    Calibrating a delta printer using conditional GCode
    Beta Firmware
    514
      A Former User
      This is better than sliced bread!
      • garyd9undefined
        garyd9
        I'm curious to know what might be used with the "Move" construct. The example shows "Move.Axes[]" and "Move.CalibrationDeviation", but I don't see anything showing what else is available.
        For example, the homing script might be modified to continue attempting to re-calibrate until either 5 iterations are reached, OR the difference between the "deviation before" and "deviation after" is less than 0.02.
        • infiniteloopundefined
          infiniteloop @dc42
          @dc42 When dreams come true…
          Just one question: it looks like „iterations“ is an implicit property of the while loop. If so, can I change that property from within the loop? Or can I evaluate it in a conditional statement?
            dc42 administrators @infiniteloop
            @infiniteloop said in Calibrating a delta printer using conditional GCode:
            You can use it in any expression, including a condition ('if', 'while' etc.) but you can't change it. Currently you can't define your own variables, so I included 'iterations' to make counted loops possible.
              dc42 administrators @garyd9
              @garyd9 said in Calibrating a delta printer using conditional GCode:
              See https://forum.duet3d.com/topic/13797/where-can-i-find-rrf3-0-object-model-reference-material.
              • DaBitundefined
                DaBit
                Ooooohhhhhh yeah! More intelligent nozzle wipe process on toolchange possible soon!
                Anxiously awaiting the beta..
                • Danalundefined
                  Danal
                  Wowzers!!! That is FANTASTIC and what a great starting 'proof'.
                  Now I have a reason to go RRF3 on my Duet2 hardware!
                  • fmaundefined
                    fma
                    wouldn't it be better to use '==' for comparison, rather than '='?
                    Frédéric
                      dc42 administrators @fma
                      @fma said in Calibrating a delta printer using conditional GCode:
                      Why? But the syntax allows both anyway.
                      • fmaundefined
                        fma
                        To avoid confusion with variable assignement, but I just saw in the documentation than you will use 'set' for that purpose. Good to have both notations.
                        Frédéric
