    Duet 3 Standalone RRF3 Package?
    Firmware installation
    1.8k
      A Former User
      The Duet3 should, according to documentation at least, start up in stand alone mode if there is a /sys/config.g on the sd card installed on the Duet3 board.
      You could use the same SD card as was supplied for the Raspberry Pi, but you may have to reformat/re-partition it and add the /sys/config.g file like you would the Duet2Wifi. (There is a chance you can add the config file to card prepared for the Pi on the one FAT partition that is used for /boot in linux, but I've not been able to test that).
      • Hornetriderundefined
        Hornetrider
        @deckingman
        I know, I want to use the Ethernet connection...like with DUET2 Ethernet...
          Hornetrider
          @bearer
          tried that already with the formated SD card and the folder structure...but no success
          Btw. does the Paneldue directly connect or there is something to be considered besides the wiring to IO_0?
          • wilrikerundefined
            wilriker @Hornetrider
            @Hornetrider said in Duet 3 Standalone RRF3 Package?:
            There is no additional configuration necessary.
            Manuel
            My Tool Collection
              Hornetrider
              @wilriker thx
              so probably a wire mix up on RX/TX..will check on this again
                Hornetrider
                @deckingman
                THX wire mix up solved, Paneldue connected
                  A Former User
                  Just for future refrence you can use the something like M575 P1to see if the serial port is configured.
                    deckingman @Hornetrider
                    @deckingman
                    Fair enough but in your OP you said "..............standalone like my other Duet2Wifi types". Hence my assumption that you wanted to use WiFi.
                      Hornetrider
                      I got it running after creating all the folders and integrating the latest DWC into the WWW folder.
                      But now I am struggling to update the FW...having Checksum errors when using "Duet3Firmware_MB6HC.bin" for update from DC42 github ressource.
                      Is this the right bin file?
                      Sorry for all this questions...
                      wilrikerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      • wilrikerundefined
                        Yes, this is the correct file. Depending on which version of firmware currently is running on the board there will still be some bugs with uploading data over the internal ethernet interface. In that case it's best to copy the firmware binary directly on the SD card from your PC. Then you can flash it by issuing M997. After that uploads should be a lot more reliable and work via web interface from there on.
                        Manuel
                        My Tool Collection
                          dc42 administrators @Hornetrider
                          Yes that's the right file. Please use the one from the 3.0RC2 release. Earlier beta releases frequently gave CRC errors during file uploads.
                            Hornetrider
                            doing it with 3.0RC2 but receiving Error: "Duet3iap_sd_MB6HC.bin not found"...
                            • Danalundefined
                              Danal @Hornetrider
                              @Hornetrider Get the iap file from github and put it in sys. Then re-try the upload (or m997)
                                Hornetrider
                                did that and still this error...
                                  Hornetrider
                                  had to rename the iap fie from github...but I am not sure if that worked as:
                                  M122
                                  RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0beta12 running on Duet 3 MB6HC
                                  Board ID: 08DJM-956L2-G43S4-6JTDD-3SD6K-TV5UF
                                  Used output buffers: 3 of 32 (12 max)
                                  • Danalundefined
                                    Danal
                                    No, that did not work. You will get:
                                    M122 B1
                                    Diagnostics for board 1:
                                    Board EXP3HC firmware 3.0RC2 2019-12-28b4
                                      deckingman @Danal
                                      @Danal That's expansion board firmware which is different. Main board is
                                      RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0RC2 running on Duet 3 MB6HC
                                      • Danalundefined
                                        Danal
                                        You should have the IAP and the regular firmware file from this link:
                                        https://github.com/dc42/RepRapFirmware/releases/tag/3.0RC2
                                        And you should not have to rename them. You may want to put it in /sys on the SD card directly in a PC (not web)
                                          Hornetrider
                                          @Danal
                                          used this files right before my last post...
                                          Still got the error and then tried it by renaming the IAP, and then something worked..kind of..
                                          • Danalundefined
                                            Danal @deckingman
                                            @deckingman is as usual correct, I had a typo. Main board will look like THIS when correct:
                                            M122 B0
                                            Board ID: 08DGM-9T66A-G63SJ-6J1DD-3SD6K-1V0MA
                                            Used output buffers: 1 of 32 (18 max)
