    BLTouch will not deploy
    1.0k
    • PeteIHughesundefined
      PeteIHughes @Veti
      @Veti
      Hope these help.
      As I said, I wired it per https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
      on heater 7
      Also tried the wiring on this site and heater 3
        PeteIHughes @DIY-O-Sphere
        @DIY-O-Sphere
        Sorry, I really don't understand.
        I tried the wiring on the page you linked
        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
        and this in my config.g
        M307 H3 A-1 C-1 D-1
        M558 P9 H5 F100 T2000
        G31 X0 Y0 Z0 P25
        so heater 3 I guess.
        I did not come across any documentation for the pullup resistor ^ thing.
        I am just trying to follow posted documentation
        Thanks
        Pete
        btw, the Ender 3 stock is doing a massive job printing the PETG mount right now
        Phaedruxundefined DIY-O-Sphereundefined 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @PeteIHughes
          @PeteIHughes said in BLTouch will not deploy:
          M307 H3 A-1 C-1 D-1
          G31 X0 Y0 Z0 P25
          This is for firmware 2.0. Are you using Firmware 3.0 or no? Your original config looked almost correct for RRF3.
          • DIY-O-Sphereundefined
            DIY-O-Sphere @PeteIHughes
            @PeteIHughes
            Sorry the link wasn't copied as expected....
            https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
            M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
            M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            You have wired to heater 7 so the code should be
            M558 P9 C"^zprobe.in" H5 F120 T6000
            You don't need the mod pin....
            (UTC+1)
              @PeteIHughes
              Also check the endstop setting
              That would use an connected endstop
              M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
              Normally with Bltouch the probe is used as endstop
              M574 Z1 S2 ; Set endstops controlled by probe
              (UTC+1)
              PeteIHughesundefined 1 Reply Last reply Reply Quote 0
                @DIY-O-Sphere
                Thanks for all the help BTW
                Unfortunately, none of the above suggestions has affected anything.
                It is not that the BLtouch isn't probing correctly.
                The issue is that the probe doesn't move at all.
                The probe servo is not moving the tip out.
                It does so twice on power up, but never again.
                M401 does nothing.
                It is almost like it is dead, but as I said, I have 2, and 2 sets of wires.
                So I believe that the Duet is not sending a signal to operate the probe pin..
                I have a multimeter if needed to check duet pin outputs,
                and worse case scenario, I have a stock ender 3 I could test it on.
                Thx again
                Pete
                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                  PeteIHughes
                  I am on Duet Web Control ver 2.0:4
                  Wifi Server ver 1.22
                  Wifi/ethernet 3.0
                  2020.01.03b3
                    Phaedrux Moderator @Veti
                    @Veti said in BLTouch will not deploy:
                    post a picture of your wiring
                    the rrf3 deploy is
                    M280 P0 S10 ; deploy BLTouch
                    What do you have in your deploy macro? Does it match what veti says here?
                      Then the Bltouch is working
                      Have you tried "M280 P0 S10" in DWC?
                      (UTC+1)
                        @DIY-O-Sphere
                        That worked !!!!!!!
                        so my guess is that my deploy probe "g" file is bad.
                        It is all lower case.
                        could that be it ?
                          DIY-O-Sphere
                          @PeteIHughes
                          If they are from RRF2 you have to edit the content
                          deployprobe.g
                          M280 P0 S10
                          retractprobe.g
                          M280 P0 S90
                          (UTC+1)
                            dc42 administrators @PeteIHughes
                            @DIY-O-Sphere
                            That worked !!!!!!!
                            could that be it ?
                            No, lowercase is fine. The difference is the M280 P parameter. In RRF2, the P parameter is the logical pin number, which for heater pins is the same as the heater number. In RRF3 is it the number of the servo device that you created using the M950 S command.
