    Considering a Duet in my Makergear M3
    1.3k
      Also you can directly embed the photo if you link directly to the jpg
      p
      • Danalundefined
        Danal
        @guycobb2 said in Considering a Duet in my Makergear M3:
        RAMBo v1.3
        Rambo uses A4982 drivers. Duet uses TMCxxxx (depending on which Duet you are talking about). This will make a HUGE difference.
        With regard to Octoprint, it is not needed, and in fact has several drawbacks, with a Duet. The Duet has its own web interface.
        And, of course, on this forum, you'll discover that Duets not only produce excellent prints, they also keep your coffee warm and improve your overall appearance. Well, maybe not the coffee thing...
        • guycobb2undefined
          guycobb2
          I currently have a duet in my Artemis and like it. It has some things octoprint doesn’t that I miss and vice versa.
          Here’s another print I did to observe straight lines vs curves at different layer heights. Starting at bottom it goes 0.3->0.2->0.1->0.05 at 5mm increments.
          o
            Considering the price of the M3 I wouldn't be very pleased with that surface finish.
            • guycobb2undefined
              guycobb2
              100% agree with that. I’ve been in contact with them and they seem to be trying to drill down. Either way, I’ve sent me my gcode and they printed it on their machine....looked the same. So I don’t suppose it’s my machine. I got the M3 as a second owner at a discounted price so I’m not nearly as bummed as I would’ve been at full price....but still, it wasn’t cheap. However, I really like the build of it, they’ve done a lot of things right IMO.....it’s just this one (rather important) flaw that hopefully can be remedied easily. Aside from, what I assume to be, the extrusion issue it seems to stack layers very nice.
                Well if the build quality of the machine is good, then it would be a good candidate for quality electronics.
                • guycobb2undefined
                  guycobb2
                  So do y’all think it’s simply a limitation of the electronics or a mechanical design flaw?
                    Measure the distance between peaks. Do the match the belt pitch? Do they line up regardless of the layer height? It looks like they do. That might indicate poor belt mesh on the idlers.
                    guycobb2undefined 1 Reply Last reply Reply Quote 0
                    • guycobb2undefined
                      guycobb2 @Phaedrux
                      @Phaedrux what’s the proper way to do that?
                        Caliper. Ruler even. If you take a photo with a known scale you can even do it digitally.
                        • guycobb2undefined
                          guycobb2 @Phaedrux
                          @Phaedrux just measuring center to center of teeth?
                            Yes. The belt teeth are probably GT2 type belts with 2mm pitch. Curious to see if the ridges on the print match that.
                            • guycobb2undefined
                              guycobb2 @Phaedrux
                              @Phaedrux match it in what manner. A fraction of 2mm? How would it relate?
                              • guycobb2undefined
                                guycobb2
                                Also, I’m like 99% sure that print with the various layer heights was 35mm wide.
                                  https://forum.duet3d.com/topic/6248/help-my-prints-are-wavy/2?_=1581049312237
                                  • guycobb2undefined
                                    guycobb2
                                    I’m not at home at the moment but it appears the idlers are at least toothed and it looks like 16T pulley. I know the steps/mm on the X/Y is 88.88 with a 16x microstepping.
                                    https://www.makergear.com/collections/parts/products/idler?variant=49869543759
                                      Even toothed idlers can cause ridges if the teeth don't mesh smoothly. I've had that on my own printer. Flipping the belts to run on smooth idlers helped eliminate any ridges. But that's a corexy and probably not an option on the makergear.
                                        Also I did some googling and found some threads complaining about ridges on the makergear forums as well going back to 2015. So it may be working as designed.
                                        guycobb2undefined 1 Reply Last reply Reply Quote 1
                                        • guycobb2undefined
                                          guycobb2 @Phaedrux
                                          @Phaedrux meaning flawed?
                                            Maybe. I'd start looking on their forum to see if anyone else has already replaced the electronics to see if it's actually helped at all.
