    RepRapFirmware 3.0 is released!
    Firmware installation
    33
    131
    13.3k
      deckingman @DaBit
      @DaBit I'll check my settings when I get back home in 8 days or so. I suspect that I'm using 10Hz because that is what I've always used. IIRC that figure of 10Hz was chosen specifically to suit SSRs. However, do not confuse the PWM frequency with the mark-space ratio that is PWM itself. And also, don't forget that the thermal mass of the aluminium plate acts as a huge damper to the conduction of heat through the plate, which makes the PWM frequency largely irrelevant.
      • blt3dpundefined
        blt3dp
        @bulka
        You have a bed.g file?
        My 3D Printing YouTube Channel
        Better Living Through 3D Printing
        Follow me on Instagram and Twitter
        Instagram
        Twitter
        bulkaundefined 1 Reply Last reply Reply Quote 0
        • bulkaundefined
          bulka @blt3dp
          @blt3dp
          yes 🙂
          @Dougal1957
          thank you, now it's working , ^zprobe.in was the right choice.
          Dougal1957undefined 1 Reply Last reply Reply Quote 1
          • Dougal1957undefined
            Dougal1957 @bulka
            @bulka Glad to be of help
            Doug
            • garyd9undefined
              garyd9
              The documentation for converting M558 to RRF3 is a bit confusing in regards to the "I" parameter. In particular, it doesn't say anything about it (in that section)
              https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M558
              As well, the gcode wiki page also seems to imply that "M558 I1" is valid (https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type)
              "All of the above for RepRapFirmware 2.x relates to RepRapFirmware 3, except the following:" (and nothing that follows makes mention of the I param.)
              Yet, from reading this thread, I get the impression that RRF2:
              M558 P8 I1 R0.4 F300 H3
              does not work in RRF3 as:
              M558 P8 R0.4 I1 C"zprobe.in" H3 F300
              and instead should be written as:
              M558 P8 R0.4 C"!zprobe.in" H3 F300 ; I1 removed, ! prepended to zprobe.in
              Edit: I accidentally left the "I1" in my 558 after converting, and had the ! before the pin. The result apparently was a double inversion. Removing the I1 and leaving the "!" made everything seem to work.
              So ... which is the proper way?
              • garyd9undefined
                garyd9
                Duet2 wifi h/w version 1.04
                Printer is a normal delta (with 0.9 degree steppers)
                Firmware is the first general release of RRF3
                After starting my first print with RRF3 on a Duet2 WiFi, I'm seeing a LOT of hiccups using an identical configuration to what I used with RRF2 (where I only rarely saw a hiccup.)
                For example, 45 seconds after sending "M122", I sent M122 again and saw "Hiccups: 423(0)"
                Measuring it at one point, I got 161 hiccups for a travel move of around 80mm.
                The hiccups seem to be only after travel moves which are configured at 200mm/sec in my slicer. Yes, I could slow this down and probably get rid of the hiccups, but the point is that I did NOT get hiccups with RRF2.0.5 with the exact same gcode file.
                The speed related lines in my config.g are directly copied from my RRF2 config.g, as well as the stepper config. I've included them below:
                M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
                M92 X199.50 Y199.50 Z199.50 E837.50                    ; set steps per mm
                M566 X1200.00 Y1200.00 Z1200.00 E2400.00               ; set maximum instantaneous speed changes (mm/min)
                M203 X21000.00 Y21000.00 Z21000.00 E10000            ; set maximum speeds (mm/min) (severely limited by slicer)
                M201 X1500.00 Y1500.00 Z1500.00 E1000.00               ; set accelerations (mm/s^2) (limited by M204)
                M204 P500 T1200
                The delta parameters are:
                M665 L360.260:360.260:360.250 R215.476 H415.377 B140.0 X0.426 Y0.176 Z0.000
                M666 X0.298 Y-0.635 Z0.337 A-0.31 B0.33
                A random M122 is also shown in case there's some information that might diagnose an issue:
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-9T6BU-FG3SN-6JKD6-3S46P-KUYVD
                Used output buffers: 3 of 24 (23 max)
                Static ram: 30516
                Dynamic ram: 91248 of which 96 recycled
                Exception stack ram used: 544
                Never used ram: 8668
                Tasks: NETWORK(ready,640) HEAT(blocked,1240) MAIN(running,104) IDLE(ready,156)
                Owned mutexes:
                Last reset 01:32:22 ago, cause: software
                Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8940 bytes (slot 1)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                Error status: 0
                Free file entries: 9
                SD card longest block write time: 14.1ms, max retries 0
                MCU temperature: min 36.0, current 36.6, max 37.0
                Supply voltage: min 23.3, current 23.5, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: ok, SG min/max 0/990
                Driver 1: ok, SG min/max 0/267
                Driver 2: ok, SG min/max 0/403
                Driver 3: ok, SG min/max 0/1023
                Date/time: 2020-01-09 22:39:36
                Slowest loop: 13.92ms; fastest: 0.10ms
                Hiccups: 621(0), FreeDm: 153, MinFreeDm: 101, MaxWait: 0ms
                === MainDDARing ===
                Scheduled moves: 119268, completed moves: 119228, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                === AuxDDARing ===
                Heater 0 is on, I-accum = 0.3
                Heater 1 is on, I-accum = 0.5
                Segments left: 1
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is doing "G1 X-14.161 Y69.007 E0.00898" in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 200.45ms; fastest: 0.09ms
                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(1)
                HTTP sessions: 1 of 8
                - WiFi -
                Network state is running
                Failed messages: pending 0, notready 0, noresp 23
                WiFi firmware version 1.23
                WiFi MAC address 84:f3:eb:83:42:fc
                WiFi Vcc 3.41, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 24224
                WiFi IP address 192.168.7.10
                WiFi signal strength -50dBm, reconnections 0, sleep mode modem
                Socket states: 2 0 0 0 0 0 0 0
                garyd9undefined 1 Reply Last reply Reply Quote 0
                • appjawsundefined
                  appjaws
                  I am totally confused ( not hard to do)
                  I have a part fan connected to board Fan0
                  I have an extruder fan connected to board Fan1
                  I have a system fan connected to board Fan2
                  I have made changes to the config file for RRF3 but the fans are not working properly, the extruder fan is on all the time, the system fan is not working and the part fan comes on if I move the sliders on part or system.
                  Very frustrating.
                  RepRapFirmware 2 settings
                  ; Thermistors and heaters
                  M305 P0 R4700 B3950 S"Bed Heater" ; bed thermistor R and B values
                  M305 P1 R4700 B4388 H23 S"Hot end" ; nozzle 1 thermistor R and B values
                  M307 H0 A104.6 C986.0 D1.9 ;B0 ; Auto tune PID for bed heater
                  M307 H1 A669.8 C253.0 D4.5 ;B0 ; Auto tune PID for extruder 0
                  ; Fan settings
                  M106 P1 T45 H1 ; Fan 1 to run when H1 is above 45Celsius
                  M106 P2 H100:101 T35:50 L0.3 ; electronics cooling fan
                  all of the above works correctly.
                  M950 H0 C"bed_heat" T0 ; create bed heater output on bedheat and map it to sensor 0
                  M308 S0 P"bed_temp" Y"thermistor" T4700 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                  M143 H0 S70 ; set temperature limit for heater 0 to 70C
                  M307 H0 A104.6 C986.0 D1.9 B0 S1.00 ; Auto tune PID for bed heater
                  M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
                  M308 S1 P"e0_temp" Y"thermistor" T4700 B4388 ; configure sensor 1 as thermistor on pin e0temp
                  M143 H1 S230 ; set temperature limit for heater 1 to 230C
                  M307 H1 A669.8 C253.0 D4.5 B0 S1.00 ; Auto tune PID for extruder 0
                  M308 S100 Y"mcu-temp" A"CPU" ; CPU temp sensor
                  M308 S101 Y"drivers" A"Duet_drv" ; drivers temp sensor
                  ; Fan settings
                  M950 F0 C"fan0" Q500 ; create fan 1 on pin fan1 and set its frequency
                  M106 P0 C"PartFan" ; set Part fan.
                  M950 F1 C"fan1" Q500 ; create fan 0 on pin fan0 and set its frequency
                  M106 P1 S0 H1 T45 C"Extruder" ; set Extruder Fan. Thermostatic control is turned on
                  M950 F2 C"fan2" Q500 ; create fan 1 on pin fan1 and set its frequency
                  M106 P2 H100:101 T35:55 L40 C"System" ; set System fan. Thermostatic electronics cooling fan
                  appjaws - Core XYUV Duet Ethernet Duex5
                  firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                  Ormerod 1-converted to laser engraver, Duet wifi
                  OpenSCAD version 2024.03.18
                  Simplify3D 5.1.2
                  • matej1006undefined
                    matej1006
                    Hello @dc42
                    why i get G28 error when i want to home my locking actuator?
                    ; Home U Axis
                    G91                     ; Set relative mode
                    G1 U-360 F9000 H1       ; Big negative move to search for home endstop
                    G1 U4 F600              ; Back off the endstop
                    G1 U-10 F600 H1       ; Find endstop again slowly
                    G90                     ; Set absolute mode
                    Here is code from homeu.g
                    and here is from homeall.g
                    ; homeall.g
                    ; called to home all axes
                    ; generated by RepRapFirmware Configuration Tool v2.0.4 on Sat Oct 12 2019 15:44:24 GMT+0200 (Srednjeevropski poletni ÄŤas)
                    T-1 			;remove tool befor probing
                    G1 Z5 F3000 H2          ; lift Z relative to current position
                    G1 H1 X-435 Y-388 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                    G1 H1 X-435             ; home X axis
                    G1 H1 Y-388           	; home Y axis
                    G1 X5 Y5 F3000         	; go back a few mm
                    G1 H1 X-435 F360        ; move slowly to X axis endstop once more (second pass)
                    G1 H1 Y-388            	; then move slowly to Y axis endstop
                    G90                     ; absolute positioning
                    G1 X210 Y200 F3000      ; go to first bed probe point and home Z
                    G30                     ; home Z by probing the bed
                    M98 P"homeu.g"
                    ;G91                    ; relative positioning
                    ;G1 H2 Z5 F50           ; lift Z relative to current position
                    ;G90                    ; absolute positioning
                    Matej
                      dc42 administrators @matej1006
                      @matej1006 said in RepRapFirmware 3.0 is released!:
                      Hello @dc42
                      What is the error message?
                      matej1006undefined 1 Reply Last reply Reply Quote 0
                        matej1006 @dc42
                        @dc42 G28 Failed to enable edstops
                          dc42 administrators @appjaws
                          @appjaws said in RepRapFirmware 3.0 is released!:
                          If you run M98 P"config.g", do you get any error messages?
                          Some problems I can see:
                          • The M308 command to create a sensor should come before the M950 command that uses it (twice in your config.g)
                          • Your M308 commands include T4700, which means you have 4.7K thermistors. Remove that parameter
                          • Max sensor number is 63, so you can't use sensor numbers 100 and 101
                          appjawsundefined 1 Reply Last reply Reply Quote 0
                            matej1006
                            @dc42 said in RepRapFirmware 3.0 is released!:
                            M98 P"config.g"
                            if i send M98 P"config.g" there is no error
                              Sounds like a problem with M574 commands. Please post your config.g file.
                              matej1006undefined 2 Replies Last reply Reply Quote 0
                                matej1006 @dc42
                                and why i can't see in extra temperature for water
                                G90                                     ; send absolute coordinates...
                                M83                                     ; ...but relative extruder moves
                                M80					; force the PS_ON line to 0V/GND; causing a voltage over relay, thus enabling it.
                                					; With the relay active, it close the circuit of the Live wire, taking over to supply the Power Supply.
                                M550 P"Toolchange printer"              ; set printer name
                                M667 S1                                 ; select CoreXY mode
                                M552 S0
                                M552 S1                                 ; enable network
                                M586 P0 S1                              ; enable HTTP
                                M586 P1 S0                              ; disable FTP
                                M586 P2 S0                              ; disable Telnet
                                ; Debugging
                                M111 S0                                 ; Debug off
                                M929 P"eventlog.txt" S1                 ; Start logging to file eventlog.txt
                                ;X and Y motors
                                M569 P5 S0                              ; Drive 5 direction | Y Stepper
                                M569 P6 S0				; Drive 6 direction | Y Stepper
                                ;Z motors
                                M569 P7 S0                              ; Drive 7 direction | Front Right Z
                                M569 P8 S0                              ; Drive 8 direction | Back Z
                                M569 P9 S0                              ; Drive 9 direction | Front Left Z
                                ;Extruders
                                M569 P1 S0                              ; Drive 1 direction | Extruder0
                                M569 P2 S0                              ; Drive 2 direction | Extruder1
                                M569 P3 S0                              ; Drive 3 direction | Extruder2
                                M569 P4 S0                              ; Drive 4 direction | Extruder3
                                ; Toolchanger actuator
                                M569 P0 S1					; Drive 0 direction | Toolchanger Actuator
                                M584 X6 Y5 Z9:8:7 U0 E1:2:3:4                   ; set drive mapping
                                M671 X-28:172:458 Y146:402:146 S15 		; leadscrews at front left, rear middle and front right
                                M350 X16 Y16 Z16 E16 U4 I1                 	; configure microstepping with interpolation
                                M92  X80.00 Y80.00 Z400.00 E420.00 U20   	; set steps per mm
                                M566 X900.00 Y900.00 Z12.00 E120.00 U750    	; set maximum instantaneous speed changes (mm/min)
                                M203 X6000.00 Y6000.00 Z1500.00 E1200.00 U10000 ; set maximum speeds (mm/min)
                                M201 X800 Y800 Z20 E1000 U1500          	; set accelerations (mm/s^2)
                                M906 X900 Y900 Z900 E800 U1000 I60            	; set motor currents (mA) and motor idle factor in per cent
                                M208 X0 Y0 Z0 S1                        	; set axis minima
                                M208 X420 Y380 Z480 S0                  	; set axis maxima
                                M574 U1 S1                           		; Set homing switch configuration for toolchange lock. Both switches should be wired NC and in series.
                                M574 X1 Y1 S1                           	; set active low and disabled endstops
                                M574 Z1 S2 					; Set endstops controlled by probe
                                M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T3000   ; Set Z probe type to modulated and the dive height + speeds
                                G31 P467 X0 Y40 Z1.0 				; Set Z probe trigger value, offset and trigger height
                                ; Bed Heater
                                M308 S0 P"bedtemp" Y"thermistor" T100000 B4138                  			; configure sensor 0 as thermistor on pin bedtemp
                                M950 H0 C"bedheat" T0        ; create bed heater output on bedheat and map it to sensor 0
                                M143 H0 S120        ; set temperature limit for heater 0 to 120C
                                M307 H0 B0 S1.00        ; disable bang-bang mode for the nozzle heater and set PWM limit
                                ; Tool1 Heater
                                ;M308 S1 P"spi.cs1" Y"rtd-max31865"                                                     ; configure sensor 1 as thermocouple via CS pin spi.cs1
                                M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4138                                      ; configure sensor 1 as thermistor on pin duex.e2temp
                                M950 H1 C"duex.e2heat" T1                                                               ; create nozzle heater output on duex.e2heat and map it to sensor 1
                                M143 H1 S280        ; set temperature limit for heater 1 to 280C
                                M307 H1 B0 S1.00        ; disable bang-bang mode for the nozzle heater and set PWM limit
                                ; Tool2 Heater
                                ;M308 S2 P"spi.cs2" Y"rtd-max31865"                                                     ; configure sensor 2 as thermocouple via CS pin spi.cs2
                                M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4138                                      ; configure sensor 2 as thermistor on pin duex.e3temp
                                M950 H2 C"duex.e3heat" T2                                                               ; create nozzle heater output on duex.e3heat and map it to sensor 2
                                M143 H2 S280        ; set temperature limit for heater 2 to 280C
                                M307 H2 B0 S1.00        ; disable bang-bang mode for the nozzle heater and set PWM limit
                                ; Tool3 Heater
                                ;M308 S3 P"spi.cs3" Y"rtd-max31865"                                                     ; configure sensor 3 as thermocouple via CS pin spi.cs3
                                M308 S3 P"duex.e4temp" Y"thermistor" T100000 B4138                                      ; configure sensor 3 as thermistor on pin duex.e4temp
                                M950 H3 C"duex.e4heat" T3                                                               ; create nozzle heater output on duex.e4heat and map it to sensor 3
                                M143 H3 S280        ; set temperature limit for heater 3 to 280C
                                M307 H3 B0 S1.00        ; disable bang-bang mode for the nozzle heater and set PWM limit
                                ; Tool4 Heater
                                ;M308 S4 P"spi.cs4" Y"rtd-max31865"                                                     ; configure sensor 4 as thermocouple via CS pin spi.cs4
                                M308 S4 P"duex.e5temp" Y"thermistor" T100000 B4138                                      ; configure sensor 4 as thermistor on pin duex.e5temp
                                M950 H4 C"duex.e5heat" T4                                                               ; create nozzle heater output on duex.e5heat and map it to sensor 4
                                M143 H4 S280        ; set temperature limit for heater 4 to 280C
                                M307 H4 B0 S1.00 									; disable bang-bang mode for the nozzle heater and set PWM limit
                                ; Tool definitions
                                M563 P0 S"TOOL1" D0 H1 F3  					; Define tool 1
                                G10 P0 Z-3.75                   				; Set tool 1 offset from the bed
                                G10 P0 R170 S190                				; Set tool 1 operating and standby temperatures(-273 = "off")
                                ;M572 D0 S0.1				    			; Set pressure advance on Extruder Drive 0
                                M563 P1 S"TOOL2" D1 H2 F4  					; Define tool 2
                                G10 P1 Z-3.75         						; Set tool 2 offset from the bed with tool-0 as a reference.
                                G10 P1 R170 S190                				; Set tool 2 operating and standby temperatures(-273 = "off")
                                ;M572 D1 S0.1				    			; Set pressure advance on Extruder Drive 1,
                                M563 P2 S"TOOL3" D2 H3 F5  					; Define tool 3
                                G10 P2 Z-3.75                   				; Set tool 3 offset from the bed
                                G10 P2 R170 S190         				; Set tool 3 operating and standby temperatures(-273 = "off")
                                ;M572 D2 S0.1				    			; Set pressure advance on Extruder Drive 2
                                M563 P3 S"TOOL 4" D3 H4 F6   					; Define tool 4
                                G10 P0 Z-3.75                    				; Set tool 4 offset from the bed
                                G10 P0 R170 S190		 				; Set tool 4 operating and standby temperatures(-273 = "off")
                                ;M572 D3 S0.1				    			; Set pressure advance on Extruder Drive 3
                                ;Water temp
                                M308 S5 P"e1temp" Y"thermistor" T100000 B4138                   ;configure sensor 5 as thermistor on pin e1temp
                                M950 F0 C"!Fan0+exp.pb6" Q25000 				; fan 0 is a 4-wire PWM fan so invert it, use high PWM frequency, tacho connected to PB6 on expansion connector
                                M106 H0 S1 T25                                                  ; set fan 0 value. Thermostatic control is turned on
                                T-1                                      			; select first tool
                                  matej1006 @dc42
                                  @dc42 i figurit out for homing u axe i stiil have problem with showing temp on graph and extra temp for water and MCU temp
                                  • wilrikerundefined
                                    wilriker @matej1006
                                    @matej1006 If a sensor is not bound to a heater it needs to be given a name to show up in the UI. That's done with the A parameter for M308.
                                    Manuel
                                    My Tool Collection
                                    • garyd9undefined
                                      garyd9 @garyd9
                                      @garyd9 said in RepRapFirmware 3.0 is released!:
                                      A follow up on this: I wanted to test things in a controlled environment without a print going. So, with no heaters/fans/extrusion going on, I performed the following commands (while in absolute positioning mode):
                                      G1 X0 Y-50 Z50
                                      M122 // just to clear the hiccup count
                                      M122 // just to make sure the hiccups were really at 0
                                      G1 Y+50 F12000
                                      M122
                                      The second M122 showed 188 hiccups.
                                      Is this normal for 0.9 degree steppers, 16 microsteps, and movements of only 100mm across the center of the bed at only 200mm/sec?
                                      Same test, but with a F param of 10000 showed 20 hiccups. Slowing it down to 9000mm/min showed 2 hiccups.
                                      (I didn't see these kinds of hiccups with RRF2 on the same config with moves this slow.)
                                      @dc42? Is RRF3 ready for Duet2 boards controlling deltas?
                                        @garyd, I'll do some tests on maximum step rates in RRF3. I noticed that on my delta, I had to reduce the max speed to 200mm/sec when it was previously higher.
                                        MrSteve920undefined 1 Reply Last reply Reply Quote 0
                                        • Hornetriderundefined
                                          Hornetrider
                                          Updated done for DUET3 Standalone from 3.0RC2 to 3.0 without trouble.
                                          Now going to do some prints to see if everything runs...
                                          Great Job!
                                          • appjawsundefined
                                            appjaws @dc42
                                            M98 P"config.g"
                                            thanks dc42,
                                            I am almost there now but I think you should know that the gcode documentation under M950 has a note "M950 needs to be before M106, M308 etc in config.g file"
                                            Simplify3D 5.1.2
