duet2, firmware 3 --> bed and 1 heater on TEVO little monster
Firmware installation
808
    RafB
    Hi, why can't I find my bed and heater after Firmware 3 for Duet2? I used https://configtool.reprapfirmware.org/Start
    Can you help me? Thank you
    M92 X80.00 Y80.00 Z80.00 E837.00 ; set steps per mm
    M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; set minimum Z
    M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
    M950 H3 C"nil" ; Disable heaters h3-h7 to free up pins
    M950 H4 C"nil"
    M950 H5 C"nil"
    M950 H6 C"nil"
    M950 H7 C"nil"
    M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H6 F200 T2000 ; set Z probe type to bltouch and the dive height + speeds
    M557 R150 S20
    M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
    M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
    ;M563 P0 D0 H1 F0 ; define tool 0
    ;G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
    ;G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
    M501
      droftarts administrators
      @RafB This is a stock output from the RRF config tool to compare:
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      But mainly you need M140 H0 and to uncomment your Tools section.
        RafB
        @droftarts said in duet2, firmware 3 --> bed and 1 heater on TEVO little monster:
        Thank you
        I've tried to add M140 but still got nothing. See the screenshot
        I don't understand where this is coming from and how to find my mistake.
        Thank you for any help.
        undefined 1 Reply Last reply 28 Jan 2020, 07:30 Reply Quote 0
          deckingman @RafB
          @RafB prior to RRF3, H0 was by default, the bed heater. Since RRF 3, it is not and you have to explicitly define it using M140 H0. Are you sure that you put that command in your config.g and saved it? BTW that's H zero not the letter "O".
            RafB
            Thank you for your help.
            Droftarts, I forgot to uncomment the tools, it works...
            I have a new problem that I don't understand at the moment.
            After a home, I get this message
              Post your homing files.
                RafB
                ; homedelta.g
                ; called to home all towers on a delta printer
                ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 14:51:14 GMT+0100 (CET)
                G91 ; relative positioning
                ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
                G1 H1 X705 Y705 Z705 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
                ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
                G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
                ;G1 Z-10 F6000 ; move down a few mm so that the nozzle can be centred
                G90 ; absolute positioning
                ;G1 X0 Y0 F6000 ; move X+Y to the centre
                  How are you homing when that message happens? From the DWC? Sending G28 in a gcode file?
                  Can you evoke it again by sending those lines from homedelta manually in the console?
                    RafB
                    @Phaedrux said in duet2, firmware 3 --> bed and 1 heater on TEVO little monster:
                    Hey, guys,
                    I'm doing a G28 and then I want to put my head down, that's when the message comes.
                    When I send a gcode file with G28, it works perfectly.
                    undefined 1 Reply Last reply 8 Feb 2020, 21:34 Reply Quote 0
                      Phaedrux Moderator @RafB
                      @RafB said in duet2, firmware 3 --> bed and 1 heater on TEVO little monster:
                      What do you mean by "I want to put my head down,"?
                      If you press the homeall button in the DWC does it work without error?
                        RafB
                        Okay, I just figured it out and everything seems to be working fine.
                        I was trying to shoot my hothead but I pressed +0.5mm and when I pressed -0.5mm I got the same message.
                        On the other hand if I do Home(G28) and I press -0.5mm my hothead goes down correctly.
                        Sorry, rookie mistake...
                          Glad you figured it out.
                            RafB
                            I wanted to run a print but I still have to put G31 Zx.xx (0.88mm).
                            I don't understand the difference between Firmware 2 and 3.
                            Can you advise me on this point here? J'ajoute simplement la ligne à Z-probe?
                            G31 Z0.88
                            Actuel z-probe
                            M557 R150 S20
                              RafB
                              There is no example in the firmware3 wiki. Complicated for a beginner like me
                              https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_G31
                              undefined 1 Reply Last reply 8 Feb 2020, 22:30 Reply Quote 0
                                droftarts administrators @RafB
                                @RafB Refer to the main gcode dictionary: https://duet3d.dozuki.com/Wiki/Gcode#Section_G31_Set_or_Report_Current_Probe_status
                                Put it in your config.g. eg
                                G31 P500 X0 Y0 Z0.88                            ; set Z probe trigger value, offset and trigger height
                                M557 R150 S20
                                This is where you put your probe XY offset, too. You can use the RRF config tool to produce example code: https://configtool.reprapfirmware.org/
                                undefined 1 Reply Last reply 8 Feb 2020, 22:39 Reply Quote 0
                                  RafB @droftarts
                                  @droftarts Thanks a lot!
                                  I would like to know if it is possible to change the shrinkage values during printing?
                                  undefined 1 Reply Last reply 8 Feb 2020, 22:43 Reply Quote 0
                                    @RafB You can use https://duet3d.dozuki.com/Wiki/Gcode#Section_M579_Scale_Cartesian_axes for scaling. However, I don't know the effect of doing this during a print.
