    How to Set Z home
    • Keith53undefined
      Keith53
      I am using a switch to home XYZ. When I home Z the nozzle is about .3mm below the bed. I have been trying figure out how to set it so it knows this. When I home XY the web interface shows X-33 Y-10 but Z still shows Z0.0.
      M208 X-33 Y-10 Z-0.3 S1 ; set axis minima
      M208 X220 Y220 Z240 S0 ; set axis maxima
      I also tried editing the homeZ.g and the homeall.g
      G92 Z0.3 ; set Z position to axis minimum (you may want to adjust this)
      What am I doing Wrong?
        Phaedrux Moderator @Keith53
        Can you post your homing files? Maybe your full config.g too.
        Do you mean that the nozzle is pushing into the bed surface? How are you measuring -0.3?
        When you trigger the endstop the position is set to either the minima or maxima from M208. So triggering the zmin endstop should set the position to -0.3 as you have that as your minima. Unless it's being reset with an G92 Z after hitting the endstop.
        Keith53undefined 1 Reply Last reply Reply Quote 0
        • Danalundefined
          Danal
          @Keith53 said in How to Set Z home:
          Have you tride G91 Z-0.3?
          • Keith53undefined
            Keith53 @Phaedrux
            @Phaedrux said in How to Set Z home:
            The G92 Z0 was resetting it in the homeall.g and homez.g files. I commented out ;G92 Zxxx and now when it is on the Z end stop it shows what is in M208 below Thanks!
            Not sure why G92 Z-.03 did not work. I use G92 on mills at work sounds like it should do the same thing on the printer.
            G92 "Change Work Coordinate System"
            G92 X0 Y0 Z=VTOFH[VTLCN]+12.7
            This would set where the spindle is now to X0 Y0 and Z would be the current tool in the spindles length+12.7
              I'd have to see the actual file to venture a guess.
              Using G92 in the homing files is a bit of a kludge honestly. Best to refrain if possible.
