Trigger wifi reconnect during long print
Assuming you are running recent versions of RRF and DuetWiFiServer, the Duet continuously tries to reconnect if it loses the connection.
If for some reason it keeps failing to reconnect, then you could try resetting the wifi module (M552 S-1) followed by restarting it (M552 S1 assuming you run it in client mode). You could do this in a macro, commanded from a PanelDue or from a trigger.
It was updated to latest version end of November or December. It's been much better recently.
Can this be done through USB?
Wifi light is off, not blinking, just off
@clytle374 said in Trigger wifi reconnect during long print:
Yes, you can send those 2 commands via USB.
You may be on 2.04, or one of the 2.05RC releases. Best to update to 2.05 release: https://github.com/dc42/RepRapFirmware/releases/tag/2.05
@dc42 put in a lot of work to resolve the wifi disconnection issues. When you are next able to connect, please can you send M122 and post the response.Ian
I'm back online, here's the version info
RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1) Duet WiFi Server Version: 1.23 Duet Web Control 2.0.4 Can I run M122 while printing?
@clytle374 Yes, it should be okay to run M122 when printing!
M122 output
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later Board ID: 08DGM-917DA-G4MSJ-6JKDA-3SN6N-KSRB9 Used output buffers: 6 of 24 (16 max) === RTOS === Static ram: 25712 Dynamic ram: 92584 of which 416 recycled Exception stack ram used: 512 Never used ram: 11848 Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3800) IDLE(ready,160) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 09:57:05 ago, cause: reset button or watchdog Last software reset at 2019-12-30 07:03, reason: User, spinning module GCodes, available RAM 12088 bytes (slot 1) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 12 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 7.6ms, max retries 0 MCU temperature: min 42.3, current 42.6, max 42.9 Supply voltage: min 11.6, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: ok, SG min/max 0/395 Driver 1: ok, SG min/max 0/415 Driver 2: ok, SG min/max 0/414 Driver 3: ok, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2020-01-08 12:35:31 Cache data hit count 4294967295 Slowest loop: 14.02ms; fastest: 0.07ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 156, MinFreeDm: 108, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 724836, completed moves: 724801, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.6 === GCodes === Segments left: 1 Stack records: 1 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is doing "G1 F3600.000" in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 200.31ms; fastest: 0.08ms Responder states: HTTP(0) HTTP(0) HTTP(1) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 1 WiFi firmware version 1.23 WiFi MAC address cc:50:e3:0d:22:c1 WiFi Vcc 3.35, reset reason Turned on by main processor WiFi flash size 4194304, free heap 22792 WiFi IP address 192.168.0.13 WiFi signal strength -51dBm, reconnections 0, sleep mode modem Socket states: 0 0 2 0 0 0 0 0 -
If I'm reading this properly I'm on the latest firmware.
Thanks
Cory -
Error status: 12
Referring to Error_codes_and_software_reset_codes this means:
0x04 Output buffer starvation
0x08 Output stack overflowRRF 2.04 and 2.05 had changes to fix most instances of these. I've referred this thread to @dc42 to have a look at.
My internet in the building with the printer is a special kind of horrible, the main DSL hasn't been much better. I've spent the last 2 days working on the system. Fixed DSL, I think. Ran ethernet to building and removing the cheap wifi booster out here.
I've changed the wifi name and password in the config.g file on the duet. But it's still connecting to the old wifi. How do I get it to change over?
NEVERMIND: That was way harder than it should be.
Thanks
Cory
