    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    9.8k
    • tooundefined
      too @dc42
      @dc42 looking forward!
      Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
      • wilrikerundefined
        wilriker
        Release v2.1
        This release provides parameter substitution. Please see the below for details on how to use it.
        It can be found at the GitHub Releases page.
        Parameters
        execonmcode does provide a simple mechanism for parameter substitution. It is possible to pass string parameters to the
        selected M-Code and have them inserted in the -command. In the command string they have to be single letters prefixed by
        the percent-sign (%) and they must not be G, M or T.
        All parameters that do not have a corresponding value in the M-Code will be forwarded as given.
        Example
        Run execonmcode as
        $ ./execonmcode -command "mycommand %F %N %D"
        Then you can use the following M-Code syntax to replace these parameters
        M7722 F"my first parameter" N"my second parameter"
        this will lead to an execution of
        mycommand "my first parameter" "my second parameter" %D
        Note that %D was passed as is since it was not given in the M-Code.
        Manuel
        My Tool Collection
        oozeBotundefined 1 Reply Last reply Reply Quote 1
        • wilrikerundefined
          wilriker
          Release v2.1.1
          This is just a bug fix release to address a bug where too many (empty) parameters where introduced in between the command and it's actual parameters. This could lead to various problems.
          As usual it can be found at GitHub Releases page.
          Thanks to @too for reporting this. 👍
          Manuel
          My Tool Collection
          • wilrikerundefined
            wilriker
            Just as a short teaser: the upcoming version will allow an arbitrary amount of M-code+command pairs.
            Manuel
            My Tool Collection
            • tobias_munichundefined
              tobias_munich
              great Job !! many thanks.
              exactly what I looked for
              Tobias
              Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
              Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
              Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
              • wilrikerundefined
                wilriker
                Release v3.0
                This release adds the possibility to provide an arbitrary amount of -mCode + -command tuples. This way it is possible to have a single instance of execonmcode handle all the custom commands.
                Note that as part of this change there is no longer a default value for -mCode.
                Get it at GitHub Releases page.
                EDIT: This version is built agains goduetapiclient 1.2.0 and as such will only work with DSF 1.2.2.1 and later. In case you need a version that is working with DSF <= 1.2.2.0 please tell me here. It's not a problem to provide that as well.
                Manuel
                My Tool Collection
                gtj0undefined 1 Reply Last reply Reply Quote 1
                • gtj0undefined
                  gtj0 @wilriker
                  @wilriker I can't believe I missed this whole thread! Gonna give it a try tomorrow.
                  I'm also working on something to allow the SBC to do a hardware reset and flash erase via GPIO pins for cases where the firmware is stuck and you can't get to the board. Could be a good companion to your utility.
                  • wilrikerundefined
                    wilriker @gtj0
                    @gtj0 Glad to hear about any use-cases. 🙂
                    I myself use it to run poweroff as well as activating and deactivating my webcam (starting/stopping a systemd unit).
                    Manuel
                    My Tool Collection
                      A Former User
                      Tempting to try with a small I2C OLED on the Pi, but not top of the list just yet
                      • chas2706undefined
                        chas2706
                        @wilriker
                        This sounds really good. I would like to use it to activate a bash script on my system but I have attempted to install it and I cant get it to work.
                        I followed your instructions in your first post but using execonmode V3:
                        I downloaded execonmode and placed it into /usr/local/bin.
                        I tried to run it using sudo ./execonmode -help (just to see if it works) but I get the error message "cant open binary".
                        Could you instruct me where i'm going wrong.
                        BTW I am on the latest version of RRF3 and up to date with DSF etc.
                        Thanks in advance.
                        • wilrikerundefined
                          wilriker @chas2706
                          @chas2706 If you run
                          sudo ./execonmcode -help
                          It will try to find the executable in the current directory you issue this command. To have your shell locate it in your $PATH remove the ./ in front of execonmcode. For -help you don't need sudo BTW.
                          To make sure that it can find it also check if
                          echo $PATH
                          actually does contain /use/local/bin.
                          Last thing: you spelled it execonmode instead of execonmcode (extra "c" after "m") above. Make sure that's only a typo here. I might rename the executable in the future to something less error-prone.
                          Manuel
                          My Tool Collection
                          • chas2706undefined
                            chas2706
                            @wilriker
                            Thanks for the info. I will give it another go.
                            execonmode was just a typo error in my post lol.
                            Thanks
                            • chas2706undefined
                              chas2706
                              @wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                              ./execonmcode -help
                              I have placed execonmcode in /usr/local/bin and typed the following in the terminal without success:
                              pi@Duet3:~ $ cd /usr/local/bin
                              pi@Duet3:/usr/local/bin $ ls
                              execonmcode listen-for-shutdown.py
                              pi@Duet3:/usr/local/bin $ ./execonmcode -help
                              bash: ./execonmcode: Permission denied
                              pi@Duet3:/usr/local/bin $ sudo ./execonmcode -help
                              sudo: ./execonmcode: command not found
                              pi@Duet3:/usr/local/bin $ execonmcode -help
                              bash: /usr/local/bin/execonmcode: Permission denied
                              pi@Duet3:/usr/local/bin $ sudo execonmcode -help
                              sudo: execonmcode: command not found
                              • wilrikerundefined
                                wilriker @chas2706
                                @chas2706 Have you made execonmcode executable via sudo chmod +x /usr/local/bin/execonmcode? I think that's missing from the installation instructions.
                                Manuel
                                My Tool Collection
                                • chas2706undefined
                                  chas2706
                                  @wilriker
                                  No I forgot!!
                                  My silly mistake! It works a treat now.
                                  Thank you for your help.
                                  • wilrikerundefined
                                    wilriker @chas2706
                                    @chas2706 Thank you for implicitly pointing out a hole in the installation instructions. I amended that to GitHub already and will fix it above in an instant.
                                    Manuel
                                    My Tool Collection
                                    • chas2706undefined
                                      chas2706
                                      @wilriker
                                      No problem, again thanks for your help and for producing a fantastic plugin.
                                      • wilrikerundefined
                                        wilriker
                                        Important Note
                                        The current version of Exec On MCode is NOT compatible with DSF 1.3.0+. It will connect but fail at a random point in time which might lead to breaking side-effects. I will release a new version tomorrow or Monday. Until then, don't use this tool with DSF 1.3.0+.
                                        Manuel
                                        My Tool Collection
                                        • chas2706undefined
                                          chas2706
                                          Important Note
                                          I plan to temporarily remove this feature can you confirm that all I need to do this is to delete the extension?
                                          I did not enable it to run at start up.
                                          Many thanks for pointing this out.
                                          • wilrikerundefined
                                            wilriker @chas2706
                                            @chas2706 If you don't start it (automatically or manually) there is no need to do anything. It can sit in the filesystem that won't have any effect until you execute it.
                                            Manuel
                                            My Tool Collection
