    stepper motors vibrating but not moving issue
    • dingo007undefined
      dingo007
      new duet lan board, coming off a MKS Gen L V1.0 motors worked fine with marlin config
      on the duet they just vibrate, nothing moves and a message says message motor phase may be disconnected
      The motors in question are
      NIDEC Servo Corporation
      KH42KM2R015D
      DC 4.42V 1.3/A 1.8/step
      my config.g is
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y2 Z1:4 E3 ; set drive mapping
      M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
      M906 X800 Y800 Z800 E800 I80 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      • Vetiundefined
        Veti
        @dingo007 said in stepper motors vibrating but not moving issue:
        MKS Gen L V1.0
        did you check that you wired the phases correctly? motor phase disconnected means they are not.
        dingo007undefined 1 Reply Last reply Reply Quote 0
        • dingo007undefined
          dingo007 @Veti
          @Veti Yupp got it, that was the issue... resolved now. Thanks just had to reverse 2 pins on each motor. Thanks
