Calibrating a delta printer using conditional GCode
I'm almost ready to release RRF 3.1beta with conditional GCode support. I've tested it using a G32 script to calibrate my delta printer. At the start, it homes the printer only if it hasn't already been homed. Then it calibrates the printer by probing a number of points, starting again if probing fails. If calibration yields a standard deviation that is above a limit, it repeats the calibration process. If calibration fails 5 times for any reason, it quits. Here is the script:
; Auto calibration routine for large delta printer M561 ; clear any bed transform ; If the printer hasn't been homed, home it if !Move.Axes[0].Homed || !Move.Axes[1].Homed || !Move.Axes[2].Homed G28 ; Probe the bed and do auto calibration G1 X0 Y140 Z10 F10000 ; go to just above the first probe point while true if iterations = 5 abort "Too many auto calibration attempts" G30 P0 X0.00 Y140.00 Z-99999 if result != 0 continue G30 P1 X70.00 Y121.24 Z-99999 if result != 0 continue G30 P2 X121.24 Y70.00 Z-99999 if result != 0 continue G30 P3 X140.00 Y0.00 Z-99999 if result != 0 continue G30 P4 X121.24 Y-70.00 Z-99999 if result != 0 continue G30 P5 X70.00 Y-121.24 Z-99999 if result != 0 continue G30 P6 X0.00 Y-134.85 Z-99999 if result != 0 continue G30 P7 X-65.57 Y-113.57 Z-99999 if result != 0 continue G30 P8 X-112.29 Y-64.83 Z-99999 if result != 0 continue G30 P9 X-130.59 Y-0.00 Z-99999 if result != 0 continue G30 P10 X-115.90 Y66.91 Z-99999 if result != 0 continue G30 P11 X-69.45 Y120.29 Z-99999 if result != 0 continue G30 P12 X0.00 Y70.00 Z-99999 if result != 0 continue G30 P13 X60.62 Y-35.00 Z-99999 if result != 0 continue G30 P14 X-52.28 Y-30.19 Z-99999 if result != 0 continue G30 P15 X0 Y0 Z-99999 S8 if result != 0 continue if Move.CalibrationDeviation <= 0.03 break echo "Repeating calibration because deviation is too high (" ^ Move.CalibrationDeviation ^ "mm)" ; end loop echo "Auto calibration successful, deviation", Move.CalibrationDeviation ^ "mm" G1 X0 Y0 Z150 F10000 ; get the head out of the way
You can read what the commands mean at https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands.
This is better than sliced bread!
I'm curious to know what might be used with the "Move" construct. The example shows "Move.Axes[]" and "Move.CalibrationDeviation", but I don't see anything showing what else is available.
For example, the homing script might be modified to continue attempting to re-calibrate until either 5 iterations are reached, OR the difference between the "deviation before" and "deviation after" is less than 0.02.
@dc42 When dreams come true…
Just one question: it looks like „iterations“ is an implicit property of the while loop. If so, can I change that property from within the loop? Or can I evaluate it in a conditional statement?
@infiniteloop said in Calibrating a delta printer using conditional GCode:
You can use it in any expression, including a condition ('if', 'while' etc.) but you can't change it. Currently you can't define your own variables, so I included 'iterations' to make counted loops possible.
@garyd9 said in Calibrating a delta printer using conditional GCode:
See https://forum.duet3d.com/topic/13797/where-can-i-find-rrf3-0-object-model-reference-material.
Ooooohhhhhh yeah! More intelligent nozzle wipe process on toolchange possible soon!
Anxiously awaiting the beta..
Wowzers!!! That is FANTASTIC and what a great starting 'proof'.
Now I have a reason to go RRF3 on my Duet2 hardware!
wouldn't it be better to use '==' for comparison, rather than '='?
@fma said in Calibrating a delta printer using conditional GCode:
Why? But the syntax allows both anyway.
To avoid confusion with variable assignement, but I just saw in the documentation than you will use 'set' for that purpose. Good to have both notations.
