    Duet 3 Standalone RRF3 Package?
    Firmware installation
    1.9k
    • wilrikerundefined
      wilriker @Hornetrider
      @Hornetrider said in Duet 3 Standalone RRF3 Package?:
      Btw. does the Paneldue directly connect or there is something to be considered besides the wiring to IO_0?
      There is no additional configuration necessary.
      Manuel
      My Tool Collection
      • Hornetriderundefined
        Hornetrider
        @wilriker thx
        so probably a wire mix up on RX/TX..will check on this again
          Hornetrider
          @deckingman
          THX wire mix up solved, Paneldue connected
            A Former User
            Just for future refrence you can use the something like M575 P1to see if the serial port is configured.
              deckingman @Hornetrider
              @deckingman
              I know, I want to use the Ethernet connection...like with DUET2 Ethernet...
              Fair enough but in your OP you said "..............standalone like my other Duet2Wifi types". Hence my assumption that you wanted to use WiFi.
                Hornetrider
                I got it running after creating all the folders and integrating the latest DWC into the WWW folder.
                But now I am struggling to update the FW...having Checksum errors when using "Duet3Firmware_MB6HC.bin" for update from DC42 github ressource.
                Is this the right bin file?
                Sorry for all this questions...
                wilrikerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • wilrikerundefined
                  Yes, this is the correct file. Depending on which version of firmware currently is running on the board there will still be some bugs with uploading data over the internal ethernet interface. In that case it's best to copy the firmware binary directly on the SD card from your PC. Then you can flash it by issuing M997. After that uploads should be a lot more reliable and work via web interface from there on.
                  Manuel
                  My Tool Collection
                    dc42 administrators @Hornetrider
                    Yes that's the right file. Please use the one from the 3.0RC2 release. Earlier beta releases frequently gave CRC errors during file uploads.
                      Hornetrider
                      doing it with 3.0RC2 but receiving Error: "Duet3iap_sd_MB6HC.bin not found"...
                      • Danalundefined
                        Danal @Hornetrider
                        @Hornetrider Get the iap file from github and put it in sys. Then re-try the upload (or m997)
                          Hornetrider
                          did that and still this error...
                            Hornetrider
                            had to rename the iap fie from github...but I am not sure if that worked as:
                            M122
                            RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0beta12 running on Duet 3 MB6HC
                            Board ID: 08DJM-956L2-G43S4-6JTDD-3SD6K-TV5UF
                            Used output buffers: 3 of 32 (12 max)
                            • Danalundefined
                              Danal
                              No, that did not work. You will get:
                              M122 B1
                              Diagnostics for board 1:
                              Board EXP3HC firmware 3.0RC2 2019-12-28b4
                                deckingman @Danal
                                @Danal That's expansion board firmware which is different. Main board is
                                RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0RC2 running on Duet 3 MB6HC
                                • Danalundefined
                                  Danal
                                  You should have the IAP and the regular firmware file from this link:
                                  https://github.com/dc42/RepRapFirmware/releases/tag/3.0RC2
                                  And you should not have to rename them. You may want to put it in /sys on the SD card directly in a PC (not web)
                                    Hornetrider
                                    @Danal
                                    used this files right before my last post...
                                    Still got the error and then tried it by renaming the IAP, and then something worked..kind of..
                                    • Danalundefined
                                      Danal @deckingman
                                      @deckingman is as usual correct, I had a typo. Main board will look like THIS when correct:
                                      M122 B0
                                      Board ID: 08DGM-9T66A-G63SJ-6J1DD-3SD6K-1V0MA
                                      Used output buffers: 1 of 32 (18 max)
                                      • Danalundefined
                                        Danal @Hornetrider
                                        @Danal
                                        Yeah, depending on what release you are coming FROM, there may be some renaming involved.
                                          Hornetrider
                                          then why do I have:
                                          M122
                                          • Danalundefined
                                            Danal
                                            If you got it to do something, try again with the RC2 file and un-renamed IAP.
