    Best settings for stepper motors ?
    3.9k
      And what motor currents have you set in your M906 command in config.g? I suggest between 1300 and 1600mA for those tower motors if you are using the Duet WiFi, and about 1000mA for the extruder.
      EDIT: I see you have 1000mA for the axis motors, so you should increase that.
      • elmoretundefined
        elmoret
        Looks like quite a bit of over extrusion also, could be catching an edge.
        • StefaanCundefined
          StefaanC
          M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
          M92 X80 Y80 Z80 ; Set axis steps/mm
          M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
          M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
          M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
          M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
          • iDeveloundefined
            iDevelo
            Do you have an E setting for M92 in your config file?
            • iDeveloundefined
              iDevelo
              Ok I see you do further down. Scrap that!
              • iDeveloundefined
                iDevelo
                Have you checked your esteps?
                • Dougal1957undefined
                  Dougal1957
                  You don't appear to have set a Microstepping for your Z Axis in the M350 line not sure if this would cause it or not TBH but worth a try?
                  • StefaanCundefined
                    StefaanC
                    M350 what do i put in this line ? i did make not any changes here .
                      If you don't have a M350 command then it defaults to 16x microstepping with interpolation to 256x, which is what most people use.
                      I think it's a combination of over-extrusion as Tim pointed out, causing the nozzle to snag on the print, and insufficient motor current.
                      You have your extruder steps/mm set to 663, which is about right for the RepRap Mini Geared Extruder (which has a gear ratio of around 5:1) but too high for most other extruders. So I repeat idevelo's question: have you calibrated your extruder steps/mm?
                      Also I suggest you increase the XYZ motor current to 1300mA (M906 command in config.g).
                      • StefaanCundefined
                        StefaanC
                        ok i give a trie to change motors to 1300 and extruder to 663
                        • StefaanCundefined
                          StefaanC
                          I am manegd to print the lizard.gcode my tower are on 1000mA extruder 800mA
                          extruder steps/mm set to 500 . printhead E3D volcano 0,8mm
                          only issue i have was the temp. setting in the lizard gcode was set too low , i had continues put it back To 210° els it would not stick to my buildtac heatbed .
                          see video :
                          https://youtu.be/hFBDHyYQpVE
