    Problem reaching machine setting in the latest release
    Duet Web Control
    • stendundefined
      stend
      Hi!
      I've started installation of my duet2 bought some months ago.
      i followed instructions and installed the latest firmware and web software. When i'm now about to install endstops and all the other cables i can't see the "machine settings" only UI settings in the webpage.
      I had saved a tab in the browser with the old web page and was able to see "machine settings" and also click it.
      I really need to see the endstops indications, any help?
      I also tried to revert the firmware to the "2" generation but got an
      error reporting that duetcombinedIAP file was missing so it is not
      possible to revert.
      • Danalundefined
        Danal
        Does your left bar look like this?
        If so, the machine settings are at the bottom.
        If not, press the "hamburger menu", the three bars just left of the system name (duet3 in the example)
        • stendundefined
          stend
          Hi1
          Thanks for answering!
          In Settings i have only "User Interface"
          About says "Duet Web Control" 2.0.0-RC3 is that right?
            dc42 administrators @stend
            @stend said in Problem reaching machine setting in the latest release:
            Hi1
            That's very old. Try the 2.0.7 SD version from https://github.com/chrishamm/DuetWebControl/releases/tag/2.0.7.
            • stendundefined
              stend
              !! working
              Thanks for the very prompt reply.
              Now first a cup of tea and then endstops
              regards
              /Sten
                Phaedrux Moderator @stend
                If you do ever want to return to the previous 2.x firmware you can find that missing file along with the other firmware .bin files in the release.
