    RepRapFirmware 3.01beta1 released
    Beta Firmware
    16
    60
    3.4k
    • kraegarundefined
      kraegar
      Can't wait to start playing!
      • chas2706undefined
        chas2706
        Found a problem with my config and everything is now working.
        Great work!
        • littlehobbyshopundefined
          littlehobbyshop
          Just a note for anyone playing with macros in browser. DWC 2.0.4 has a bug with tab spaces. The 2.0.5 update fixes that.
          https://github.com/chrishamm/DuetWebControl/releases/tag/2.0.5
          BLV MGN Cube w/Hemera, K8200, Sunlu S8
          • mwolterundefined
            mwolter
            Great work @dc42 This is going to be so helpful! Can’t wait to start using it!
            • insertnamehereundefined
              insertnamehere
              I have a Duet Wifi 2 and I've been trying to access Initial Deviation in the Object Model.
              If I execute the following line from the console:
              echo "Initial Deviation", move.initialDeviation.deviation ^ "mm"
              I get an error:
              echo "Initial Deviation",move.initialDeviation.deviation ^ "mm"
              Error: while executing command: unknown value initialDeviation.deviation
              echo "Calibration Deviation", move.calibration.deviation ^ "mm"
              responds:
              echo "Calibration Deviation", move.calibrationDeviation.deviation ^ "mm"
              Calibration Deviation 0.000mm
              M409 shows
              {"key":"","flags":"","result":{"boards":[{"firmwareFileName":"Duet2CombinedFirmware.bin","firmwareVersion":"3.01-beta1","iapFileNameSD":"Duet2CombinedIAP.bin","mcuTemp":{"current":40.4,"max":44.6,"min":39.9},"name":"Duet 2 WiFi","shortName":"2WiFi","vIn":{"current":24.0,"max":24.4,"min":0.5}}],"heat":{"coldExtrudeTemperature":160.0,"coldRetractTemperature":90.0,"heaters":[{"current":26.7,"sensor":0,"state":"Off"},{"current":27.1,"sensor":1,"state":"Active"}],"sensors":[{"lastReading":26.7,"name":"","type":"Thermistor"},{"lastReading":27.1,"name":"","type":"Thermistor"}]},"job":{"file":{"filament":[],"firstLayerHeight":0.0,"generatedBy":"","height":0.0,"lastModified":"28115-10-29T03:41:51","layerHeight":0.0,"numLayers":0,"printTime":0,"simulatedTime":0,"size":0},"lastFileName":"","layer":0,"timesLeft":{"filament":0.0,"file":0.0,"layer":0.0}},"move":{"axes":[{"homed":true,"letter":"X","max":300.0,"min":0.0,"userPosition":70.000,"visible":true},{"homed":true,"letter":"Y","max":300.0,"min":0.0,"userPosition":35.000,"visible":true},{"homed":true,"letter":"Z","max":350.0,"min":0.0,"userPosition":4.278,"visible":true}],"calibrationDeviation":{"mean":-0.000,"deviation":0.000},"currentMove":{"requestedSpeed":0.0,"topSpeed":0.0},"daa":{"enabled":false,"minimumAcceleration":10.0,"period":0.0},"idle":{"factor":0.7,"timeout":30000},"meshDeviation":{"mean":0.000,"deviation":0.000},"initialDeviation":{"mean":0.003,"deviation":0.001},"printingAcceleration":10000.0,"travelAcceleration":10000.0,"speedFactor":100.0},"network":{"interfaces":[{"actualIP":"192.168.1.142","firmwareVersion":null,"gateway":"0.0.0.0","subnet":"0.255.255.255","type":"wifi"}]},"state":{"currentTool":0,"machineMode":"FFF","status":"Idle"}}}
                dc42 administrators @insertnamehere
                @insertnamehere said in RepRapFirmware 3.01beta1 released:
                I get an error:
                You've found a bug (the property table wasn't ordered alphabetically after I renamed a property, so the binary search failed). I've fixed it in the latest build at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. I also added a compile-time check to prevent this happening in future, and an extra property state.upTime.
                insertnamehereundefined 1 Reply Last reply Reply Quote 0
                • carlossprundefined
                  carlosspr
                  I have updated and I can only use one tool.
                  On the tool configuration I have the following error:
                  M563 S"Yellow" P1 D1 H1 F0
                  Error: Tool creation: bad drive number
                  however on previous release this command was working fine.
                  carlossprundefined 1 Reply Last reply Reply Quote 0
                  • kraegarundefined
                    kraegar
                    3.01 now appears to require endstops be defined on a duet2, where the 3.0 upgrade guide specifically says they do not. (That guide also says fans do not, but that change was covered in the 3.01 release notes)
                      dc42 administrators @kraegar
                      @kraegar said in RepRapFirmware 3.01beta1 released:
                      That's correct. I'll add it to the 3.01 release notes and check the 3.0 upgrade guide.
                      • piperswundefined
                        pipersw @chas2706
                        @chas2706 said in RepRapFirmware 3.01beta1 released:
                        I just upgraded to this on my Duet Ethernet and I thought my board suddenly broke.
                        The extruder fan stays permanently on, I cant move any axis because I get this:
                        Have you read the readme ?
                        If upgrading a Duet WiFi/Ethernet/Maestro from the 3.0 release, note that default fans are no longer created.
                        Unless your config.g file already used M950 to create the fans explicitly, add commands M950 F0 C"fan0", M950 F1 C"fan1" and M950 F2 C"fan2" to config.g before your M106 commands.
                        Likewise, default endstop switches are not set up, so you will need to set up X and Y endstops (and Z odf needed) explicity, using one M574 line for each, and specifying the port name. Example: M574 X1 S1 P"xstop".
                          dc42 administrators @pipersw
                          @pipersw said in RepRapFirmware 3.01beta1 released:
                          To be fair to @chas2706, I have only just added that bit!
                          • kraegarundefined
                            kraegar
                            Got a macro in testing for iterating on bed leveling, and it's pretty amazing!
                            My initial round had two && in one line, which caused the duet to hard crash and reboot. I switched it to nested if statements, and that worked well. I want to tweak it a bit, but definitely working!
                            ( was iterating until initialDeviation was < 0.01 AND deviation was within 0.002 of initialDeviation)
                            • kraegarundefined
                              kraegar
                              Cleaned up the output to make it easier to follow. (also changed my leadscrew locations to make it take longer to converge for these tests, so I could troubleshoot easier)
                                Can you provide that version, so that I can fix it?
                                • kraegarundefined
                                  kraegar
                                  This post is deleted!
                                  • kraegarundefined
                                    kraegar
                                    Here is the version that works well:
                                    M561                         ; clear any existing bed transform
                                    ; If the printer hasn't been homed, home it
                                    if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                      G28
                                    G1 Z7.5
                                    ;Run initial 4 point leveling routine
                                    G30 P0 X15 Y45 Z-99999
                                    G30 P1 X15 Y227.5 Z-99999
                                    ;G30 P2 X235 Y125 Z-99999 S3
                                    G30 P2 X235 Y227.5 Z-99999
                                    G30 P3 X235 Y45 Z-99999 S3
                                    while true
                                      if iterations = 5
                                        abort "Too many auto calibration attempts"
                                      if move.initialDeviation.deviation < 0.01
                                        if move.calibrationDeviation.deviation < move.initialDeviation.deviation + 0.005
                                          if move.calibrationDeviation.deviation > move.initialDeviation.deviation - 0.005
                                            break
                                      echo "Repeating calibration because initial deviation (" ^ move.initialDeviation.deviation ^ "mm) must be < 0.01"
                                      echo "and (" ^ move.calibrationDeviation.deviation ^ "mm) must be within 0.005 of initialDeviation"
                                    echo "Auto calibration successful, deviation", move.calibrationDeviation.deviation ^ "mm"
                                    echo "Auto calibration successful, initialDeviation", move.initialDeviation.deviation ^ "mm"
                                    G28 Z
                                    G1 X0 Y0 F24000               ; move the head to the corner (optional)
                                    And removing the nested if's to replace with && crash it
                                      if move.initialDeviation.deviation < 0.01 && move.calibrationDeviation.deviation < move.initialDeviation.deviation + 0.005 && move.calibrationDeviation.deviation > move.initialDeviation.deviation - 0.005
                                            break
                                    Edit: I realize I could just have some major syntax issues, still figuring this out. But that's a hard crash if you do that 🙂
                                    dc42undefined garyd9undefined 2 Replies Last reply Reply Quote 0
                                      carlosspr @carlosspr
                                      @carlosspr Solved. I was missing M584 drive mapping on config.g
                                        Thanks, I've reproduced the crash by adding that line to my own script. I will look into it. Even if you do make a syntax error, you should get a helpful error message.
                                        PS - now I know that the new crash handler I added for uncaught exceptions works!
                                        Last software reset at 2020-01-15 16:35, reason: Terminate called, spinning module GCodes, available RAM 9464 bytes (slot 2)
                                        • kraegarundefined
                                          kraegar
                                          Trying to test if move.initialDeviation.deviation is 0.000
                                          if move.initialDeviation.deviation != 0
                                            echo "one " ^ move.initialDeviation.deviation
                                          I've tried using 0.000 as well, with the same result. == 0.000 or == 0 doesn't match, even though it is.
                                          (I'm trying to determine if leveling has been run at all yet, my only clear method for now is to see if initial and calirbated deviation and mean are all 0.000)
                                            Just done some tests. There is a problem with equality between floats.
                                            The other problem you had is because the GCode line was too long. I changed it to throw an exception when that happens, but the exception isn't caught.
                                            This is all very new code, so I was expecting some bugs.
