    Disabled heater still turning on
    430
      Phaedrux Moderator @brandon444
      @brandon444 said in Disabled heater still turning on:
      the red led on heater 7 comes on and the heater is outputting .9 to 1v
      Where exactly are you measuring this?
      Does the probe actually deploy and retract?
      brandon444undefined 1 Reply Last reply Reply Quote 0
        Also, for the sake of completeness, please post your config-override and probedeploy and retractprobe files.
        • brandon444undefined
          brandon444 @Phaedrux
          @Phaedrux I'm measuring it on the green screw terminal that you would but your heater cartridge wires in. Its labeled E6 Heater.
            brandon444
            Config override
            ; config-override.g file generated in response to M500 at 2019-12-30 23:50
            ; Heater model parameters
            M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
            M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
            G10 L2 P1 X0.00 Y0.00 Z0.00
            G10 L2 P2 X0.00 Y0.00 Z0.00
            G10 L2 P3 X0.00 Y0.00 Z0.00
            G10 L2 P4 X0.00 Y0.00 Z0.00
            G10 L2 P5 X0.00 Y0.00 Z0.00
            G10 L2 P6 X0.00 Y0.00 Z0.00
            G10 L2 P7 X0.00 Y0.00 Z0.00
            G10 L2 P8 X0.00 Y0.00 Z0.00
            G10 L2 P9 X0.00 Y0.00 Z0.00
            Deploy
            M280 P7 S10
            Retract
            M280 P7 S90
              Just for the sake of experimentation, can you try switching to PWM_3? You'll need to modify your existing commands to target that pin. Also verify your wires are ordered correctly by tracing them back to the BLTouch. Continuity check them as well.
                @Phaedrux
                So I changed it over to pwm4/heater6 and still the same thing.
                Just so you know what I'm talking about with the red led. Here's a picture. Also where I am measuring the 1v
                  Yes I see that thanks. I'm not sure if that's normal or not but does the probe actually work at all? Deploy and retract and trigger?
                    brandon444
                    Everything seems to be working. I don't have a bed or x/y motors installed right now so I can't test the homing, but everything seems to work
                      In answer to your original question, this is normal. The PWM output channels on the DueX5 share the same control pins as the heaters. So think of the LED as a "PWM active" indicator.
                      brandon444undefined 1 Reply Last reply Reply Quote 1
                        brandon444 @dc42
                        @dc42 thank you! Now I can probe peacefully
