    Q for @DC42 and Chris Hammacher
    Beta Firmware
    1.6k
    • Danalundefined
      Danal
      Thanks, guys, all good ideas.
      I've tried numerous ways to make a connection to CodeConsole more efficient; they all run into the fact that CodeConsole closes stdin when it sees EOF. Also, I'm not married to Python. I'm just scripting. Python was primarily because I wanted to lean toward something that is installed by default on a Pi.
      So... websockets, or the dcs.sock ipc socket. I think I'm going down the websocket path next. Seems simplest and most consistent.
      THANKS.
      gtj0undefined A Former User? 2 Replies Last reply Reply Quote 0
      • gtj0undefined
        gtj0 @Danal
        @Danal said in Q for @DC42 and Chris Hammacher:
        THANKS.
        You can't send commands via the WebSocket. It's just for receiving events (state changes, temp changes, current coordinates, etc). You'll still need to use the HTTP POST to send GCode.
        • Danalundefined
          Danal
          In order to deal with only the socket, I'm going to send commands formatted like this:
          {"code":"M122 B1","channel":0,"command":"SimpleCode"}
            A Former User @Danal
            thats fair enough, but it shouldn't get an EOF before you call os.pclose() or g0Stream goes out of scope methinks. (although you clearly know more python than me, so I could be wrong, incorrect or all of the above)
            • Danalundefined
              Danal @A Former User
              @bearer said in Q for @DC42 and Chris Hammacher:
              Yeah, you'd think. But whether invoked with any of several os.xxxx or fork, it ends after the first write to it's cloned stdin. I think python is set up so much to be nonblocking... maybe...
              Anyway, I'm off in socket land, and I like it a LOT better.
              • Danalundefined
                Danal
                Proof-of-concept level success in socketland. Decide to bypass the web socket and go straight to the control server's (internal) socket. This little program works:
                #!/usr/bin/env python3
                import socket
                import json
                import time
                s = socket.socket(socket.AF_UNIX, socket.SOCK_STREAM)
                s.connect('/var/run/dsf/dcs.sock')
                j=json.dumps({"mode":"command"})
                print(j)
                s.send(j.encode())
                time.sleep(0.002)
                r=s.recv(128)
                print(r.decode())
                j=json.dumps({"code": "M122 B1","channel": 0,"command": "SimpleCode"})
                print(j)
                s.send(j.encode())
                r=s.recv(128)
                print(r.decode())
                if (r.decode() == '{"success":true}'):
                  r=s.recv(1024)
                  print(r.decode())
                • Danalundefined
                  Danal
                  the 'dumps' or 'loads' turn python dictionaries to/from string-style-json
                  the '.encode()' and matching dcode turn simple strings to/from "byte like objects", which are a python thing necessary for dealing with raw streams such as internal sockets.
                  There is a bit of socket stream handling here and there, and then there is a bit of specific payloads and/or sequences that are Dave and Chris's way of talking to the control server. I figured those out from traces of what DWC was doing.
                  Anyway, it should be possible to built the scripts I want to build on top of little wrappers for the above. Right this instant, my mind is fried and it is a VERY pretty day in North Texas. Going outside!!
                    A Former User
                    Yeah, if the unix socket runs off json then why not.
                    But CodeConsole runs fine with multiple commands through socat and across TCP (running my PanelDue now like so:) so its definitively a quirk with how its handled in Python; the only thing that strikes me is that it could be the echo cmd | bit that causes the issue with echo closing up its stdout causing CodeConsole to get the EOF right away? Anyway, the horse is dead, i'll stop beating it, or take a break at least:)
                    • Danalundefined
                      I'm still kind of curious. Not the echo, that went away when I moved from shell to trying to keep a pipe open. Things like this. The first command M122 works, the second M114 hangs (stalls) forever. Tried LOTS of variants.
                      Anyway, like you said, horse, dead, beat, etc, etc.
                      rs, ws = os.pipe()
                      if not os.fork():
                        #child
                        os.dup(rs)    #stdin  to parent pipe
                        os.dup2(ws,1) #stdout to parent pipe
                        os.dup2(ws,2) #stderr to parent pipe
                        os.execv('/opt/dsf/bin/CodeConsole',['dummy'])
                        print('Failed to start CodeConsole')
                        sys.exit(8)
                      #parent
                      wsf = os.fdopen(ws,'w')
                      rsf = os.fdopen(rs,'r')
                      line = rsf.readline()
                      print(line)
                      if ('Connected!\n' != line):
                        print('Error connecting to DSF')
                        print(line)
                        for line in rsf:
                          print(line)
                        exit(8)
                      wsf.write('M122 B1\n')
                      print(line)
                      wsf.write('M114\n')
                      for line in rsf:
                          print(line)
                      • Danalundefined
                        Danal
                        And... here is a library based on the POC that can be imported into a Python program, with everything following the library being more-or-less straightforward gcode calls.
                        Only very lightly tested... and at least some of the sequence/race in the POC were wrong, so they could still be wrong here.
                        import socket
                        import json
                        def openDSF():
                            j=json.dumps({"mode":"command"}).encode()
                            s.send(j)
                            r=s.recv(128).decode()
                            if (-1 == r.find('{"version":')):
                                  print("Failed to enter command mode - version not received")
                                  print(r)
                                  exit(8)
                            if (-1 == r.find('{"success":true}')):   #could be in same buffer as version
                                      print("Failed to enter command mode - success not received")
                                      print(r)
                                      exit(8)
                            return(s)
                        def closeDSF(s):
                            s.close()
                        def Gcode(s,cmd=''):
                            j=json.dumps({"code": cmd,"channel": 0,"command": "SimpleCode"}).encode()
                            s.send(j)
                            r=s.recv(2048).decode()
                            return(r)
                        def getPos(s):
                          result = json.loads(Gcode(s,'M408'))['result']
                          pos = json.loads(result)['pos']
                          print('getPos = '+str(pos))
                          return pos
                        Very short test:
                        from DWClib import *
                        DSFsock = openDSF()
                        r=Gcode(DSFsock,'M114')
                        print(r)
                        print('====================================')
                        r=Gcode(DSFsock,'M122 B1')
                        print(r)
                        r=Gcode(DSFsock,'M408')
                        print(json.loads(r))
                        p=getPos(DSFsock)
                        print(p[0])
                        closeDSF(DSFsock)
                        A Former User? 1 Reply Last reply Reply Quote 2
                          @Danal Nice, now how about using a proper language? (...while I go hide under my desk:)
                          ((My bad, that was just meant as praise with a sidedish of a poor joke; will poke it and see if it deals with M117, M118, M300 and other asyncronous stuff better than CodeConsole for mye PanelDue adventures. Thanks for doing the legwork!))
                          • Danalundefined
                            Actually, I'm open to anything that's pre-installed on the Pi (and the Duet image, in particular), that leans even a little bit toward scripting.
                            What would you suggest?
                            • gtj0undefined
                              gtj0
                              Nice work @Danal !
                              • Danalundefined
                                Danal
                                OK, switched to round hole. At this moment, hacked into the corner of the bed; for production would be more nicely integrated along an edge somewhere.
                                Also got the script working consistently. Based on 4 back-back runs, repeatability seems to be about 0.09mm in Z and 0.02 in X and Y. These are probably better than any hand method, and usable for printing. At the same time, I'd like for them to be even more consistent and may tweak a few things.
                                timothyzundefined 1 Reply Last reply Reply Quote 0
                                • timothyzundefined
                                  timothyz @Danal
                                  @Danal .09mm in Z repeatability seems rather high, and I would expect that to be much lower than the xy repeatability. Any thoughts as to why this is?
                                  • Danalundefined
                                    Danal @timothyz
                                    @timothyz said in Q for @DC42 and Chris Hammacher:
                                    Yeah, I was concerned about that as well. Not sure.
                                    I need to literally "look" at the printer while this runs. Or single steps. With a dial gauge or similar.
                                    And/or, even at feedrate F100, I may back off slightly and retouch at an even lower feedrate.
                                    • Danalundefined
                                      Danal
                                      Also, I've cleaned up a bunch of things, and published this all on github.
                                      And... started a new thread. So Dave and Chris don't have to see the title of this one keep popping up!
                                      • wilrikerundefined
                                        wilriker
                                        Just for the sake of completeness: there does not yet exist an official python library to the DuetAPI (but it is on the roadmap - next I think). There exists of course the C#.NET library that e.g. CodeConsole is built upon as well as my Go library (https://github.com/wilriker/goduetapiclient).
                                        And this wraps up that there is no current (full) client library for any scripting language. Thus great job at getting started @Danal! 👍
                                        Manuel
                                        My Tool Collection
