    PWm control using fans
    • andornotundefined
      andornot
      Can i use say Fan 0 PWM to control an external phase angle controller using a thermocouple for temperature? The controller draws less then the 1.5A as stated in the documentation.
      If so, what code do i require, existing code below:
      ; thermocouples
      M308 S1 P"spi.cs1" Y"thermocouple-max31856"
      M308 S2 P"spi.cs2" Y"thermocouple-max31856"
      M305 P0 X153 ; set thermocouple to control bed temperature
      ; chamber parameters
      M141 H3 ; heater 3 is the chamber heater
      M305 P3 X152 ; set thermocouple to chamber temperature
      ;M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S180 ; Set temperature limit for heater 0 to 150C
      M305 P1 X201 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S450 ; Set temperature limit for heater 1 to 280C
      ;M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      ;M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      SpatialOne custom delta printer, upgrading to print PEEK, PEKK & Ultem
        Ditch the M305 commands, they are not used in RRF3. Instead, you should first create sensors using M308, then use M950 to create the heaters and associate them with sensors.
