.
                                          PA of 0.8 is on the high side and it can give you problems on infill. What are your retraction settings?
                                          But I would try a different slicer, just to eliminate the possibility of wrong settings.
                                          • jens55undefined
                                            jens55
                                            I only retract 1 mm and no retraction on layer change.
                                            Can you elaborate how high PA can cause issues with infill ?
