    RepRapFirmware 3.0 is released!
    Firmware installation
    33
    131
    13.1k
    • tobias_munichundefined
      tobias_munich
      Hi all,
      maybe i missed it.
      Is the the paneldue running on the DUET3 with this release yet?
      saw that IO_0 should be reserved for this.
      regards Tobias
      Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
      Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
      Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
      • c310undefined
        c310
        DuetWiFi seem not to reed part of config. 😞
        I have upgraded to 3.0 and have issue with termostacically controlled fan:
        in config.g i have following lines:
        M106 P0 T45 S1 H1 B0.2 C"Extruder"			; extruder FAN on when 45 deg
        M950 F0 C"fan0"
        Once system boots and i query fan state: M106 P0
        04.01.2020, 17:09:43: M106 P0: Fan 0, speed: 0%, min: 10%, max: 100%, blip: 0.10
        basically it is ignoring part "T45 H1 B0.2" .... However, if i manually copy the same line to console and execute it, everything becomes fine:
        04.01.2020, 17:10:24: M106 P0 T45 S1 H1 B0.2 C"Extruder"
        04.01.2020, 17:10:34: M106 P0: Fan 0 (Extruder), speed: 100%, min: 10%, max: 100%, blip: 0.20, temperature: 45.0:45.0C, sensors: 1, current speed: 100%:
        as you can see - same command, but different outcome.
        same happens with system fan
        M106 P1 L30 T44:63 H20:21 C"System"			; system FAN min speed 10 MCU or Driver thermistor controlled cooling range 44...63 degrees
        M308 S20 Y"mcu-temp" A"CPU" 				; CPU temp sensor
        M308 S21 Y"drivers" A"Duet_drv" 			; drivers temp sensor
        M950 F1 C"fan1"
        What can i do to fix the issue? or it is the bug?
          deckingman @c310
          @c310 M950 needs to be before M106 (you have to create a fan output before you can use it). Hence the reason why the M106 in your congfig.g doesn't work but sending another M106 after config.g has run (and the M950 has been executed) does work.
          • c310undefined
            c310
            @deckingman said in RepRapFirmware 3.0 is released!:
            thanks! is works fine now. i have updated M950 documentation
            • DIY-O-Sphereundefined
              DIY-O-Sphere
              Successfully updated my Maestro from 2.05 to 3.0
              I have done almost everything manual, but for reference also generated the files with RRF Config Tool.
              For me that was the best way to get familiar with the new pin assignment.
              @chrishamm: Apart from that it was not possible to select the right pin assignment for BL-Touch within RRF-CT.
              With a customised 12864 display menu system and some macros I had to check around 70 files...
              I would recommend Notepad++ as it provides a option to find multiple words.
              It has only take some minutes to identify the relevant files.
              As often, the time for converting itself depends on your own knowledge.
              But in the end it was easy than expected.
              (UTC+1)
              • Danalundefined
                Danal
                Update via Pi, and all went well on DSF and 6HC main board. Had to manually issue a M997 B1 for expander. (This may be expected behavior at this point).
                  dc42 administrators @Danal
                  @Danal said in RepRapFirmware 3.0 is released!:
                  Yes it is.
                  • Alexander Mundyundefined
                    Alexander Mundy
                    So what if any config changes would I need to make going from 3.0 Beta on a Duet2 WiFi? I already use S1 in M574.
                    Firmware Version: 3.0beta5+4 (2019-06-22b1)
                    WiFi Server Version: 1.23
                    Web Interface Version: 1.22.6
                    G90                                         ; Send absolute coordinates...
                    M83                                         ; ...but relative extruder moves
                    M665 R226.747 L470.983 B200 H860.970 X-0.483 Y-0.268 Z0  ; Set delta radius, diagonal rod length, printable radius and homed height
                    M666 X0.18 Y-0.11 Z-0.07 A0.17 B-0.18       ; Put your endstop adjustments here, or let auto calibration find them
                    M579 X0.998 Y0.999
                    ; Non Linear Advance
                    M592 D0 A0.001 B0.0004 L0.4                 ; PETG
                    M550 P"400"                                 ; Set machine name
                    M552 S1                                     ; Enable network
                    M586 P0 S1                                  ; Enable HTTP
                    M586 P1 S0                                  ; Disable FTP
                    M586 P2 S0                                  ; Disable Telnet
                    M569 P0 S1                                  ; Physical drive 0 goes forwards
                    M569 P1 S1                                  ; Physical drive 1 goes forwards
                    M569 P2 S1                                  ; Physical drive 2 goes forwards
                    M569 P3 S1                                  ; Physical drive 3 goes forwards
                    M350 E16 I0                                 ; Configure microstepping without interpolation
                    M350 X16 Y16 Z16 I1                         ; Configure microstepping with interpolation
                    M92 X160 Y160 Z160 E1330                    ; Set steps per mm
                    M566 X600 Y600 Z600 E600                    ; Set maximum instantaneous speed changes (mm/min)
                    M203 X18000 Y18000 Z18000 E10000            ; Set maximum speeds (mm/min)
                    M201 X1500 Y1500 Z1500 E1500                ; Set accelerations (mm/s^2)
                    M906 X1200 Y1200 Z1200 E1200 I30            ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S30                                     ; Set idle timeout
                    M208 Z-0.1 S1                               ; Set minimum Z
                    M574 X2 Y2 Z2 S1                            ; Set active high endstops
                    M558 P5 R0.5 H3 F100 T3000 I1 A5 S0.02      ; Set Z probe type to effector and the dive height + speeds
                    G31 P500 X0 Y0 Z-0.064                      ; Set Z probe trigger value, offset and trigger height
                    ;M558 P1 R0.5 H2 F100 T3000 I1 A5 S0.02      ; Set Z probe type to effector and the dive height + speeds
                    ;G31 P485 X0 Y0 Z-0.064                      ; Set Z probe trigger value, offset and trigger height
                    M557 R195 S20                               ; Define mesh grid
                    M950 H0 C"nil"
                    M950 H2 C"nil"
                    M950 F0 C"nil"
                    M950 H0 C"e1heat" Q10                       ; Remap bed heater to e1 heater and frequency to 10hz
                    M143 H0 S120                                ; Set Bed temperature limit to 120C
                    M305 P0 T100000 B3950 R4700                 ; Set Bed thermistor + ADC parameters
                    M307 H0 A318.5 C876.2 D4.2 B0               ; Bed PID
                    M143 H1 S280                                ; Set Hot End temperature limit to 280C
                    M305 P1 T100000 B4388 R4700                 ; Set Hot End thermistor + ADC parameters
                    M307 H1 A491.5 C268.4 D3.8 B0               ; Hot End PID
                    M950 F0 C"bedheat" Q25500                   ; Map Part Fan to bed heater mosfet / freq 25.5Khz
                    M106 P0 S0 L125 X255 B0.2                   ; Part Fan starts off / Min 50% / Max 100% / 100% for 0.2 Sec when turned
        ; on
                    M106 P1 T50 S255 H1                         ; Hot End Fan 100% when Hot End >= 50C
                    M106 P2 T50 S125 H1                  	    ; Extruder Stepper Fan 50% when Hot End >= 50C
                    M563 P0 D0 H1                               ; Define tool 0
                    G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
                    G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
                    T0                    		            ; select first hot end
                    M80                                         ; PS_ON to activate relay for heaters
                      A Former User @Alexander Mundy
                      @Alexander-Mundy said in RepRapFirmware 3.0 is released!:
                      All releases link to the whats new log, which you're encouraged to read before upgrading as it will list all the relevant changes; big ones breaking configurations will be usually highlighted at the top of each version.
                      https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md
                        Alexander Mundy
                        Not before Beta 12, at least that I could find.
                          there is only beta 11 between, which has some notes in the release post
                          https://github.com/dc42/RepRapFirmware/releases/tag/3.0beta11
                            Alexander Mundy
                            Thank you. I lost track of 3 beta after I got it working for one of my printers that needed the remapping features because it worked and I didn't need more. But now that stable is out I figure time to upgrade because future release will be based from this one.
                            • Shotfireundefined
                              Shotfire
                              I've upgraded to 3.0
                              Duet Wifi 2,
                              Have everything working, at least I think, except for my Precision Piezo Z-Probe.
                              X and Y are homing correctly
                              Z probe is acting odd.
                              Old Code - that worked fine:
                              M558 P8 R0.4 H5 I1 F1200 T6000
                              New Code - Not Working
                              M558 P8 C"^zprobe.in" R0.04 H5 F1200 T6000
                              The Dashboard shows Z-Probe "1000" when I tap on it, it immediately goes to "0" then back to "1000"
                              If I remove the Invert Character "^" the dashboard right after connecting shows "1000".
                              When I tap on it, it will go to "0" and stays there for about 10 seconds and then goes back to "1000"
                              Any Ideas?
                                dc42 administrators @Shotfire
                                @Shotfire said in RepRapFirmware 3.0 is released!:
                                Any Ideas?
                                You used I1 in your old M558 command, therefore you need to use pin name "!zprobe.in" in the new command. If the probe needs a pullup resistor (as appears to be the case), you will need to use "^!zprobe.in".
                                Shotfireundefined 1 Reply Last reply Reply Quote 0
                                • Shotfireundefined
                                  Shotfire @dc42
                                  @dc42 Thanks I will try that.
                                  • DaBitundefined
                                    DaBit
                                    Took the plunge and moved to RRF3.0. Sooner or later I will have to move anyway if I ever want to use conditional G-code, and it seems wiser to move before honing in the toolchange procedures.
                                    Some weirdness. The X/Y endstop switches. These are normally open active low NPN proximity sensors. Configured in RRF2 like this:
                                    M574 X1 Y2 S0                                   ; set active low and disabled endstops
                                    M574 Z1 S2                                      ; set endstops controlled by probe
                                    The RRF config tool generates this code:
                                    M574 X1 S0 P"xstop"                                    ; configure active-low endstop for low end on X via pin xstop
                                    M574 Y2 S0 P"ystop"                                    ; configure active-low endstop for high end on Y via pin ystop
                                    M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
                                    Which is not correct; according to the M574 documentation the S parameter should be 1 (microswitch-type endstop), and I suppose I need to do the inversion on the pins. Which seems to work:
                                    (I also enabled the pullups)
                                    M574 X1 S1 P"^!xstop"                                    ; configure active-low endstop for low end on X via pin xstop
                                    M574 Y2 S1 P"^!ystop"                                    ; configure active-low endstop for high end on Y via pin ystop
                                    Next is Z homing. My RRF3 homez.g script, taken from the configurator and adjusted coordinates:
                                    G91                ; relative positioning
                                    G1 H2 Z5 F6000     ; lift Z relative to current position
                                    G90                ; absolute positioning
                                    G1 H2 X115 Y115 F6000 ; go to first probe point
                                    G30                ; home Z by probing the bed
                                    G1 H2 Z5 F100     ; lift Z relative to current position
                                    The G1 H2 X115 Y115 fails, and actually moves to X115 Y0? I suppose it moves the CoreXY motors independently. Removing the H2 does not work; you cannot move axes that are not homed yet.
                                    I hacked it with a pair of M564 commands:
                                    M564 S1 H0
                                    G1 Z5 F6000     ; lift Z relative to current position
                                    G1 X115 Y115 F6000 ; go to first probe point
                                    M564 S1 H1
                                    This works, but it is probably not how I am supposed to do that?
                                    • mihaitinteaundefined
                                      mihaitintea
                                      I have a custom built delta printer with the latest Duet2Wifi board avec Duex5, running the latest RRF 2.x.
                                      I use the latest Cura 4 for slicing.
                                      If I do the RRF2 -> RRF3 upgrade for these boards (Duet2Wifi avec Duex5) , will the GCode generatedf by Cura 4 still work on my delta printer, or do I have to look for another slicing software ?
                                      • Danalundefined
                                        Danal @mihaitintea
                                        @mihaitintea said in RepRapFirmware 3.0 is released!:
                                        Should be no change to the slicer at all. There MIGHT be something in the start G-Code to adjust... but I really doubt it.
                                        Do be aware that your config.g will require quite a bit of change. Look at all the guides for the Duet3.
                                          dc42 administrators @DaBit
                                          @DaBit said in RepRapFirmware 3.0 is released!:
                                          You are correct. We'll get configtool fixed.
                                          The H2 should be removed. Surely X and Y have been homed by that point? It doesn't make sense to try to home Z using a Z probe if you can't set the XY coordinates.
                                          • DaBitundefined
                                            DaBit
                                            X and Y have been homed before Z.
                                            I tested by accidentally removing the H2 at the first Z-lift too, my bad.
                                            This works:
                                            ; homez.g
                                            ; called to home the Z axis
                                            Anyway, the RRF configurator is generating (imho) wrong code for this too; it produces a H2 for both the lift-Z and X/Y positioning moves.
                                            RRF config tool generated homez.g:
                                            ; homez.g
                                            ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Jan 05 2020 10:48:15 GMT+0100 (Midden-Europese standaardtijd)
                                            G1 H2 X19 Y1 F6000 ; go to first probe point
                                            ;G91               ; relative positioning
                                            ;G1 H2 Z5 F100     ; lift Z relative to current position
                                            ;G90               ; absolute positioning
