    Long simulation time = fun guaranteed
    3D Printing General Chat
    853
    • Nxt-1undefined
      Nxt-1 @dc42
      @dc42 38h13m30s so in this instance more like 30x
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • eitenundefined
        eiten
        What will it be?
        Nxt-1undefined 1 Reply Last reply Reply Quote 0
        • Nxt-1undefined
          Nxt-1 @eiten
          @eiten said in Long simulation time = fun guaranteed:
          What will it be?
          It will be 1/6th of a mold for an epoxy granite pour I plan to do.
          A Former User? eitenundefined 2 Replies Last reply Reply Quote 0
          • DaBitundefined
            DaBit
            Offtopic: Sure about that? I used an MDF mold to cast the epoxy concrete gantry of my CNC mill, and the 30mm thick outer shell was barely stiff enough for 90kg of the stuff. Compacting the stuff exerts quite a bit of force on the mold. Also, with MDF you have smooth walls as a bonus, and with the bendable MDF you can create curves.
              A Former User @Nxt-1
              @Nxt-1 said in Long simulation time = fun guaranteed:
              epoxy granite pour
              colour me, intrigued, I'm sticking around for the update!
              • DocTruckerundefined
                DocTrucker
                Hope you're not suffering the same problem as me or that build could be more like 47hrs!
                https://forum.duet3d.com/topic/13407/simulation-has-become-inaccurate?_=1579639007249
                • Nxt-1undefined
                  Nxt-1 @DaBit
                  @DaBit said in Long simulation time = fun guaranteed:
                  The bottom will be MDF, the parts I am printing have fillets (technically could do without if needed) and are not just a square shape. So fabricating the mould out of MDF only would be beyond my skills. Also, I plan to use at most 30kg.
                  • eitenundefined
                    eiten @Nxt-1
                    @Nxt-1 Sounds interesting. Please post results!
                      A Former User
                      Maybe you have considered it already, but if you put a box around the print and pack the outside with sand before casting the epoxy granite inside the mold you'll have a lot of external support (thats the theory at least:)
                      Nxt-1undefined 1 Reply Last reply Reply Quote 1
                      • Nxt-1undefined
                        Nxt-1 @A Former User
                        @bearer said in Long simulation time = fun guaranteed:
                        This is actually very clever, I had not thought of this. Should I run into strength problems, I will definitely go look into this.
                        Since the topic of the epoxy cast has gained some interest here, I will start a dedicated thread.
                          I haven't tried it but seen similar solution applied to similar problem. One aspect could be the exothermic reaction of the resin softening the print as well. If I ever get around to trying something similar I'd use my green sand and let the sand/clay dry thoroughly before casting for optimal external support.
                          • botundefined
                            bot
                            I've had simulations take like 5 hours, stop complaining 😛 (super high detail 5 day print)
                            *not actually a robot
                            • Nxt-1undefined
                              Nxt-1 @bot
                              @bot Hehe, nice
