    DWC 2.06, Experiencing Connection Interruption Errors
    Duet Web Control
    604
    • ctilley79undefined
      ctilley79
      Will do. Damn you guy's move fast. must have been released today
        ctilley79 @jay_s_uk
        @jay_s_uk Actually that didn't seem to fix it.
          Do you have a password set on that Duet?
          ctilley79undefined 1 Reply Last reply Reply Quote 0
            ctilley79 @dc42
            @dc42 no. I live life dangerously
              A Former User
              is it a Duet2Wifi? Run M122and post the output.
              ctilley79undefined 3 Replies Last reply Reply Quote 0
                ctilley79 @A Former User
                @bearer yes it is a duet 2 wifi
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-9T6BU-FG3SJ-6J9DD-3SJ6R-TBYHG
                Used output buffers: 3 of 24 (12 max)
                Static ram: 25712
                Dynamic ram: 93224 of which 12 recycled
                Exception stack ram used: 456
                Never used ram: 11668
                Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,1664) IDLE(ready,160)
                Owned mutexes:
                Last reset 03:10:22 ago, cause: software
                Last software reset at 2020-01-24 14:58, reason: User, spinning module GCodes, available RAM 11644 bytes (slot 3)
                Error status: 0
                Free file entries: 10
                MCU temperature: min 34.2, current 34.7, max 38.9
                Supply voltage: min 23.7, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, SG min/max 0/368
                Driver 1: standstill, SG min/max 0/341
                Driver 2: standstill, SG min/max 0/158
                Driver 3: standstill, SG min/max 0/1023
                Driver 4: standstill, SG min/max 0/128
                Date/time: 2020-01-24 18:09:01
                Slowest loop: 114.31ms; fastest: 0.06ms
                Hiccups: 0, FreeDm: 160, MinFreeDm: 100, MaxWait: 2653530ms
                === DDARing ===
                Scheduled moves: 4, completed moves: 4, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                Heater 0 is on, I-accum = 0.3
                Heater 1 is on, I-accum = 0.4
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 145.57ms; fastest: 0.00ms
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is running
                  WiFi firmware version 1.23
                  WiFi MAC address 60:01:94:2e:c4:57
                  WiFi Vcc 3.34, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 23224
                  WiFi IP address 192.168.1.236
                  WiFi signal strength -45dBm, reconnections 0, sleep mode modem
                  @bearer and the other machine
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-beta2 running on Duet WiFi 1.02 or later
                  Board ID: 08DGM-956GU-DJMSN-6JKFD-3SD6M-1URHG
                  Used output buffers: 3 of 24 (19 max)
                  Static ram: 27988
                  Dynamic ram: 92560 of which 24 recycled
                  Exception stack ram used: 496
                  Never used ram: 10004
                  Tasks: NETWORK(ready,596) HEAT(blocked,1232) MAIN(running,1596) IDLE(ready,76)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 18:26:58 ago, cause: software
                  Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10236 bytes (slot 0)
                  Error status: 10
                  SD card longest block write time: 10.4ms, max retries 0
                  MCU temperature: min 38.0, current 38.3, max 38.7
                  Supply voltage: min 24.5, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                  Date/time: 2020-01-24 18:12:29
                  Slowest loop: 13.62ms; fastest: 0.09ms
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                  === MainDDARing ===
                  Scheduled moves: 9, completed moves: 9, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                  === AuxDDARing ===
                  Segments left: 0
                  === Network ===
                  Slowest loop: 202.25ms; fastest: 0.09ms
                  Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                  • WiFi -
                    Failed messages: pending 0, notready 0, noresp 1
                    WiFi MAC address 5c:cf:7f:76:60:cf
                    WiFi Vcc 3.43, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 23240
                    WiFi IP address 192.168.1.85
                    WiFi signal strength -37dBm, reconnections 0, sleep mode modem
                    Socket states: 4 0 0 0 0 0 0 0
                    @bearer
                    This is from my Ubiquiti Access point dashboard. It's showing that neither printer has dropped connection to the network.
                    Screen Shot 2020-01-24 at 6.18.34 PM.png Screen Shot 2020-01-24 at 6.17.07 PM.png
                      A Former User @ctilley79
                      @ctilley79 said in DWC 2.06, Experiencing Connection Interruption Errors:
                      😍 that should rule out connection issues. And it also confirms you're running
                      DuetWiFiServer 1.23 which i believe is the correct version. (Someone will probably be along shortly to correct me if I'm wrong, Icouldn't find the refrence I was looking for with a quick search)
                      • smoki3undefined
                        smoki3
                        I also get alot of these issues with 2.06 and 2.07
                        • mwolterundefined
                          mwolter
                          Same here, with a Duet 2 Ethernet rev 1.04 running RRF 2.05. Constant reconnection messages and approx one hour into a print I lose all access to DWC. I can still ping the board, the print continues fine and PanelDue continues to work fine. Did not have issues with version 2.04.
                          mwolterundefined 1 Reply Last reply Reply Quote 1
                          • mwolterundefined
                            mwolter @mwolter
                            @mwolter Updated to DWC 2.07 and it appears to have helped with the web interface becoming unresponsive. There are still a lot disconnection notifications in the console but at least I’m not locked out of the web GUI. Interesting thing, I don’t notice the disconnection pop ups as often. Prior to 2.07 it was common to see them if DWC was open and in focus. Now I don’t notice them as much but there are still quite a few in the console. Could this be because the Mac doesn’t give priority to safari when it’s minimized? BTW, this is with the lates MacOS and Safari.
                              ctilley79 @mwolter
                              @mwolter That's what I'm noticing as well. Seems the disconnect notifications in the log aren't affecting usability. Just annoying
