    configuring Dual Z w/ Dual Z endstops....
    1.3k
    • Vetiundefined
      Veti @dingo007
      @dingo007 said in configuring Dual Z w/ Dual Z endstops....:
      rr3 config (makes no sense) (M584 X0 Y2 Z1 E3:4 should be M584 X0 Y2 Z1:4 E3 )
      yes change it. thats the manual change that you did.
      dingo007undefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        M574 Z1 S0 P"ystop" ; configure active-low endstop for low end on Z via pin ystop
        now add your second stop like this
        M574 Z1 S0 P"ystop+e0stop" ; configure active-low endstop for low end on Z via pin ystop
        • dingo007undefined
          dingo007 @Veti
          @Veti
          And below where it states, makes completely no sense to my brain, can someone explain ?
          You must use the M671 command to define the X and Y coordinates of the leadscrews
          where my left and right Z screws are at 225 to the bed which is centered of the 450x450 bed
          M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
          M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
          • dingo007undefined
            dingo007 @Veti
            @Veti said in configuring Dual Z w/ Dual Z endstops....:
            Im using Y and E1 so.....
            M574 Z1 S0 P"ystop+e1stop" ; configure active-low endstop for low end on Z via pin ystop
            • dingo007undefined
              dingo007 @dingo007
              @dingo007 i guess its..... ???
              M671 X0:250 Y0:250 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
              M208 X0:250 Y0:250 ; X carriage moves from 0 to 250, Y carraige goes from 0 to 250
              • Vetiundefined
                Veti
                what are you trying to do now? dual z endstop or independent leveling?
                thats only needed for the second one.
                • dingo007undefined
                  dingo007 @Veti
                  @Veti the document you sent me https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                  • dingo007undefined
                    dingo007
                    final RR3 config
                    config.g
                    M569 P2 S0 ; physical drive 2 goes backwards
                    M569 P4 S0 ; physical drive 4 goes backwards
                    M584 X0 Y2 Z1:4 E3 ; set drive mapping
                    M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z800.00:800.00 E420.00 ; set steps per mm
                    M566 X900.00 Y900.00 Z12.00:12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00:180.00 E1200.00 ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00:20.00 E250.00 ; set accelerations (mm/s^2)
                    M906 X800 Y800 Z800:800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 X0:250 Y0:250 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                    M208 X350 Y350 Z850 S0 ; set axis maxima
                    M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop
                    M574 Y1 S0 P"zstop" ; configure active-low endstop for low end on Y via pin zstop
                    ;M574 Z1 S0 P"ystop" ; configure active-low endstop for low end on Z via pin ystop
                    bed.g
                    ; bed.g
                    ; generated by RepRapFirmware Configuration Tool v2.1.5 on Fri Jan 10 2020 16:18:31 GMT+0700 (Indochina Time)
                    G29 ; probe the bed and enable compensation
                    G28 ; home
                    ;M401 ; deploy Z probe (omit if using bltouch)
                    G30 P0 X250 Y250 Z-99999 ; probe near a leadscrew, half way along Y axis
                    G30 P1 X250 Y250 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                    ;M402 ; retract probe (omit if using bltouch)
                    • Vetiundefined
                      Veti
                      did you try homing?
                      dingo007undefined 2 Replies Last reply Reply Quote 0
                      • dingo007undefined
                        dingo007 @Veti
                        @Veti not yet, waiting for a print to finish before i reflash to 3.x
                        • dingo007undefined
                          dingo007 @Veti
                          @Veti Okay so it doesnt home Z the way i would think. 1 end stop per Z axis .... cut the motor per side when end stop triggered. the right (Y) Z end stop both from movement, where i would think the opposite side would continue to move until its end stop was triggered.
                          config.g
                          M569 P2 S1 ; physical drive 2 goes backwards
                          M569 P1 S1 ; physical drive 1 goes backwards
                          M569 P3 S0 ; physical drive 3 goes forwards
                          M569 P4 S1 ; physical drive 4 goes backwards
                          M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                          bed.g
                          ; bed.g
                          G28 ; home
                          • Vetiundefined
                            Veti
                            this has to be answerd by dc
