RepRapFirmware 3.0 is released!
@Danal said in RepRapFirmware 3.0 is released!:
Had to manually issue a M997 B1 for expander. (This may be expected behavior at this point).
Yes it is.
So what if any config changes would I need to make going from 3.0 Beta on a Duet2 WiFi? I already use S1 in M574.
Firmware Version: 3.0beta5+4 (2019-06-22b1)
WiFi Server Version: 1.23
Web Interface Version: 1.22.6G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M665 R226.747 L470.983 B200 H860.970 X-0.483 Y-0.268 Z0 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0.18 Y-0.11 Z-0.07 A0.17 B-0.18 ; Put your endstop adjustments here, or let auto calibration find them M579 X0.998 Y0.999 ; Non Linear Advance M592 D0 A0.001 B0.0004 L0.4 ; PETG ; Network M550 P"400" ; Set machine name M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Physical drive 0 goes forwards M569 P1 S1 ; Physical drive 1 goes forwards M569 P2 S1 ; Physical drive 2 goes forwards M569 P3 S1 ; Physical drive 3 goes forwards M350 E16 I0 ; Configure microstepping without interpolation M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation M92 X160 Y160 Z160 E1330 ; Set steps per mm M566 X600 Y600 Z600 E600 ; Set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z18000 E10000 ; Set maximum speeds (mm/min) M201 X1500 Y1500 Z1500 E1500 ; Set accelerations (mm/s^2) M906 X1200 Y1200 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z-0.1 S1 ; Set minimum Z ; Endstops M574 X2 Y2 Z2 S1 ; Set active high endstops ; Z-Probe M558 P5 R0.5 H3 F100 T3000 I1 A5 S0.02 ; Set Z probe type to effector and the dive height + speeds G31 P500 X0 Y0 Z-0.064 ; Set Z probe trigger value, offset and trigger height ;M558 P1 R0.5 H2 F100 T3000 I1 A5 S0.02 ; Set Z probe type to effector and the dive height + speeds ;G31 P485 X0 Y0 Z-0.064 ; Set Z probe trigger value, offset and trigger height M557 R195 S20 ; Define mesh grid M950 H0 C"nil" M950 H2 C"nil" M950 F0 C"nil" ; Heaters M950 H0 C"e1heat" Q10 ; Remap bed heater to e1 heater and frequency to 10hz M143 H0 S120 ; Set Bed temperature limit to 120C M305 P0 T100000 B3950 R4700 ; Set Bed thermistor + ADC parameters M307 H0 A318.5 C876.2 D4.2 B0 ; Bed PID M143 H1 S280 ; Set Hot End temperature limit to 280C M305 P1 T100000 B4388 R4700 ; Set Hot End thermistor + ADC parameters M307 H1 A491.5 C268.4 D3.8 B0 ; Hot End PID ; Fans M950 F0 C"bedheat" Q25500 ; Map Part Fan to bed heater mosfet / freq 25.5Khz M106 P0 S0 L125 X255 B0.2 ; Part Fan starts off / Min 50% / Max 100% / 100% for 0.2 Sec when turned ; on M106 P1 T50 S255 H1 ; Hot End Fan 100% when Hot End >= 50C M106 P2 T50 S125 H1 ; Extruder Stepper Fan 50% when Hot End >= 50C ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C T0 ; select first hot end M80 ; PS_ON to activate relay for heaters -
@Alexander-Mundy said in RepRapFirmware 3.0 is released!:
All releases link to the whats new log, which you're encouraged to read before upgrading as it will list all the relevant changes; big ones breaking configurations will be usually highlighted at the top of each version.
https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md -
Not before Beta 12, at least that I could find.
there is only beta 11 between, which has some notes in the release post
https://github.com/dc42/RepRapFirmware/releases/tag/3.0beta11 -
Thank you. I lost track of 3 beta after I got it working for one of my printers that needed the remapping features because it worked and I didn't need more. But now that stable is out I figure time to upgrade because future release will be based from this one.
I've upgraded to 3.0
Duet Wifi 2,Have everything working, at least I think, except for my Precision Piezo Z-Probe.
X and Y are homing correctly
Z probe is acting odd.Old Code - that worked fine:
M558 P8 R0.4 H5 I1 F1200 T6000New Code - Not Working
M558 P8 C"^zprobe.in" R0.04 H5 F1200 T6000The Dashboard shows Z-Probe "1000" when I tap on it, it immediately goes to "0" then back to "1000"
If I remove the Invert Character "^" the dashboard right after connecting shows "1000".
When I tap on it, it will go to "0" and stays there for about 10 seconds and then goes back to "1000"Any Ideas?
@Shotfire said in RepRapFirmware 3.0 is released!:
Any Ideas?You used I1 in your old M558 command, therefore you need to use pin name "!zprobe.in" in the new command. If the probe needs a pullup resistor (as appears to be the case), you will need to use "^!zprobe.in".
@dc42 Thanks I will try that.
Took the plunge and moved to RRF3.0. Sooner or later I will have to move anyway if I ever want to use conditional G-code, and it seems wiser to move before honing in the toolchange procedures.
Some weirdness. The X/Y endstop switches. These are normally open active low NPN proximity sensors. Configured in RRF2 like this:
; Endstops M574 X1 Y2 S0 ; set active low and disabled endstops M574 Z1 S2 ; set endstops controlled by probe The RRF config tool generates this code:
; Endstops M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y2 S0 P"ystop" ; configure active-low endstop for high end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z Which is not correct; according to the M574 documentation the S parameter should be 1 (microswitch-type endstop), and I suppose I need to do the inversion on the pins. Which seems to work:
(I also enabled the pullups); Endstops M574 X1 S1 P"^!xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y2 S1 P"^!ystop" ; configure active-low endstop for high end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z Next is Z homing. My RRF3 homez.g script, taken from the configurator and adjusted coordinates:
G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 H2 X115 Y115 F6000 ; go to first probe point G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 H2 Z5 F100 ; lift Z relative to current position G90 ; absolute positioning The G1 H2 X115 Y115 fails, and actually moves to X115 Y0? I suppose it moves the CoreXY motors independently. Removing the H2 does not work; you cannot move axes that are not homed yet.
I hacked it with a pair of M564 commands:
G91 ; relative positioning M564 S1 H0 G1 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X115 Y115 F6000 ; go to first probe point G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 H2 Z5 F100 ; lift Z relative to current position G90 ; absolute positioning M564 S1 H1 This works, but it is probably not how I am supposed to do that?
I have a custom built delta printer with the latest Duet2Wifi board avec Duex5, running the latest RRF 2.x.
I use the latest Cura 4 for slicing.
If I do the RRF2 -> RRF3 upgrade for these boards (Duet2Wifi avec Duex5) , will the GCode generatedf by Cura 4 still work on my delta printer, or do I have to look for another slicing software ?
@mihaitintea said in RepRapFirmware 3.0 is released!:
Should be no change to the slicer at all. There MIGHT be something in the start G-Code to adjust... but I really doubt it.
Do be aware that your config.g will require quite a bit of change. Look at all the guides for the Duet3.
@DaBit said in RepRapFirmware 3.0 is released!:
You are correct. We'll get configtool fixed.
The G1 H2 X115 Y115 fails, and actually moves to X115 Y0? I suppose it moves the CoreXY motors independently. Removing the H2 does not work; you cannot move axes that are not homed yet.The H2 should be removed. Surely X and Y have been homed by that point? It doesn't make sense to try to home Z using a Z probe if you can't set the XY coordinates.
X and Y have been homed before Z.
I tested by accidentally removing the H2 at the first Z-lift too, my bad.This works:
; homez.g ; called to home the Z axis G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X115 Y115 F6000 ; go to first probe point G30 ; home Z by probing the bed G91 ; relative positioning G1 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning Anyway, the RRF configurator is generating (imho) wrong code for this too; it produces a H2 for both the lift-Z and X/Y positioning moves.
RRF config tool generated homez.g:
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Jan 05 2020 10:48:15 GMT+0100 (Midden-Europese standaardtijd) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 H2 X19 Y1 F6000 ; go to first probe point G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 H2 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning -
FYI for anyone else moving from early beta (before 11) I had to do the following:
Define heaters and associated temp sensors
Use M308 instead of M305
Activate the pullup resistors for endstops and z probe if needed since they are not active by default
I had remapped the bed heat and part cooling fans previously and had M950 H0 C"nil" and M950 H2 C"nil" but removed them since heaters are no longer automatically assigned. -
@tobias_munich said in RepRapFirmware 3.0 is released!:
Is the the paneldue running on the DUET3 with this release yet?
saw that IO_0 should be reserved for this.Yes, it does. Connect it to
IO_0
and it will work. If you are using Duet3 + SBC then everything related to job files and macros will not work on PanelDue because it cannot see those (maybe also contents of/sys
, haven't checked that). -
Hi
I am not sure if this is off topic in this thread...sorry...
The symbols (double arrows) for Baby-Steps in the Print menu on Paneldue in combination with Duet3 and RRF3.0RC2 look different from RRF2.05 and are kind of missleading to me...
Could there be an option to change them to something simpler like before?I am having real fun using the Duet3 and RRF3.0. Damn good job!
@Hornetrider said in RepRapFirmware 3.0 is released!:
They used to show up and down arrows, but users complained about this because on machines that move the bed in Z, the arrows pointed in the opposite direction to the resulting bed movement. So now they show the gap between the nozzle and bed increasing or decreasing.
@dc42 said in RepRapFirmware 3.0 is released!:
FWIW:
As someone who has both kinds of printers, those that move bed, and those that move nozzle, I could never figure out the old icons. The new "squeeze or separate" make it much more clear for all cases.
Yeah, I got it.
Didn't think about it, regarding the Z axis as moving bed...
Thin I will get used to it as soon as I have updated my second printer to RRF3.0...
