Duet2wifi water-cooled
498
    A Former User
    as @bearer said, move the duet outside of the enclosure, change the wires, lengthen them and you are golden ... if you really can't do it, give up on water and go with mineral oil, dump the whole thing in mineral oil and cool the mineral oil tank with a coil that has cold water running trough it if you areadly have water cooling set up
    undefined undefined 2 Replies Last reply 27 Jan 2020, 03:11 Reply Quote 0
      Phaedrux Moderator @A Former User
      @smece said in Duet2wifi water-cooled:
      @pipersw and please post pictures!
        zapta @A Former User
        As @smece said, move the duet outside of the enclosure if possible. This addresses the root cause.
          pipersw
          I cannot put the electronic outside I prefer to have all inside the printer and no wire outside the enclosure.
          ? ? 2 Replies Last reply 27 Jan 2020, 07:09 Reply Quote 0
            A Former User @pipersw
            @pipersw how do you plan on cooling the water? If you can stick a radiator + fan on the outside you probably fit the Duet in the same space instead. If you plan on having the water cooling all on the inside then you're just adding heat to the closed system.
              Nxt-1 @pipersw
              @pipersw said in Duet2wifi water-cooled:
              Waterblock have to be put on top of the components or on the bottom pcb ?
              In general (at least for the stepper drivers) you need to cool components from the bottom. Their thermal via's are on the bottom of the components and in direct contact with the heavy copper planes in the pcb to distribute the heat. So it also makes sense to cool the whole underside of the pcb if at all possible.
              I could use thermal adhesive for fixing the blocks on pcb, but I don't know if it's electrical conductive.
              Have you some pictures of duet2wifi bottom ?
              I have found that often thermal compounds are at least a bad conductor, sometimes even a good one. So definitely check your material. On the topic of attaching your waterblock, keep in mind that the bottom surface of the Duet has many protrusions from component legs sticking trough the board. I would be surprised if you can fit a decent sized water block to the bottom with any amount of thermal contact.
              The picture below (samelessly taken from somewhere else on the forum) illustrates my point.
              Duet3D and delta printer enthousiast. Buildlog
              Looking for Duet3D configuration support, check out Nxt-3D
                Cannot or don't want to?
                Prefer it all you want, it's NOT a good idea.
                You came here requesting help, if you don't like the advice being offered what is the point in asking?
                undefined 1 Reply Last reply 27 Jan 2020, 20:14 Reply Quote 0
                  pipersw @A Former User
                  @CaLviNx said in Duet2wifi water-cooled:
                  Why are you so agressive ?
                  The enclosure is in my living room, so noise is important, and I don't want the duet outside, only the radiator.
                  In commercial temperature, the components are operating up to 70C ambiant, and 85C in industrial temperature.
                  ? ? 2 Replies Last reply 27 Jan 2020, 20:16 Reply Quote 0
                    ...that moment you realize that the cooling of the radiator will have to match the cooling of the duet in any case...
                    (also have you even read https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board#Section_Cooling )
                    edit:
                    Their specifications are still listed at 25C, exceed that and expect to derate everything including power handling and MTBF.
                      but you will have more noise from the fan on the water grill than you will have from duet, on room temperature with nice heatsinks stuck to the bottom there's no need for force cooling (I do have some "will start to blow fan if the box temp goes over 40c" but the fan never turns on)
                        If you mount the duet outside vertically with enough air vents it likely won't need a fan at all unless you're running 2a+ current.
                        12 out of 13
