    Duet 2 wifi corexy homing z in middle of the bed issue
    • weed2allundefined
      weed2all
      Hi...I just setup my custom corexy with a duet 2 wifi board and a precision piezo orion v2 in digital mode as a bed probe...for x and y I use optical endstop at 0,0 position,so far so good...I can home individual axis and all work ok...but I want to home z axis in middle of the bed and it seams that I cannot achieve this...I edited the homez.g and homeall.g for the nozzle to go to x150 y150 but only it's only go to x150 then home z axis...my working area is 300x300x315
      https://www.thingiverse.com/weed2all/designs
      • Vetiundefined
        Veti
        post your config and homing files.
        • weed2allundefined
          weed2all
          config.g homez.g homeall.g
          • Vetiundefined
            Veti
            G1 H2 X150 Y150 F9000 ; go to first bed probe point and home Z
            H2 moves are not for Corexy. delete H2
            • weed2allundefined
              weed2all
              That is a new configuration file made today on reprap configuration tool...why it put the h2 in homez.g and homeall.g?
              • weed2allundefined
                weed2all
                Ok...sweet...thank you so much.. I've deleted the h2 from homez.g and homeall.g
                All work as it should.. thank you...
                  Phaedrux Moderator @weed2all
                  @weed2all said in Duet 2 wifi corexy homing z in middle of the bed issue:
                  Known issue. Will be resolved in next update.
