    Z height probe before print starts
    • andornotundefined
      andornot
      Please can somebody tell the command to measure and set the z height with the z probe before the prints starts, i only want to measure the center (x0,y0) so i can add the command in the start gcode of the print.
      SpatialOne custom delta printer, upgrading to print PEEK, PEKK & Ultem
      • Vetiundefined
        Veti
        its G30
        https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
          dc42 administrators @Veti
          @Veti said in Z height probe before print starts:
          its G30
          To be clear, G30 probes starting from the current XYZ position. So you probably want to use a command such as G1 X0 Y0 Z5 F6000 immediately before it.
          andornotundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti
            @dc42 said in Z height probe before print starts:
            the G30 has a parameter for X and Y to define the point of probing. Can this not be used as well?
            • andornotundefined
              andornot @dc42
              G1 X0 Y0 Z5 F6000
              so is the command G30 S-3 to set the z height before the print?
                dc42 administrators @andornot
                @andornot said in Z height probe before print starts:
                No, just G30.
