Z height when homed is always 206.18
1.4k
    DustinDep
    No matter what i do, i can't figure out how to fix this issue. I have built a Kossel Mini and i know my homed height it actually 259mm. I bring the head down to within a piece of paper of the bed and set that as Z0. then when i hit home it doesn't go all the way up only part of the way. If i then hit home a second time it completely ruins my calibration. Please help! i have the homed height in my config.g file set to 259 currently
      T3P3Tony administrators
      Can you post your config.g and homedelta.g
        DustinDep
        ; Configuration file for Duet 0.8.5 (firmware version 1.16)
        ; generated by RepRapFirmware Configuration Tool on Fri Feb 03 2017 10:52:12 GMT-0800 (PST)
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        G90 ; Send absolute coordinates…
        M555 P2 ; Set firmware compatibility to look like Marlin
        ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
        M665 R105.6 L215 B85 H259 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
        M574 X2 Y2 Z2 S1 ; Define active high microswitches
        M558 P1 X0 Y0 Z0 H10 F120 T2400 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
        G31 P500 X-18 Y-6 Z1 ; Set Z probe trigger value, offset and trigger height
        M92 X80 Y80 Z80 E663 ; Set steps per mm
        M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
        M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
        M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
        M906 X700 Y700 Z700 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M143 S285 ; Set maximum heater temperature to 285C
        M305 P0 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 0
        M305 P1 T100000 B4388 R4700 ; Set thermistor + ADC parameters for heater 1
        M563 P0 D0 H1 ; Define tool 0
        G10 P0 X0 Y0 ; Set tool 0 axis offsets
        M550 PMiniKossel ; Set machine name
        M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
        M552 P192.168.1.14 S1 ; Enable network and set IP address
        M553 P255.255.255.0 ; Set netmask
        M554 P192.168.1.254 ; Set gateway
        M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
        ; Custom settings
        M208 S1 Z-20 ; Set minimum Z
        T0 ; Select first tool
          DustinDep
          ; homedelta.g
          ; called to home all towers on a delta printer
          ; Use relative positioning
          G91
          ; Move all towers to the high end stopping at the endstops (first pass)
          ;*** Slow homing has been configured. Change F240 to F2400 below when your configuration is working
          G1 X210 Y210 Z210 F2400 S1
          ; Go down a few mm
          G1 X-5 Y-5 Z-5 F2400 S2
          ; Move all towers up once more (second pass)
          G1 X10 Y10 Z10 F2400 S1
          ; Move down a few mm so that the nozzle can be centred
          G1 Z-5 F2400
          ; Switch back to absolute positioning and go to the centre
          G90
          G1 X0 Y0 F2400
            DustinDep
            i just noticed it says Duet firmware 0.8.5 but I'm on duet wifi does that matter?
            Also im using the 1.17 firmware for the wifi
              You need to change the line in homedelta.g
              To a value larger than the 259 your Z height is.
              Try
              G1 X265 Y265 Z265 F2400 S1
                DustinDep
                Okay now it goes all the way up with the first time hitting Home, but same issue it says my Z height is 206.18.
                  How are you probing the bed?
                    DustinDep
                    i have the escher3D IR sensor but i am not even to the point of auto calibration yet
                      If you run M665 with no parameters, what does it report?
                      7 out of 10
