    Rippels and Ghosting on Y-Axis of converted Ender 3
    My Duet controlled machine
    8
    74
    13.5k
    • 4latheundefined
      4lathe
      This is exactly the same problem Phaedrux has been trying to help me with on my Ender. Im equally perplexed.
        @4lathe right I was actually gonna link your thread here since it sounds pretty similar.
        https://forum.duet3d.com/topic/14116/weird-ripples-on-my-maestro-rrf3-conversion?_=1581124694675
        • devleonundefined
          devleon @Phaedrux
          @Phaedrux said in Rippels and Ghosting on Y-Axis of converted Ender 3:
          That seems like excessively optimistic acceleration values for the Ender. I get a lot of ringing with much more than 600.
          I've set it to 800 for now, but with zero difference in the ripples in the 40x40mm cube. Maybe I should try a ghosting/ringing test if I get less ringing.
          Try changing the jerk policy to M566 P1 and testing PA again.
          I actually already had the P1 in there since yesterday. However, I had only done prints with no retractions (vase mode) to calibrate flow, and it made no difference. However, the first print I just did right now with retractions to dial in PA again, I got really bad underextrusion after an unretract, and the stepper was making wierd sounds, as in, the unretractions before the lines with underextrusion made much louder sounds. Hard to decribe the sound, just sounded like a very quick and loud stepper move.
          The exact same G-Code with
          M566 X600.00 Y600.00 Z60.00 E2000.00:2000.00 P0
          printed the following cube just fine, with PA values from 0 to 0.8.
          Seems like after changing the nozzle diameter to 0.35mm, a wall thickness of 0.4mm and recalibrating flow to 0.975, I now need a smaller PA. Which speaks for a lower pressue in the nozzle, which is good I think. Not really sure which value to pick here though?
          For the Ender I'm finding that the stock belts are pretty stretchy and with no tensioners by default excessive ringing seems to be pretty common. doing a tensioner mod might be worthwhile if you haven't already.
          I've already replaced the belt for the y-axis without any difference... So that can't be it... I also tried varying belt-tension, without much difference.
          Well, guess the next step would be swapping the driver or replacing the motor of the y-axis to see if that makes a difference. If that still doesn't make a difference, I really don't know.
          Also regarding layer consistency, would direct drive give me better results? The layers are still not 100% consistent, as you could see in the vase I held against the light. Maybe this is also just simply down to the filament? Finally, where does this wierd pattern come from you can even see on the last picture? The one that makes the surface look like a tire.
          This is what I mean.
            Phaedrux Moderator @devleon
            @devleon said in Rippels and Ghosting on Y-Axis of converted Ender 3:
            Try reducing your reprime speed.
            The short bowden of the ender shouldn't be this bad. Check the couplers though. If they are sliding and sloping that's a problem that's fixable. Some people get good results from capricorn tubing and couplings.
            The vase print almost looks like there's bad backlash or slop, but that doesn't seem to appear on the cube prints.
            Perhaps you already have, but I think I would be tempted to disassemble and reassemble it checking for squareness while I go. Something just seems mechanically off.
            devleonundefined 1 Reply Last reply Reply Quote 0
            • devleonundefined
              devleon @Phaedrux
              To what extend? I'm using firmware retract of 6mm with 40 mm/s with my bondtech bmg, I've seen people do up to 100 mm/s on the BMG, so 40 mm/s already seems rather low. But maybe I have a bit too high accel and jerk? I remember getting those values from a thread somewhere here.
              It's also visible when you hold the cubes against the light. The individual layers are definitely not the same thickness, and it varies every 3-8 layers. But maybe this could also just be the cheapo filament I'm using? I do have some filamentum vertigo gray too, I will give it a try tomorrow. Pretty tired of printing cubes at this point.
              Also, Backlash and slop where? I just checked all the couplers - nothing moves there. I'm already using capricorn tubing.
              I appreciate your help 🙂
              Oh I have... A couple times. Everything is as square as it can get, and things are carefully aligned, checking with calipers. And again, I just installed a linear rail for the y-axis, and that didn't affect the ripple at all - so I'm thinking it's the motor, driver or even the pully, as these are the only parts I haven't changed yet.
                In that case try reducing the E jerk from 2000 by half see if it helps with the slipping. You should be able to increase the retraction speed itself which should help reduce the blobbing effect. The M566 P1 change is basically allowing jerk to be applied in cases where it wasn't previously. So having such a high jerk value could explain why it's slipping.
                The reason I suggested reducing reprime speed was that I recently had a similar underrun after a retraction with a particular filament. It just didn't flow as quickly as some other filaments and a slower reprime (from 60mm/s to 45mm/s) helped substantially and doesn't seem to negatively affect other filaments that flow more easily.
                Regarding the layers bulging. It could be filament. Have you measured it at multiple points to see if it really does vary? Also make sure you measure each point at multiple angles and take the average for each point since filament is not really circular, but more oval. If you measure North by south, east by west, northeast by southwest, northeast by southeast, you should see that it's wider in one direction than the other.
                But it would have to be pretty bad filament to matter that much I think.
                Which brings to the lead screw. Yu said you've replaced it with a 2mm lead leadscrew which is good for resolution, but also that you have an anti backlash nut. That can lead to stiction where it binds and releases seemingly in a pattern. Have you tried without the anti backlash nut?
                What are you using for the Z axis lead screw motor coupler?
                If you move the Y and X axis back and forth with the belts detached do they roll smoothly?
                I assume this is still with the stock motors? Do you have other motors on hand to test with?
                • devleonundefined
                  devleon @Phaedrux
                  Alright, I have reduced the jerk to 1000, accell to 4000, increased the retraction speed to 60 mm/s and set the jerk policy to 1 again. Trying another print again now. So far, it's looking good. No underextrusion.
                  And me from the future: The print just finished, looks identical, I can't see any difference at all.
                  Just measured it again, it varies a little bit. Anywhere from 1.78 to 1.83, with an average of 1.8, which is what I have set in PrusaSlicer as well. I don't think a 3% variation should make this much difference?
                  I have not yet tried without the backlash nut. I should note, the backlash nut that came with the leadscrew also has a pretty big play. I can move the leadscrew left/right/front/back, even though the brass nut is firmly bolted into the XZ axis. Before that when I had the stock leadscrew and nut, I had to loosen the brass-nut anyways, as it would bind when tightened. So I guess it was always sorta loose. I'm waiting for a POM nut that's supposed to have much less play.
                  But, if it were the Z-Axis and lead screw, wouldn't the pattern be the same across prints? Like I saw when I had overconstrained the not-as-straight-as-i-had-hoped leadscrew?
                  I just compared 6 cubes to each other, and they don't share the thicker lines in the same position.
                  I'm using a spider / plum coupler. The thing with the red rubber in the middle.
                  All Smooth. With the the motors attached, I can feel all the steps.
                  I'm running the following motors:
                  0.9° JK42HM34-1334 for E1, E2
                  0.9° JK42HM40-1684 for X, Y
                  1.8° JK42HS34-1304 for Z (stock)
                  I do have the original creality motors still, so I could use them to replace the 0.9 motors. I also just tried to use swap the drivers of E1 and Y, but turns out I can't actually do that with 2.05, at least I found nothing obvious in the documentation. Guess that would require me to upgrade to RRF3, but that's a whole other topic.
                  Finally, I'm going to print a cube with some filamentum vertigo gray now, which is very consitently 1.75mm.
                  Edit: And to a surprise to noone, I'm still getting inconsistent layers even with the filamentum vertigo gray ¯_(ツ)_/¯. It does look a tiny bit better though. I'm going to try my other extruder and BMG now.
                  • devleonundefined
                    devleon
                    And here's two cubes printed on the first bmg, and on the second bmg.
                    So two different motors, two different BMGs.
                    Just as a reference, here's my setup again:
                    Maybe it has something to do with the Y-Splitter. As a next step I can try removing the splitter completely, and feeding the bowden tube from the bmg directly into the E3D V6.
                      That would be a good plan of attack. Perhaps there is some added friction in the splitter.
                      • devleonundefined
                        devleon
                        Just for shits and giggles, I replaced one of the BMGs with a single drive metal extruder from the old days, and adjusted steps and calibrated it. Oddly enough, the same /////\\\ pattern is still visible, and the layers are still inconsistent. Maybe it has something to do with the microstepping, the TMC drivers, or the steppers from that particular manifaturer? Or it's simply the Y-Splitter.
                        I will remove that tomorrow, as it will require me to modify quite a lot of macros. I should do something else for now. I've spent too many hours today on my printer again.
                        • devleonundefined
                          devleon
                          Because I found my usb microscope, and because I have been obsessing about this too much again anyways, here are some pictures.
                          I present to you:
                          The tiny ripples (this is X):
                          The infamous ghosting on the y-axis:
                          And finally, the inconsistent extrusion.
                          I'm off to bed for now.
                          • devleonundefined
                            devleon
                            A new day, and i just finished a print with the Y-Splitter removed.
                            And on the left is the cube with the removed Y-Splitter.
                            A tiny bit better maybe? Not really though. Well. Not sure what to do now.
                            I'm going to try disabling interpolation and changing microstepping to see if that makes a difference in the ///\\ pattern.
                            The last thing I can do then is to swap the extruder motors, remove the backlash nut, wait for the POM nut, and upgrade the Z to linear rails as well. Maybe even do a Dual Z?
                            Edit: Doing a print now without interpolation. Oof, the motors are already way louder.
                            • devleonundefined
                              devleon
                              Well, disabeling interpolation only made the steppers louder, but didn't change anything. However, turning off my partcooling fan did finally made a change. Seems like the ///\\ pattern was caused by vibration of my cheapo 5015 blower fans. Does anyone have a reccomendation of a good, silent and non-vibrating 5015 blower fan? I guess the ones from china are probably all equally crappy.
                              Edit: Thinking about the unregular extrusion and irregular layers....
                              Maybe it's the nozzle? Maybe it's the PFTE tube itself?
                              Can't be the heatbreak, since it's an all the way through style hotend, so the PFTE tube is right ontop of the nozzle. But I also have an titanium heatbreak, so maybe I could try that too?
                              I also checked all couplers, they don't give.
                                Here's a good quality 5015
                                https://www.digikey.ca/products/en?keywords=259-1829-nd
                                Canadian store front mind you. But model number sunon MF50151VX-B00U-A99
                                • devleonundefined
                                  devleon @Phaedrux
                                  Thanks, found them too while I was searching just now. They are pricey, but hopefully worth it.
                                  I do have a 24V system though, and they are 12V. Would it be okay just wiring them in series, or should I get a voltage converter?
                                    @devleon quiet 24v blowers are non existent as far as I can find but I haven't searched digikey lately. I don't think sunon makes any 24v versions anyway. So you may be able to find a better quality option on there than you'd get from Amazon or AliExpress.
                                    If all your fans are 24v and didn't want to change the entirefan voltage to 12v then you could still use a buck converter to provide 12v+ to the blower directly and still have the negative leg connected to the fan terminal for pwm control.
                                    • 4latheundefined
                                      4lathe
                                      @devleon I know this doesnt help, but as I said earlier I have exactly the same problem on my converted Ender 3. I however have a bondtech/v6 direct drive setup. I have switched stepper motors, extruders, nozzles, forced spreadcycle, forced stealthchop2, gone from 1/4 to 1/256 without and with interpolation, turned fan on and off. All to no avail. The only thing that mostly cures it is printing above say 80mm/s. Have you tried that? Im beginning to think it may have to do with running belt teeth over the smooth idlers. I am about to try and change those to toothed idlers ifI can find something that works. Also the way the stock belt ends are held in place seems less than optimal. I originally notice those micro ripples on .2mm first layers. Do you see the same?
                                      • devleonundefined
                                        devleon @4lathe
                                        @4lathe
                                        Yeah, I saw your thread as well. I will try printing faster in the next days. I also already increased my current to the motors from 70% to 80%, but that only made them louder - plus again, the ripples are only on my Y-Axis, and not X, even though they use the same motors from the same lot from the same manufacturer. Maybe I need to get into the TMC2660 datasheet and adjust things from there.
                                        I actually don't see any ripples on the first layer. The first layer for me lays down perfectly flat with almost no artifacts, other than a tiny bit where the infill meets the perimiters. I only get the ripples on the y-axis, just liked you showed in your last pictures.
                                        Regarding belts an idlers - I'm using a linear rail for y with 3 toothed 16T idlers. The whole linear rail upgrade pretty much replaced everything : Aluminum plate, linear rail, high quality gt2 belt, toothed idlers. The only thing I haven't changed so far is the motor and the pully. All that, and it made barely any difference. It doesn't make sense to me 😕 It's frustrating.
                                        Something I noticed however - when I look from a very small angle directly at the idler at the back, I can see the belt slightly moving up and down. How come? I tried to tension the belt as tight as I could. Maybe because the belt is slightly higher and not parallel to the extrusion? It's the same in a stock ender 3.
                                        https://www.youtube.com/watch?v=x6kNXtgr0QY
                                        Maybe I should try another y-rail mod that moves the belt to the side?
                                        Or maybe, it's just a weakness of the frame? I have ordered some parts to stiffen the frame, but they will take quite a while to arrive here.
                                        On a different note, Is your extrusion also inconsistent, or better with your direct drive setup? You've only mentioned the ghosting/ripples so far, so I wasn't sure, and I'd love to get some input on someone with a direct drive setup, before I upgrade to it, lose my dual BMGs, and then I realize it was all for nothing... Edit: Just looked at some of your pictures and it definitely looks better. Maybe I'll make the swap to direct drive...
                                        Edit:
                                        • Another Thread I found with similar problems.... Their extrusion looks much more consistent than mine though, so there's that...
                                        • 4latheundefined
                                          4lathe
                                          Direct drive definitely an improvement. When I looked at your usb microscope pictures, it looked like my first layer artifacts. If you look at your first layer with the same magnification that you did on the walls, do you see the same small pattern?
                                          • 4latheundefined
                                            4lathe
                                            Also I had seen that other thread and read all of it hoping for a solution. Instead it ended with him printing abs and abandoning the problem.
